Question about Viking VGSC366-6B Gas Kitchen Range
Oven temperature is +100F warmer than setpoint
The model is a VGSC366-4GSS and about 4 years old. The termostat and electric control module for the oven was changed last year and the oven temperature is now: 350F when set to 200F 390F when set to 300F 450F when set to 350F 495F when set to 400F 575F when set to 450F Is there any way to adjust the settings or is other fault at play? Burners shut on and off at the higher temperature as they should, but it is impossible to produce temperatures less than 350F in the oven. Please indicate possible solutions.
  • peteorne Nov 23, 2008
    Oven is 450 when set to 350 and 350 when set to 250. Oven is 5 years old and we knew it was warmer than it indicated (chocolate cookies always burned!, but didn't realize how much. Never been serviced.
    Sergeant:
  • 274 Answers
Sounds like the wrong module got installed or is defective. Dangerous situation. Call or take it back to whoever installed it. If you did yourself, pull the control module and return it to the shop you bought it from for a new one or make sure you have the correct module by checking the part number on the module itself. Better yet call Viking directly. Here's customer support info: Customer Support If you own a Viking product and have questions or require assistance with product repairs if you wish to speak to a customer service representative please call us at 1-888-VIKING1 (1-888-845-4641), then press 1.
Posted on Aug 20, 2007
SOURCE:
Bake does not work
you need to call a repair service we do not recommend DIY with gas appliances.Safety reasons
Nov 02, 2017 | GE JGSP23 Gas Kitchen Range
JTP15 Oven - Shuts down after preheating
It sounds like the module is momentarily losing power when the bake relay clicks off. Does it do the same thing when you use broil?
Post back with the complete model number and I will try to find the wiring diagram for it and we will walk through checking it.
Thanks/Mike
Nov 03, 2007 | GE JTP15 Electric Single Oven
Amana Convection Oven - Not heating in normal bake mode, but works otherwise
I will say that is the control board that is not working properly. Have you try to unplugged for phew minutes?, this will reset the current settings. If not, I will star replacing the control board. Good Luck!.
Jan 13, 2014 | Amana Ovens
Frigidaire Oven doesn't turn off at set temperature
Hello - From what you have described it sounds like the electric range could possibly be experiencing a communication issue with the EOC, wiring harness or faulty element. Try resetting the unit by unplugging it or flipping the breaker off. Wait approximately ten minutes and turn on oven. If proves to be ineffective, contact a professional to move forward accurately.
Nov 01, 2012 | Ovens
F-4 error
This indicates an oven temperature sensor problem. Here is a link that should help http://appliancehelponline.com/oventempprobe.html
Jul 21, 2010 | Whirlpool RBD305PDS Electric Double Oven
What does a flashing code F10 mean? I was in the middle of baking when this code replaces the temperature and the stove starts beeping. It stops when I hit stop/clear, only to start up again in about 1...
The F10 indicates that the electronic oven control board senses a runaway temperature condition in the oven through the oven sensor circuit.
This can be caused by a faulty oven temperature sensor probe or a failed electronic control board.
Oven temperature is detected by the control board as it monitors the resistance through the oven temperature sensor circuit.
You could have a failed oven temperature sensor, a wiring harness failure, an open thermal switch or a failed electronic oven control board that would cause this problem.
The first component to check would normally be the oven temperature sensor probe.
If you have a volt/ohm meter, you can shut off the breaker for the range and remove the screws that mount this sensor to the back wall of the oven.
Carefully pull the wire harness into the oven cavity until you get to the wire harness disconnect plug.
You should have enough slack to pull it this far into the oven.
Disconnect the sensor but do not let the wire harness retract back through the back wall of the oven or it will be hard to reconnect.
Measure the resistance of the oven temperature sensor with your volt/ohm meter. At room temperature, the resistance should measure around 1100 ohms.
The resistance chart is shown in the image below.
If the resistance is above 2200 ohms at room temperature, then the sensor probe is causing the F10 error code and will need to be replaced.
You can order a new sensor probe from the Sears PartsDirect website. The part number for the sensor is 316217002.
If the resistance is normal, then one of the other causes mentioned above is producing your F10 code.
You would need to access the electronic oven control board (Timer) in the console and check the resistance at the sensor circuit connection to the control board as the next step in troubleshooting this problem.
http://media.fotki.com/1_p,wbqdsfkrfqtswfqxgtqsskgwtqkq,vi/krdbrtqkgxkrbbqbrwb/1/1303472/5961857/image37801img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 28, 2010 | Kenmore 94220 / 94221 / 94222 / 94224 /...
I need to calibrate an electric oven
Probably. There is often a key sequence that will enable a calibration mode. We need the full model number to find the tech info, or you can probably find it in the tech sheet which is normally taped on behind the control panel.
Oct 13, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Our Jenn-Air double oven is 10 yrs old. Will not
There are 3 things that can cause this:
1. Bake or Broil element faulty. The oven cycles these on and off to reach and maintain the average setpoint temperature. If the elements heat poperly during the time they are ON, then they are OK (may be able to see them glow).
2. The temperature sensor probe is faulty. This can cause the oven to think it's hotter than it actually is.
3. The above two causes can be easily diagnosed by a technician with an ohm-meter. If they are both OK, then the problem is in the controller itself. If this is the case you may want to have us repair the controller. We see this fault quite often.
Hope this helps you out.
Regards,
Bruce
www.fixyourboard.com
Oct 10, 2009 | Jenn-Air JJW8230D Electric Double Oven
Kenmore Electric range does not maintain temperature setpoint.
How do you know the thermo sensor is working correctly when it gets hot?. No I think the thermal sensor is defective, it is cheap to buy.
May 04, 2017 | Kenmore Ovens
Amana Electric Oven Issue
My oven never reaches the proper temperature sitting for baking. Controls for the oven only is push buttons. How can I adjust this. This has been going on since I have bought the Amana
Oct 27, 2008 | Amana AOCS3040 Electric Single Oven
Viking VGSC366-6B Gas Kitchen Range Logo
304 people viewed this question
Top Viking Kitchen Ranges Experts
Ismael Rodriguez...
Steve Allison
Steve Allison
Paul Carew
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
