Question about Dell TrueMobile 2300 Wireless Broadband Router (TM23001)
Router Dell-Wireless 2350 (Linksys)
My router is configured correctly but freezes up every time. I need to unplug it and will start again. Any help? Thanks
    Problem Solver:
  • 9 Answers
First try to check if your router is really configured correctly. Then try to check your banwidth, because bandwidth can also make your computer freeze. Then check also your cable if it is ok. Then try also to check the disk space in your computer because if your disk space is full or almost full it can also make your computer to freeze.
Posted on Aug 22, 2007
SOURCE:
Linksys router unidentified network....receiving full signals but showing unidentified network ...i hv checked SSID and key both are correctly entered....
Try resetting the router and then configure it again.
To reset the Linksys back to the default settings - Press and hold the pinhole RESET button at the back of the router with the power ON for 20 secs. then release the RESET button.
To connect to your wireless router, the router's wireless settings needs to be configured with the SSID, encryption etc. and also the wireless cards in all the laptops/computers needs to be configured with these router's wireless settings. Then the laptops/desktop computers can communicate with your wireless router.
Connect a LAN cable from the Linksys to the LAN port on your computer.
Open a browser and enter the Linksys configuration URL
http://192.168.1.1
The default login = admin
The default PW = admin
You can protect your router by changing the default admin PW (write it down and put it in a safe place)
Go to the wireless configuration and set up the SSID and WPA or WPA2 encryption.
Now apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Oct 15, 2012 | Linksys WRT160N Wireless Router
I cant renember the router password and...
Sounds like your router needs to be reset to the factory defaults by pressing the reset button on the back of the router for 4 to 6 seconds.
Here is the link to setting up your router for gaming:
https://support.dell.com/support/edocs/network/2350/en/EX_CONFG%5Cgaming.htm
Hope this helps..
Mar 12, 2010 | Dell Wireless 2350 Router
Wireless connectivity failing
Maybe try to reset it with a pin or pen on the backside,and configure it all over again.
Feb 09, 2010 | Dell Wireless 2350 Router
WIFI not working with Linksys wireless-g broadband router/Comcast
Unplugging the wireless router and connecting it again should not have altered the wireless connection/configuration. You have connected the cables correctly because the Internet works when you connect a LAN cable to the router.
The Linksys wireless configuration or the wireless card configuration in the computer was changed it to lose the wireless connection. The wireless card configuration needs to be changed to match the wireless router's settings or change the Linksys with new configuration settings and configure the wireless card accordingly.
To secure your router with a login password and wireless security, please follow my instructions - click on this link :-
Should you need further assistance, please leave me a comment.
Dec 25, 2009 | Linksys Wireless-G Broadband Router
I cant connect wirelessy with my dell wireless 2350 broadband router
Unplug router for 10 seconds and reconnect. This will stop the static charge buildup that happens frequently with routers. If needed, set up a wireless network using the network wizard and set all settings to automatic.
Sep 22, 2009 | Dell Wireless 2350 Router
Laptop connection problems to wireless router after reformat
Hi Drew,
I am assuming by access key your are referring to the pass phrase. The easiest way to approach this would be to use a cable to connect directly to the router from your laptop and confirm the wireless configuration on the router. You may have the pass phrase correct by the router is using WEP and your laptop is set to WPA or visa versa. Confirm the wireless configuration on the router then unplug the laptop from the router and change the configuration for you wireless settings on the laptop.
Apr 03, 2009 | Linksys Wireless-G Broadband Router
Disconnection problems
I see. You can try changing the wireless settings of the router. You can do that by accessing the web based utility of the router. Here are the instructions:
1. Click the Start button, and then click Run.
2. Type the following text in the Open box: http://my.router
3. If this is the first time configuring your Dell Wireless 2350 Broadband Router, or if the user name and password have not been changed from the default settings, type admin in the User Name field and admin in the Password field.
4. Click the OK button. The Configuration screen appears.
5. Under the Basic settings, under Wireless Settings change the channel from Auto to 1, 6, or 11.
If that does not work, you can try updating the firmware of the router. You can download the firmware from this site:
http://www.dell-drivers.com/dell-drivers-downloads/Dell-Wireless-2350-Broadband-Router_8689.shtml
Here are the instructions on how to upgrade:
1. Reaccess the configuration page of the router using a wired computer.
2. Click on System Tools, find Firmware Upgrade.
3. Click Browse and search for the firmware you downloaded from the site I gave you earlier. Select it and then start the upgrade. Let the firmware finish its upgrade.
May 21, 2008 | Dell Wireless 2350 Router
Fujitsu Siemens and Dell Wireless 2350
Before we have the wireless configuration discussion are you aware this computer has a WLAN on/off switch. I appears to be a recent feature to conserve battery live in some models.
Please reply if there are configuration isues you wish to discuss.
Dec 24, 2007 | Dell Wireless 2350 Router
Installing dell wireless 2350 router gets configuration failure
if its not broke dont replace it... you will need to contact your ISP for propper settings for that router. if that fails then the router needs upgrading.
Nov 11, 2007 | Dell Wireless 2350 Router
Dell TrueMobile 2300 Wireless Broadband Router (TM23001) Logo
558 people viewed this question
Ekse
Clive
Clive
