Back to:
Tags:
Emerson EWF2704 TV
EMERSON-MODEL#VT911OA-W VERSION-C
posted by YANKEES115 on Aug 20, 2007
POWER BUTTON; USED TO HAVE TO PRESS POWER BUTTON SEVERAL TIMES TO GET T.V. TO COME ON SOMETIMES UP TO 20 TIMES. NOW, WONT EVEN COME ON AT ALL. FUSE STILL GOOD. IS IT WORTH FIXING? DO I NEED NEW PANEL BOARD? THANKS,YANKEES115 S/N# 654-51224104
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Aug 22, 2007
Helpful (85)
MikeNJ1964
Rank:Guru Guru
Rating: 89%, 633 votes
If the set will not turn on with the power button on the front of the set, you must then try turning it on with the remote. You must be sure that the remote is working correctly. If the set turns on with the remote, then your power button itself is bad or has cracked loose. This is easily fixed without having to replace the board. If the set does not turn on with a working remote, then something inside the set has failed and it should be serviced by a qualified tech.
Rating Locked! (?) YANKEES115 has rated this solution as Helpful
Thank You!
Was the solution helpful?
Show your appreciation by commenting on EMERSON-MODEL#VT911OA-W VERSION-C:
I don't want to Accept this solution
Can you Help with these Standard Televisions problems?
Emerson EWF2704 TV
Everything is plugged in. However, when i press power the...
Emerson EWF2704 TV
there is a line of light across the center of the...
Emerson EWF2704 TV
we had a storm and after the power surge will not turn on
Emerson EWF2704 TV
Must use two remotes to watch TV. There are no codes to...
Emerson EWF2704 TV
has little shine on the screen as it should, more than 2...
Loading problems.
Repair Service
Find Standard TV Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Home Media Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
