Does anyone know the wap/gprs/mms settings for the i9 phone for o2 as o2 say they dont recognize the phone so they cant send me the settings
First you have to make 2 data accounts,
1 for wap,
1 for mms.
Press service,
Data account,
GPRS, ok,
Pick any one of the settings because you are going to change it,
Press edit.
account name edit to O2 WAP GPRS,
APN to payandgo.o2.co.uk,
user name to payandgo,
password is password,
authentication type normal,
after each one if done is the option press it. this is the setting for wap internet.
You have to do the same again to make a new data account for the mms. the settings for this is
account name O2MMS,
APN payandgo.o2.co.uk,
user name payandgo all others same as before.
Now you have 2 new data accounts you need to set up wap.
press service, wap, settings, edit profile, sim 1 or 2 which ever you are using,
select the O2 WAP GPRS account that was made earlier,
press ok. press edit profile,
rename profile is ok it is O2 WAP GPRS,
edit home page to http//wap.o2.co.uk,
set data account to O2 WAP GPRS,
connection type wap, IP address 193,113,200,195
user name payandgo,
press back and activate profile.
you should be able to get on to o2 homepage now.
To get mms
press text, mms, mms settings, server profile, sim which ever you are using 1 or 2 ,
select the O2 MMS made earlier, edit profile, rename profile is 0k should be O2 MMS, home page is http//mmsc.mms.o2.co.uk:8002,
data account is the O2 MMS you made before,
MMS IP address 193,113,200,195
user name payandgo,
select back when all settings are entered and select activate profile. this should be it.
This works OK for me.
Here are the settings for o2
1 for wap,
1 for mms.
Press service,
Data account,
GPRS, ok,
Press edit.
account name O2MMS,
user name payandgo,
To get mms
user name payandgo,
Hi i have sciphone i9+++ and having a hardtime setting up my GPRS in Globe...could somebody help me? whenever I tried to do the other suggested way., error appears GPRS is not subscribed
Find manuals with GPRS and MMS settings for all providers here:
http://chinamanuals.com
Go to samsung website and select pixon phone and get settings sent worked 4 me
Ok gprs settings are differant if you are on a contract so please read
O2 GPRS settings (WAP):
Note: Different settings for contract and PAYG (Pay as you go)
Homepage: http://wap.o2.co.uk/
Access point (contract): wap.o2.co.uk
Access point (PAYG): payandgo.o2.co.uk
Gateway (IP) address : 193.113.200.195
Username : o2wap (contract) / payandgo (PAYG)
Password: password
Session type: Continuous / permanent
Authentication: Normal
Security: Off
Port number: 8080
same again with the mms settings
Access point name: wap.o2.co.uk (contract customers) or payandgo.o2.co.uk (pay-as-you-go customers)
Username: o2wap (contract customers) or payandgo (pay-as-you-go customers)
Password: password
Data bearer: GPRS
Gateway IP (proxy) address: 193.113.200.195
Session mode: Permanent
Port number: 8080 or 9201
URL address: http://mmsc.mms.o2.co.uk:8002
Hope this helps
Call o2 back up again and this time ask them for the settings for the Nokia 2610 phone as these settings work on the i9.
Solution you give for i9 still can't work
i cant open my mms because it says GPRS not subscribed what can I do to fix this problem
i am also looking can you please email me at [email protected] when you find out please and i will send you if i find
i have the same problem please meial me a solution
i have put in tha I9 settings that was given to me and still my phn want work
tried all the above where it says o2.co.uk, do i put the comma? daft question i know
