Question about Philips 55PP9401 55" Rear Projection Television
DOWN HILL??? There is a problem with the picture running down hill (as I call it) If I watch a movie that is widescreen the space below the movie is much smaller on the right than it is on the left. I was told that the yolks need to be turned. Is that true? and if so how hard is that to do?
  • imauncfan Aug 28, 2007
    Thanks for the help. I will get someone to look at it.
    Genius:
  • 1,153 Answers
It only true is its like one color that is twisted. Remember there is 3 tubes in a projo. Red, Blue, Green. So if a yolk needs turning and the color is not badly out of wack then that makes it that all colors are out and it is hardly likely that all three are turned the very same way(misconscrewed) So this maybe an internal matter. In service menu there maybe a way to align the convergence or crosshatch of all three colors or maybe a resistor that has changed in value. Either way you need someone familiar with the set to work on it.
Posted on Aug 25, 2007
I have a 2014 CTS. When traveling downhill with cruise control engaged, the car will downshift 2 or 3 gears causing the rpm to run up over 4000. Is this normal operation for these cars?
This is normal if you are going up hill but if you go down hill there should be very little work for the engine and transmission to do.
Going up hill as the engine starts to pull it is normal to kick into a lower gear to give the car more pulling power. If it does it in the down hill mode you should get it checked like low fluid or something.
Jan 30, 2015 | Cars & Trucks
Engine stalls at 50mph or when low on fuel
when low on fuel and the you drive and you turn car , side gravity forces force the fuel from the pump sock pickup sock and the fuel pump stalls, read the op. guide it tells you not do that.
the pump is fuel cooled, an fuel lubricated and starving it is a bad ACT.
so say what is going on at 50mph, going up or down a hill with 1/8th tank of fuel?
my jeep stalls in fast turns at 1/4 full (1991) slosh effect.
i slow down and bingo, it runs. did so new, and so did others..
gravity (and inertia) are our friends, but not always.
see space movie called Gravity. friend and foe.
Nov 17, 2013 | Honda Passport Cars & Trucks
Brand new less than 30min on tractor when mowing down hill white smoke bellows out the exaust I imediatly shut mower down and am parinoid about restarting for fear of damaging motor.
how steep of a hill was it?steep enough for oil to go forward into the from of the engine roll it to a flat surface and check the oil level if ok run the engine and let it burn off if the hill ii's that steep then stop using it on the hill check the manual for running angles
Jul 10, 2012 | Craftsman GT 5000 26 HP54" Garden Tractor...
I just bought a new Panasonic TX-P46S2 46"plasma
Try some adjustments. Brite changes the level of bright and Picture changes contrast. Less contrast and less brightness to even things out may help, and you won't be driving the panel so hard, so It's life will be longer too.
Nov 25, 2010 | Panasonic Televison & Video
Loosing power especially on hills
There could be a dozen causes. Get a tune up.
Oct 25, 2009 | 2001 Volvo V70
Picture is only in middle of screen, top and bottom of screen is blacked out
If you are watching widescreen format movie or tv programming on a non-widescreen tv, that is how it will appear. The widescreen is a wider picture so to show it on a less wide screen, it has to shrink down to fit. and leave blank space top and botton.
If not, sorry.
Sep 12, 2009 | Toshiba 36A40 36" TV
Getting 301 and 307 codes
CYLINDER #1 & #7 MISFIRE DETECTED.
May 12, 2009 | 1998 Dodge Ram 1500 4WD
DOWN HILL
Do NOT make any factory mechanical adjustments! Geometric alignment done electronically in the servicer mode needed.Senior tech skill level only.
Aug 20, 2007 | Philips 55PW9363 55" Rear Projection...
Easy question!
When your camera is in picture mode, press func. set, then go down to where you will see either the letter S that is in a little hill type icon, or a white hill icon, or a white staricase looking icon. 1 setting is super fine, the other is fine, and the other is normal. If you choose normal, it will give you more memory to store and your pictures won't be as good as if they were in superfine mode, which takes more space.
Mar 06, 2007 | Canon PowerShot SD630 Digital ELPH / IXUS...
Philips 55PP9401 55" Rear Projection Television Logo
42 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
