Question about Bush 5693D 24" TV
Bush TV 32in
The other day I turned my TV on the colour has gone all funny, there is lots of purple, green and yellow. Please help as this telly is not even 2 years old and don't have th money for a new one just yet. Many Thanks
  • BETH79 Sep 03, 2007
    Many Thanks for your help chrispurs1 was the degause and you were right it didn't cost that much to fix.
  • 372 Answers
Hi. If you leave your tv in standby try switching it off properly at tv switch leave a few hrs then switch on. Have you got hifi speakers or anything that is magnetic near tv if yes move it away from set switch set off wait a few hrs then switch on. Or if the above has not sorted problem the set has a fault with the degause circuit. Its not to bad to repair but you will need to use soldering iron.
Posted on Sep 03, 2007
SOURCE:
Bought new Bush 32in HD ready LED TVs on Saturday. Tried DVD which worked fine on previous TVs but on new TV pictures are all green
Please verify the correct tv source is selected as i think the green screen is the no signal indicator.
If it is the correct source , perhaps the tv is not compatible with the output of the dvd player. It might be wide screen or wrong aspect ratio and gives you a green screen .
If neither of those help, be sure to try another cable.
Feb 13, 2018 | Bush Televison & Video
My TV has a green / purple tint on the corners. Help?
It might be due to picture tube problem... As its too old, the picture tube might be weak and hence you might get colors at the edges.. Better replace the picture tube with a new one to solve this problem
Apr 01, 2012 | Bush Televison & Video
Bush tv picture colour red&purple
Check for any loose soldering points on the video output card [ a circuit baord located at the neck of the pircture tube]. Resolder all the suspected solder points. Green colour out put is absend now with your Tv.
Mar 14, 2012 | Bush Televison & Video
I have a bush rf6685 vpl - 28" screen? - all of a sudden the colour has gone funny ie watching football the grass looks purple.
good day maybe your tv has a defect, or loose connection in the main board, needs to resolder the main board. only the qualified technician can do this job. to fix your problem.
Jun 21, 2010 | Televison & Video
I have a bush colour tv and there is a blue,green,red colour wash right across the picture so people''s faces look half blue,green red....sort of as if there is a rainbow across the screen.. i do not have...
It sounds like your TV may need degausing.
Is your TV situated near to any loudspeakers or other devices with large magnets inside them? Or has anyone been near your TV screen with a magnet???
You need to try to get the screen demagnetised (degaussed). Many TV engineers have a degausing coil that could do this. It only takes around 20 seconds at most.
Some TV's like Mitsubishi have a DG button on the remote, that does this function without the need to call out an engineer! It only needs one press of the button every few years!
Nov 17, 2009 | Televison & Video
Please help, Bush RP40TV
you may have a convergence ic gone could also be a bad joint on one of the chips or a coil dry jointed
Jan 14, 2009 | Bush 5693D 24" TV
Bush lcd 24 inch tv
REPLAXCE THE DEGAUSING P.T.C
Oct 24, 2008 | Bush 5693D 24" TV
Daewoo GB2898ST
the problem is in your degausing coil and its circuit. probably it wont start every time you turn on you TV.
Apr 24, 2008 | Televison & Video
Help,colour is wrong
Hi. The problem is either the degaus positor has failed which is an easy repair. Or have you recently placed hifi speakers or something with a strong magnet in side near your tv set.
Jun 04, 2007 | Bush 5693D 24" TV
My tv is picture is blue and green
Hi there my t.v has a similar problem, I turned it on and the colours arn't right, there the colours go out in three circles mainly mainly blue, green, red yellow, but depends whats showing on the t.v? Please help.
Apr 17, 2007 | Bush 5693D 24" TV
Bush 5693D 24" TV Logo
197 people viewed this question
Top Bush Televison & Video Experts
Joseph Hoffmann
Raj Patel
Are you a Bush Televison and Video Expert? Answer questions, earn points and help others
