Question about Nikon D50 Digital Camera with 18-55mm Lens
Nikon d50 lens problem
My Nikon D50 18-55mm lens (stock--came with camera body) is not responding to the camera. I get a blinking F-- symbol on the screen which shows in the manual that the lens is not attached (it clearly is). When I switch to my Quantaray 55-200mm lens, I do not have any problems. Anyone else experiencing a similar problem? Any suggestions?
  • 3 more comments
  • tanks mom Aug 21, 2007
    I have put my other lens on the camera and it works fine...are you referring to the pins on the lens or the camera?
  • tanks mom Aug 22, 2007
    I will check it out...thanks!
  • tanks mom Aug 23, 2007
    I checked the pins on the lens and do not see anything wrong...I am going to have to take it in for repair. thanks!
  • Anonymous Dec 26, 2007
    i have receive a f--- mesage on screen, my nikon d50 do not work properly.
  • ianhaziel Jan 05, 2008
    I have receive a f--- error in my camera, i had removed the lens, check the pins and re-fit the lens again, the problem continue, any suggestions?
    Genius:
  • 2,985 Answers
This suggests one the contacts on the ens is not quite doing the business obviously. Are they of the spring load pin type? work around them see if one or more is not fully 'out' or make sure the lens is fully locked home when fixed in
Posted on Aug 21, 2007
  • john ash
    john ash Aug 21, 2007
    where ever the pins happen to be
    I dont know the actual camera system
    but the Lens's have contact points and the Camera body has matching ones
    Pins on one pads on the other.
    I am suggesting whichever one or more pins is out of contact with its appropriate contact pad
  • john ash
    john ash Aug 22, 2007
    From waht you intimated -Original lens showing error 3rd party lens OK- The body must the OK and original lens the suspect one.
My Nikon D50 isn't taking any photos. Its been
Turn the aperture ring on the lens to its smallest setting (largest f/number). You can control the aperture from the camera body the same was as with a lens without an aperture ring.
Feb 20, 2013 | Cameras
Using Nikon d50 camera, I turn it on and blinking in display is FE E. It goes away but when I push button to take picture same blinking FE E shows up and won't take picture.
Turn the aperture ring on the lens to its smallest setting (largest f/number). You can control the aperture from the camera body, the same was as with a lens without an aperture ring.
Aug 21, 2010 | Nikon AF 70-300mm f/4-5.6 ED Nikkor Lens
I dropped my Nikon d50 and now when I turn it on it flashes fEE. Whats wrong?
The lens is not making proper contact with the camera. Try removing the lens, cleaning the contacts on both the back of the lens and in the lens mount on the body, then reattaching the lens. If that doesn't do it, try jiggling the lens gently. If that doesn't do it, try attaching a different lens if you have one available, or attaching the lens to a different body if that is possible. If nothing works then it could be that the lens and/or camera needs servicing after the drop.
Apr 25, 2010 | Nikon D50 Digital Camera
Nikon D50 with Nikon DX 18-55 lens will not focus
Sorry to hear about your lens. If you are able to autofocus and take pictures with any other lens, then it means that your problem lies with the kit lens. If you can take picture in manual mode, but not in autofocus mode, then the AF motor in the lens in not functioning. I had the same thing happen to my 50mm 1.4 lens.
Depending on your location, there are Nikon repair centers in Melville, NY and Torrance, CA.
Hope this helps,
Andrew
Apr 16, 2010 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
Nikon 28-80mm lens will not auto focus, D50 body works okay.
Try cleaning the contacts on the camera body with alcohol and a cotton swab. You could also look at the contacts on the lens, but normally the ones on the camera are the issue.
Aug 27, 2009 | Nikon D50 Digital Camera with 28-80mm Lens
NIKON D50 CODE FEE
"F-EE" indicates that the camera cannot take automatic control of the lens' diapraghm. To resolve this, turn the aperture ring on the lens (the one nearest the camera body) to the largest number (probably 22 or 32).
Nov 19, 2008 | Nikon (8320) (13-30x50 mm)
Nikon D50 Set Problem - Won't Take Pictures
The F-- error means that the lens is not communicating or has lost communication, with the body. I would first try cleaning the contacts on the lens and body. You might also try another lens. This problem has been known to develop when using a heavier, large lens. It seems like you have had the unit for a number of years. Has this always been an issue?
Hope that helps,
-WN
Aug 31, 2008 | Nikon D50 Digital Camera
Nikon D50 blinking "Err" message
Make sure the lens is mounted fully (give it a little twist to see if the error clears). Also, check the gold contacts inside the body, where the body touches the gold "points" on the lens, to make sure they are clean. A pencil eraser is a good cleaning device for these contacts. I hope this solves it for you.
May 31, 2008 | Nikon D50 Digital Camera with 18-55mm Lens
FE E (flashing) r12 Error
Hey redfoxbrenda,
The error message you are getting means the aperture ring is not locked to the smallest aperture setting, and by this I don't mean set to the smallest aperture the lens must have the ability to be locked to the smallest aperture. It is unlikely that the problem is in the camera body. Some older lenses are just not fully compatible with the newer camera bodies, but if this is the case you should still be able to use the lens in manual and aperture priority mode but with limited capabilities. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
May 23, 2008 | Nikon D50 Digital Camera with 18-55mm Lens
Nikon D50 Lens won't work
I have a D50 as well but never experienced this problem. One thing to check as you already mentioned are the metal connections between the lens and the camera body. Make sure they're clean and shiny. Another thing to try would be switching between AF and MF modes on the lens itself.
Jul 02, 2007 | Nikon D50 Digital Camera with 18-55mm Lens
Nikon D50 Digital Camera with 18-55mm Lens Logo
176 people viewed this question
Top Nikon Cameras Experts
Ric Donato
pictureman4u
Geoff Hone
Are you a Nikon Camera Expert? Answer questions, earn points and help others
