posted by TalkJames on Aug 20, 2007
I've just moved into a new flat with a built in Neff dishwasher. Only problem is I can't get it to function at all.
The machine powers up fine but with every indicator light illuminated... Prog End, Salt, Rinse Aid and all four programme buttons are all lit up. From there it will do nothing. I can press a programme button but the machine just emits a buzz and continues to illuminate all lights.
I've tried pressing the reset buttons but this has no effect. Clearly something needs resetting somewhere, but I'm baffled if I can work out how.
Solution #1
posted on Aug 22, 2007
well I never heard of that brand so because you said a new flat Im guessing your form England. Good luck with the move. Ok I belive your problem is possibly the main control bord is bad.what you describe sounds like it. the only way to rest it it would be to replace the bord. doing that it should function normally.
Good luck.
Good luck.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Neff 18 in. S5943 Slim-Line Built-in
Email this problem
Email this problem
Can you Help with these Dishwashers problems?
Neff 18 in. S5943 Slim-Line Built-in...
Hygena Dishwasher
Hygena Dishwasher
My dishwasher does not drain... Answer This...
Enoying Beep
Enoying Beep
We want to run our dishwashers... Answer This...
Dishwasher does not take in...
Timer moves correctly but no... Answer This...
Repair Service
Find Dishwasher Repairman Near You:
