Question about Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener
Door won't go down
The "eye" is clear and nothing in the way but the door won't close. Any suggestions?
  • 1 more comment
  • bpdp Nov 10, 2007
    the door will raise but will not go down without holding the remote button down continously
  • Anonymous Nov 29, 2007
    Door won't go down unless keeping the remove control pushed down
  • Anonymous Mar 03, 2008
    I have the whisper drive, no obstruction door goes won't go down lights flicker.
    Novelist:
  • 91 Answers
Yes ,your path may be clear and you might have two indicator lights lit,but remember that theese sensors are called a sender and a reciever,the sender send,s a signal to the reciever to let it know that alls clear and their are no obsructions , but i can tell you from experience that if your sensor has the slightest fliker it will not allow the door to come down as a safety feature that was incorporated in all machines by law from 13 years ago, First thing you want to do is find out which sensor is the reciever and this is very easy ,Just put your hand in front of one of the camera,s ....The one sensor that,s light goes out is the receiver, Thats because it is not receiving a signal ! Now I want you to make shure it is straight in it,s holder,aiming directly accross from the other sensor! Next go to the sender ,This beam is the crucial one and must be directly pointed at the reciever, notice the light on the sensor it is always solid and will not go out ,Next i want you to go back to the reciever and loosen up the wingnut that holds the sensor in the bracket , as you move the sensor up to down and left to right notice the light on the receiver become dim and bright and flicker as you move it from the direct path of the sender , this is exactly what i want you to adjust to it,s brightest light possible , after you have tightened it back up go over to the wallpad or doorbell that operates the door and see if your problem has now dissapeared , Thank you for letting me try to help you and hopefully we fixed together Sincerely Glenn Mayer
Posted on Mar 05, 2009
Craftsman garage door goes up and down but won’t stay closed using remote or button on wall of garage?
Check to see if the electric eye and reflector are not blocked and are properly lined up... the electric eye is a safety device found with most units that shoots a laser ( invisible to the eye) across the opening of the door. On the opposite side of the door frame is a round reflector which looks a lot like the reflectors found on a bike tire. The laser bounces off of that reflector and return to a sensor located on the electric eye . If this beam gets broken or is not reflecting the door will pop up.
Aug 09, 2018 | Building Materials
I have a 1/2hp master mechanic door opener. when I close the door it goes the full travel down and then opens back up. i checked the eyes and everything was lined up. do you have any suggestions?
Look at the setting for "fully closed". it sounds like yours is set for slightly than the actual opening....So, the door reaches that location, and it thinks it hit an obstruction, which causes the door to open....While you are there, reset the sensitivity settings.
What I would do is back off the closed position setting so that the door stops an inch or two off of the ground, then adjust until the door is in the correct closed position...
You are correct on the "eyes" (infrared sensors) being lined up, if they were not, the door would not close at all.
Mar 15, 2011 | Vacuums
The power went out in my area about a month ago. When I came home, I had no way in b/c I didn't have a key since I depend on the garage door all the time. I did attempt to open it from the outside but I...
SOUNDS LIKE YOUR SAFETY EYES MAY BE OUT OF ALIGNMENT OR A BAD CONNECTION.
WHEN HOLDING DOWN THE WALL BUTTON MAKES THE DOOR CLOSE PROPERLY THE PROBLEM IS IN THE SAFETY EYES.
ARE BOTH LEDS ON? - CHECK FOR A LOOSE OR BROKEN WIRE.
ARE THE EYES WIRED CORRECTLY?
ARE THEY AIMED AT EACH HOLDING DOWN THE WALL BUTTON OVERRIDES THE SAFETY EYES.
HOPE THIS HELPS
Nov 03, 2010 | liftmaster Chamberlain Garage Door Opener...
I have a craftsman garage door opener and I have to hold the button down in order to close the door. The door opens fine and the sensors are clear. The unit starts to close then stops, the lights start...
When you can close the door by holding down the wall button it IS the safety eyes or wiring.
If the eyes are mounted to the track. Many times the track wll move as the door closes causing the eyes to move out of alignment.
Watch as the door moves down and see if they need to be adjusted.
If the eyes are not both lit - they are out of alignemnt or have a wiring problem. try adjusting them and see if the lights come on. - if not check the wiring
Hope this helps
Jul 12, 2010 | Sears Craftsman LiftMaster Chamberlain...
When you push either the remote or the switch at the door, the garage door will go down almost to the bottom and then come back up and the light will blink several times. This does not happen all the time....
Your safety reversing sensors must be connected and aligned correctly before the garage door opener will close. An obstruction in the path of the sensor will also cause your door to not close.
This sensor is an electronic beam, which is sent between two sending and receiving “eyes”. These eyes face each other and are located just inside your garage door. They may need to be adjusted so the beam from the sending eye is properly detected by the receiving eye. Once the receiving eye “sees” the beam from the sending eye, a green indicator light will glow on the top of the eye.
Jan 03, 2010 | Sears Craftsman LiftMaster Chamberlain...
My garage door won't close unless I hold the main button down in the garage. As soon as it closes it opens up again unless I press the button quickly. I can open it up using the remote, but cannot close it...
your garage door has saftey sensors at the door
these are photo eyes
in the owners manuel that came with the opener
that has pictures in it which would help
the photo eyes need to be clear of debri and aimed at each other with no obstruction
there are leds on each sensor and when aimes properly they should be light if i remember correctly
if you can not get them to light then you may have to replace the sensors
Oct 27, 2009 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster "Pro Line" Garage Door Won't Close-1999-#41A5021-C
If the main lights flash 10 times when the door reverses it is a problem with the door sensors or the wiring to them. Each sensor has a small light that must be lit and not blinking for them to work properly. Make sure each of them is on. If the sensors have been bumped you can tweak them a bit to get them pointed correctly. If you can't get both sensors to light then you either have bad sensors or once again the wiring is bad. I really wonder about the wiring because of the mouse problem. Also the wires are color coded. One of the is solid white and the other is white with black stripe. They can't be crossed.
Aug 13, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opened, won't close
If you can press and hold the wall button and the door will go down, you have a photo eye issue. Check the photo eyes at the bottom of the door.
Jan 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears craftsman garage door opener
WHEN HOLDING IT DOWN MAKES THE DOOR CLOSE PROPERLY THE PROBLEM IS IN THE SAFETY EYES.
ARE THEY AIMED AT EACH OTHER?
Jul 13, 2008 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener Logo
478 people viewed this question
Top Chamberlain Car Audio & Video Experts
Marvin
Marvin
cavs1
Albert Nairn
Albert Nairn
Level 1 Expert
Are you a Chamberlain Car Audio and Video Expert? Answer questions, earn points and help others
