Question about Frigidaire FDE336RE Dryer
Frigidaire Dryer overheat
Model FSE346RHS0 dryer that in melting the paint on the back panel. I have removed and tested both thermostats and they check OK. I have cleaned it very good and it still gets toooo hot. Now what next?
  • skeeter41 Aug 22, 2007
    Thanks, I found that thermostat and will replace it even though it seems OK. I foud out something interesting in that if I only put 2 towels in the dryer it cycles but if I put in just one more item or towel it does not cycle off and gets hot. Could this mean something else?
    Novelist:
    Champion:
  • 244 Answers
Some thermostats can test ok they should go to zero when testing but sometimes they can test ok but they are really faulty replace them and it should start to work fine again also some dryers have a 3rd stat which is situated at the very front of the inside of the dryer at the base check to see if it has got the 3rd stat before replacing the other 2stats m8 let me know what you find out but ive had stats test ok before on a few dryers but they still needed replacing have you had this dryer from brand new cause if you havent then someone might of replaced before with the wrong stats they need to be for that certain model to work fine m8
Posted on Aug 21, 2007
  • peter gittos
    peter gittos Aug 22, 2007
    in a dryer u should be able to put about 3/4 towels in and it should dryer within 60mins now u can put in a full load of clothes straight from the washer and it should dry witnin 70/90mins a be bone-dry
SOURCE:
Why is the metal screen with round holes located in my dryer drum melting some clothes and leaving its impression on those clothes. My appliance is a Frigidaire gas dryer model # LAQG7011KBO.
The metal screen is the place where the heat from the dryer enters the drum. If the dryer is melting items, you have one of two possible issues:
  • The dryer thermostats are allowing the dryer to get too hot.
  • You are drying delicate clothes on too high of a heat setting.
Jan 14, 2015 | Frigidaire Dryers
Tip
My Frigidaire Dryer is not heating anymore. Repair and testing for model...
Hi.
The example is referring to Frigidaire electric dryer model FEX831CSO. If you have a different model see here how to locate parts and diagrams: Where do I find parts and diagrams?
First part to test is the thermal fuse located at the back of the appliance. This is tested reading Ohms on fuse contacts. follow procedure explained further below to test the fuse.
If the fuse is not the culprit, it will be neccessary to access heater assembly and thermostats.
You access the heater parts by opening the top panel, part 3 on diagram below.
The heater assembly is part of the housing, and it is part 15 on diagram.
Replacing the heater requires further disassembly, first ensure that the problem is not a defective thermostat or thermal limiter. The thermostats fails far more commonly than the heater.
To test heater and thermostat use a multimeter set at Rx1. disconnect the thermostat contacts and read impedance at room temperature.
If the thermostat is good it will read zero or very low impedance.
An alternative way to test a thermostat is by jumping its contacts.
The element is also tested reading impedance. If the element has no continuity (infinite Ohms), then it must be replaced, otherwise it is good.
Test both the thermostat and the Thermal limiter, they are tested in the same way. Both this parts are accessible after removing the top panel, and can be replaced without further disassembling.
Here the parts:
Thermostat:PS446428 part 33 in diag.
Thermal limiter:PS419402 , part 36 in diag.
Test and repair must be done by a trained person. Call the phone number listed on the user manual if you need to contact a qualified technician.
Regards.
on Apr 09, 2010 | Frigidaire FEX831CS Top Load Stacked...
My frigidaire dryer is not coming on
Hi samantha sis...
Here are a few things to check:
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor/thermal fuse one at a time by removing the two wires and taping them together with electrical tape.
If the coil heats up then replace the thermostat/thermistor/thermal fuse as it is faulty.
If you have an ohm meter then you can test the thermostat/thermistor/thermal fuse,
then you do not have to tape the wires together as described above.
To test your thermostat/thermistor/thermal fuse remove the wires from the thermostat/thermistor/thermal fuse and check for continuity, if you DO NOT have continuity then replace the thermostat/thermistor/thermal fuse.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST AS THIS COULD CAUSE A FIRE BECAUSE YOU HAVE REMOVED THE SAFETY.
Check your blower wheel to make sure it is secure to the shaft and not plugged with lint,socks,etc.
If the thermal fuse overheats the dryer will not operate. It's located on the blower housing. It cannot be reset.
You can test it with an Ohm meter or continuity checker, remove both wires from the thermal fuse and put the test probes to each of the ends of the thermal fuse, if no continuity then replace the thermal fuse.
A vent clogged with lint can cause it to overheat.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace a generic element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
Please take time to rate me thumbs up
Sep 15, 2011 | Frigidaire Dryers
My frigidaire dyer is not getting hot but its still tumbles the model # GLER341AS2
Hi keke1981...
Check your Wiring
Sep 06, 2011 | Frigidaire Electric Dryer
My dryer keeps blowing the thermal limiter fuse or switch,what ever it is called.why?
Hi candwloc..
If the thermal fuse /thermostat overheats the dryer will not operate.
It's located on the blower housing and it cannot be reset.
A vent clogged with lint can cause the dryer to overheat and keep blowing the thermal fuse/thermostat.
You can test it with an Ohm meter or continuity checker, if no continuity, replace it.because it is faulty.
Jul 24, 2011 | Frigidaire FEQ332E Electric Dryer
LE02152ES0 Model Frigidaire dryer problem, not drying or doesn't have heat. I opened and cleaned the vent and tubes. Is that the fuse problem? If so, what kind of fuse am looking for?
Hi tovia246....
Check your Wiring
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape.
If the thermal fuse overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
For video and pictures on how to replace the element go to the following website:
This is a FREE answer, Please take time to rate me
May 20, 2011 | Frigidaire Dryers
My frigidaire dryer LEQ642DS0 will not shut off by itself, would that be the timer or the knob? Also if it is the timer, is the kenmore/frigidaire part #131062300 (timer) compatable with my dryer
Instructions
Things You'll Need:
* Phillips and hex nut screwdrivers
* Replacement thermal fuse
* Replacement thermostat
1. Disconnect the dryer from the electrical outlet.
2. Slide a putty knife between the top panel and front panel on the left side. Slide the knife toward the center of the dryer to release the left-side spring clip. Repeat the process on the right side. Lift the top panel up and rotate toward the back of the dryer. The thermal fuse and thermostat are located along the dryer's back wall, attached to the heating element housing.
3. Disconnect the two wires from the thermal fuse. The thermal fuse is an inch-long rectangular plastic part, located near the top of the heating element housing. Remove the screw holding the thermal fuse in place. Remove the old fuse. Place a new fuse on the housing and replace the screw. Reconnect the wires to the fuse.
4. Remove the wires on the thermostat. The thermostat is a black, oval-shaped part located just below the thermal fuse. Remove the screws holding the thermostat in place and slide it out of its slot on the heating element housing. Slide a new thermostat into the slot and replace the screw. Reconnect the wires.
5. Lower the dryer's top panel and press down until the spring clips lock into place. Plug the dryer back into the electrical outlet.
Feb 24, 2011 | Frigidaire Dryers
Frigidaire crown series gas dryer - heats up and turns, but does not dry clothes. i had someone check the vent and clear it all out - he thinks it is the blower? Can that be fixed?
Try this solution first before checking the blower.
Check your Wiring
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
This is a FREE answer, Please rate me
Dec 07, 2010 | Frigidaire GLER341A Electric Dryer
No heat
Sounds like your problem may be with the heating coil. Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
Sep 26, 2010 | Frigidaire Electric Dryer
Frigidaire dryer is overheating
Sound like the limit switch on the dryer is faulty and needs to be replaced. Hoped this helped
Mar 14, 2009 | Frigidaire Dryers
Dryers Logo
105 people viewed this question
Top Frigidaire Dryers Experts
Marvin
Marvin
John Tripp
John Tripp
Donni Steen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
