When start up the knocking noise starts, acceleration it knocks faster? Oil is good? Sounds like its coming from the engine? Very rough start up and idling ?
SOURCE: Engine knock
The idle issue is normal. The idle is controlled by the ECU. There are no adjustments for the idle. Regarding the knocking noise, that could be several things, and I am hesitant to comment without hearing it. Take it to a Toyota Dealer & have a tech listen to it. We are very good at identifying noises on the service drive.
SOURCE: ENGINE KNOCK 81 GMC 1500 (350)
IN 1981 GM MADE SOME SOFT CAMS,ALOT OF PEOPLE WERE COMPLAINING OF THIS CAM & LIFTER REPLACEMANT SOLVES THE PROMBLEM.AS FOR THE KNOCKING TAKE IT TO A PRO.
SOURCE: '99 Forester with a knocking noise at idle and acceleration
sounds like you have a headgasket blown, a head, or your rocker arms or lifters whatever you prefer to call them are running dry. might be time for oil change and coolant flush. If ther is no overheating or coolant smell than get your injectors checked. You might just have a broken seal that emits louder sound from the pulsating injectors. Good Luck!
SOURCE: I HAVE 02 TRAILBLAZER LTZ, AND IT JUST STARTED
Hello, I see you have a trailblaber with a knocking noise. It sounds like you have an electric fan clutch issue. Believe it or not your vehicle has an electric fan clutch. It looks just like the older non-electric but if you look on the driver side of the fan shroud that is the wire connector you see. It is an exspensive part just for the clutch but thats exactly what you are describing. It doesn't get louder just fast with rpms. Please rate my answer, Thank you
