Question about Olympus EVOLT E-500 Digital Camera
Flash flickers, shutter won't work
On occation, the flash will flicker away very fast, but it will not take a picture. just keeps refocusing if you depress the button
  • 2 more comments
  • Suebee1966 Aug 21, 2007
    okay, but this is set on auto
    and thank you for your help
  • Suebee1966 Aug 22, 2007
    I will do that, thanks again.
    Sue
  • red robin Nov 02, 2007
    I used my camera the other night and all the pics were blurry. I realized it wasnt on auto. I put on auto but got the same results. now it wont even take a picture or focus. I went in and reset the settings back to the factory settings and got no results. Very frustrated!!!
    Help!!!!
Thank you... it was very helpful
Posted on Dec 18, 2007
I had that problem when I first recieved the E500.
In the menu, hunt around for the AF Illuminator setting, and then make sure it is off. This will stop the flickering, but the cam will take slightly longer to autofocus in the dark
Hope this helps!
Posted on Dec 14, 2007
    Genius:
  • 2,985 Answers
Refocussing or 'hunting' suggests there is insufficient light to focus. Up the ASA rating then try
Posted on Aug 20, 2007
  • john ash
    john ash Aug 21, 2007
    This still allows you to increase the ASA setting though
    check the full manual on the Disk in PDF
Why does my camera not capture any picture? Whichever mode I use, it does not capture any picture regardless of how many times I click the button.
Flash flicker is the camera trying to get enough light to focus, It occurs when you press the shutter release part of the way down.
Try the same thing outside, ensure you press the shutter real ease all the way down. If it still does not fire, switch the lens to manual focus (sliding switch on the side of the lens, move from A to M) If the camera shoot then, the camera is struggling to auto focus.
Feb 23, 2015 | Canon EOS 1100D / Rebel T3 Digital Camera
Now what?
Nothing is going on. Your camera is working as designed.
Most cameras have an upper limit on the shutter speed when used with flash. This is called the flash sync speed. At speeds higher than this the shutter is never opened completely, and as a result you would get only a narrow slit of a picture.
Usually this is not a problem since the exposure is determined almost exclusively by the flash and the aperture. Any action is caught and stopped by the brief flash, not the shutter. The primary reason for controlling the shutter speed is to use a slow speed to allow the background to expose.
Your camera may have a special high-speed flash mode that fires off multiple flashes coordinated with the shutter movement. Since you didn\'t say what model Canon camera you\'re using, I can only suggest you check the manual.
Apr 26, 2013 | Canon Speedlite 430EX TTL Flash
Kodak M1033 LCD black. entire images on SD black. It powers on and makes audio. Flash works as does the the green light. In other words it seems everything works except viewing, taking, and saving...
It might be easily fixed. A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jun 12, 2011 | Kodak EasyShare M1033 Digital Camera
My canon powershot SD 1000 will take outdoor pictures but wont take any with low light and the flash won't work. I see that someone else asked the same question but I can see what advice was offered
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help. Recommend trying the pencil tapping fix listed in the link. It worked on my SD1000 with the same problem.
Jun 04, 2011 | Canon PowerShot SD1000 Digital Camera
When I try to take a picture you hear a clicking noise and the flash is working but it will not take a picture
You may be too close to your subject and the autofocus is not locking in. back up a few inches and the shutter should go off. Try turning off auto-focus.
If this isn't the case it could be a shutter problem. Turn off the flash (if you don't you'll get blinded during my next step) look inside the barrel of the lens and click the shutter...you should see a little flicker inside the lens as you hit the shutter button. If you do see it, then it is in fact just the shutter...if not it's the camera itself. Be sure you are holding the shutter button down completely...as halfway only allows you o focus.
Nov 28, 2010 | Nikon D40x Digital Camera
Screen is black when turned on. view side works great on old pictures when button is pushed it flashes ,but no picture
Sep 06, 2010 | Canon PowerShot A620 Digital Camera
I have a Kodak Easyshare model dx5430 digital camera (5mp). It has worked like a champ for years. Last night I was at an event when the image display went dark at picture 31. All preceding photos were able...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
May 01, 2010 | Canon PowerShot A75 Digital Camera
No image on lcd for taking pictures. Lcd works fine to go through also to view old pictures. just black in camera mode. Tried shooting anyway and no picture. This happened once before and went away an hour...
Nov 05, 2009 | Canon PowerShot A620 Digital Camera
"Canon powershot s2 is" not showing live picture
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jun 22, 2009 | Canon PowerShot S2 IS Digital Camera
Olympus EVOLT E-500 Digital Camera Logo
225 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
