Rancilio Silvia Espresso Machine
Problem for Rancilio Silvia Espresso Machine
No water coming through the pump
By meaganbz on Aug 20, 2007
I've had my rancilio for just a smidge over two years. It's been great. My husband cleaned the machine with the recommended cleaner last week and since then, the machine makes an awful noise when turned on and no water ever makes it through, thus no espresso. The steamer does work, however. Can these machines be sent back for repair or is there something I should check first?
Thanks,
Meaganbz
Same Problem
May 01, 2008
-   I have the same problem. I have had it just over two years. After the last time I cleaned it, (a couple of months ago), it took much longer to make a shot. After cleaning it last night, it doesn't work.
-   Guest
Feb 13, 2008
-   same problem as the others are describing following a cleaning session. pump sounds but no water flow from the group head or steam wand if i try activating the hot water switch. Has the pump died even though i can clearly hear it?Or would you suggest taking a look at the three way valve for a blockage?
Any help would be appreciated
thanks-   romster
Dec 30, 2007
-   I also cleaned my machine recently, had about 10 days of problem-free usage then yesterday I noticed the water was only dribbling through. I first thought an air blockage, so I used a blind plate (one with no holes) that I normally use for cleaning to see if that made a difference. It didn't. I then had the (as it turns out bad) idea to let the reservoir run dry (briefly) then to start water through afresh. Didn't work. I then had the water pump going and opened and closed the steam valve (not using the middle water pump button). Plenty of water and pressure in the steam arm. However, at this point the water flow came to a halt, and then a faint burning smell started to come from my Silvia. Everything switched off now. Another search found this link: http://www.jlhuffordmania.com/forums/view_topic.php?id=24&forum_id=6 which suggests that the cleaning powder may have been left in too long -- I certainly left it in longer this time that usual, maybe half an hour with some flushing during that time. Also, it says I should NEVER let the reservoir run dry. I didn't try the thermostat reset yet, but any help would be appreciated, though I tend to think I just need a new pump.-   demas
Dec 22, 2007
-   I have exactly the same problem. Thought it was because of chalk in the water and I have "de-chalked" it several times, but even shortly after having done so, I experience the problem. I suspect some kind of "air-plug" (??) in the system to be causing the troubles, but it's hard to find a pattern in the way it appears. ANyone with a good advise?-   Jakob Larsen
Nov 19, 2007
-   i have the exact same problem, also after cleaning it with the cleaner provided by a rancilio dealer. my sense is that i left the cleaner in too long and it dryed up and silvia is now clogged in some way. i am far from urban areas and would like to try fixing it myself before shipping it off. any ideas are appreciated!-   sloespresso
Best Solution
posted on May 02, 2008
Very Helpful)
plangley
Rank: Apprentice
Rating: 95%, 4 votes
Ok, We got a solution. We have hard water from a well. We disassembled the 3-way valve and removed the brass valve receiver. The outlet going to the coffee was plugged up solid with gunk (technical term). I used a tiny piece of wire from a wire tie and cleaned out the gunk, then soaked all the brass parts in descaler. The whole effort only took about half an hour. We used a crescent wrench, phillips screwdriver, and a 3mm allen wrench. We found the directions for the process at http://memweb.newsguy.com/~jenkins/silvia/. I think that descaling loosened a bunch of gunk from the tank and it got jammed in the tiiny hole.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Jan 22, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I have had what seemed to be a air bubble in the line on and off for months and finally found a solution that seems to fix the problem when it happens:
Turn the machine on and pump on (bottom switch). Heat machine up. Turn on water switch (middle switch) then open steam valve at the same time. This seems to clear the air bubble and then the water enters the group head like normal.
This problem was occurring almost daily but since I have done the above, it has only happened a couple of times in the last month. Good luck!
Solution #3
posted on Jan 08, 2008
Somewhat Helpful)
JetJedi221
Rank: Master
Rating: 85%, 29 votes
All could be different problems, I will only tackle the first here.
I sound like when he took the group head apart, he put the nozzle block in backwards. This will block the hole that the water comes out. Take the screw out of the group. The nozzle is under the screen. Make sure the gap under the holes is pointing up.
Also, try backflushing a few times.
There may be a service company in your area. Look under resteraunt service.
Was this helpful?
Yes
No
Solution #4
posted on May 29, 2008
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Had the same problem, and on my machine it was the solenoid part of the solenoid valve that was faulty. My Rancilio retailer had this in stock, and changing it was easy. See http://memweb.newsguy.com/~jenkins/silvia/ for details on how to disassemble the Silvia in order to get to the Solenoid. (Note that the article does not cover how to actually change the solenoid. It is easy but if you are in doubt please contact an authorized service center).
Solution #5
Somewhat Helpful)
demas
Rank: Guide
Rating: 74%, 4 votes
In my case, I consulted with the service agent and took the machine in. It wasn't the pump, as that was obviously still working (both audibly and in pumping water from the steam wand). I tried descaling but that didn't help. The likely culprit is the solenoid valve which as I understand it directs water between the group head for espresso and the steam wand for hot water. That certainly explains why in my case there seemed no difference between operating the first or the second button.
Was this helpful?
Yes
No
Solution #6
posted on Feb 15, 2009
Very Helpful)
seabadger
Rank: Apprentice
Rating: 100%, 2 votes
I had exactly the same problem, solved by following the link in plangley's advice above. In my case there was a tiny (2mm) flake of pink paint that had flaked off from inside the hole marked '2' in the brass valve receiver, which was partially blocking the hole. Once the flake was removed, and the whole thing reassembled, Silvia was working like a dream again and my 8am anxiety attack came to an end.
I cleaned my machine with descaler a few months before - perhaps the descaler caused the pink lining paint inside hole 2 to flake off?
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Rancilio Silvia Espresso
Questions and Unsolved Problems for Rancilio Silvia Espresso
Do you recommend Rancilio Silvia Espresso Machine?
Answer
Answer
Can you supply a thermostat for a Rancilio Silvia? the one required is T3 in the wiring diagram, and... (More)
Answer
Hi, last week I purchased the Rancilio Silvia Espresso Machine. For most of this time I have been... (More)
Answer
I have a Rancilio Silvia about 2 years old. About 10 days ago I did a descale and backflush process,... (More)
Answer
bad check valve in rancillio silvia? pressure loss thru group head while steaming
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Rancilio Silvia Espresso...:
Top Coffee and Esp... Experts
Rank: Guru Guru
Solutions: 901
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Coffee and Esp... Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
