Question about Sony 75-300mm f/4.5-5.6 for Alpha
Sony w 30
I just got this sony w 30 digital camera. the problem when it came to was that if i push power switch then camera wiill start and after few seconds the lens will retract and will come out again, continuously. i then cleaned all the contacts and main board. after that it started in normal way, but the flash wont charge, and the display shows erroe e:91:01. does any one knows the what this error is and how can i slove it. thank with regards, jaikishan
  • jaikishan bherwani Oct 19, 2007
    hello there aj,
    i solved the problem. there was a problem in focusing sectionof lens. when u start a camera it initalise and check its system. so when it comes to focusing system it shut down. serviced section, and it worked.
    thanks for the efforts.
    jaikishan
    Problem Solver:
  • 11 Answers
Check and see if the battery has enough power to charge the flash. If the flash is not charging that means there is not enough power in the battery as the flash requires more power than other functions of the camera. Try replacing the battery, clean contacts of the battery also and try. Let me know please. Thank you, AJ.
Posted on Sep 21, 2007
My Sony DSC P100 camera turns itself right back on after I turn it off. Is there a way to reset it?
THIS LOOKS LIKE THERE IS A PROBLEM WITH YOUR SWITCH. TAKE THE POWER SUPPLY OUT
AND GIVE THE POWER BUTTON A FEW HARD PUSH .IF THIS DOES NOT SOLVE THE PROBLEM THEN THE BUTTON MIGHT HAVE TO BE CHECKED BY A TECH
REGARDS.
Jul 02, 2011 | Sony Cyber-Shot DSC-P100 Digital Camera
I hadn't charged my w330 Sony camera for a while ....I've only had my camera for 6 months...and it's warranty is 2 yrs. The camera is in good condition, yet when I charged my battery, and later put it in...
In order to avoid people using 3rd party batteries, electronics manufacturers have started putting smart chips in the battery packs. The camera interrogates the smart chip and if it isn't the Sony chip, the camera tells you "too bad."
In your case, since you have a genuine Sony battery (it came with the camera, right?), return to the dealer and have them exchange the battery.
Feb 27, 2011 | Cameras
Sony cyber-shot DSC-W50 digital camera when cutting on the on button on the camera it says turn the power off and on again.
You can try the following 2 ways: 1. Format and restore the initial value of the camera. 2.First open the battery box cover (notice: do not pull out the battery now), then start the camera, pull out the battery just after the Len has turn out. Install the battery a few seconds later. Now start your camera with the Play button which is next to the viewfinder boot, and then moving the hand wheel to switch to camera mode, after Image appearing the screen, the camera will work properly.
Dec 30, 2010 | Sony Cyber-shot DSC-W50 Digital Camera
When I switch on the lens goes in and out a few times but no viewing screen. It asks to be switched off and then on. I can view stored pics but it won't allow me to take any?
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
· Turn off the camera.
· Remove the battery pack.
· Press and hold the power button for 30 seconds.
· Allow the camera to remain without power for 60 seconds.
· Reinsert the battery pack.
· Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the SET UP1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks,
KenSolutions
FixYa
Oct 21, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
My flash doesn't work? how do i turn it on?
Have you tried resetting your camera? Powerdown and take batteries out. Then hold "power" button for 30 seconds, release and repeat couple of times.
Jul 08, 2009 | Sony Cyber-Shot DSC-W5 Digital Camera
Battery life only lasts for a dozen shots, i have tried new batteries but no diffrent, battery indicator starts full and after a few shots is done to halfway before dying completly, any idea's
Hello, peterdearsam,
I had exactly same issue with mine and tried so many ways to fix this. Was even ready to buy some new camera instead of this Sony dsc w-17 but then found a way of resetting camera in such way: powerdown and take batteries out. Then hold "power" button for 30 seconds, release and repeat couple of times. It helped
Jun 27, 2009 | Sony Cyber-Shot DSC-W5 Digital Camera
Moultrie digital 4.0 game camera wont power up!
TRY PUSHING TO AIM...IF LASER DOESN'T COME ON, SWITCH MAY HAVE SEPARATED FROM SWITCH TOGGLE
May 18, 2009 | Moultrie GameSpy 4.0 Digital Camera Deluxe
My less than 2 year old sony dsc-w100 keeps powering off and on
my only idea would be that the power button is glitching out...anything in the manual about this?
Jan 22, 2008 | Sony Cyber-shot DSC-W100 Digital Camera
Please help with Sony DSC-H1 problem
Someone told me to try this:
take the batteries out, press and hold the power button for about 30 seconds, let the camera sit for a few minutes without batteries, then place new "good" batteries in it.Good luck
Dec 02, 2007 | Sony Cyber-Shot DSC-H1 Digital Camera
Sony 75-300mm f/4.5-5.6 for Alpha Logo
78 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
 Russ Hill
Russ Hill
Are you a Sony Camera Expert? Answer questions, earn points and help others
