Question about Nespresso C190 Espresso Machine
Krups Nespresso FNA2 coffe/cappucino machine
Hi - this machine can make espresso or cappusino coffees - as such there are 2 buttons (1 small cup and 1 large cup on the right handside to choose whether you are making an espresso or cappucino coffee. The difference is that the nespresso button delivers less water than the cappucino button for example. The problem is that when I pres the button indicating I want to make an espresso, the water does not stop flowing. So, it seems that whatever triggers the machine to measure the amount of awater needed doesn't work.
  • 5 more comments
  • fna2 Aug 21, 2007
    Hi and thank you for your help - running the vinegar/water solution through it woked right away - I ran several large and small cups to clean it, left it overnight as you said and used it again this morning after running plain water through to remove any vinegar taste...
  • Anonymous Mar 16, 2014
    Rancilio espresso coffee machine hot water push-button switch
  • Anonymous Mar 18, 2014
    The chrome arm on my machine will not open , also no water is passing through to the cup
  • Anonymous Mar 19, 2014
    I own Krupps Nespresso XN2005. Have descaling solution but as no descaling button to select do I just use as if brewing coffee and add to water in chamber. repeating process.
  • Anonymous Mar 20, 2014
    only a small amount of coffee in the cup . Water is leaking right side middle top of the machine inside.
  • Anonymous Mar 22, 2014
    Gaggia
  • Anonymous Mar 24, 2014
    i started the machine and it was blinking lights only for espresso shots. but not milk coffee. infact ive put the milk container in it, but still no success..
  • 944 Answers
First thing to try is a descale. Run the machine normally using it (as if making a cup of both types) a couple of times with a 50/50 mix of white vinegar and water. Leave the machine off but uncleaned overnight. run a couple of cycles with just water, and if there is still a slight vinegar taste then run a cycle with a teaspoon of baking soda in water, then flush with just water again. If this doesn't solve the problem, try again with 75% vinegar. If still not working, there is either a control board problem (may be solveable), or the valve/solenoid that stops/allows the water is sticking, almost certainly solveable by taking that apart and cleaning/lubricating. Definitely solveable by replacement. Let me know what you get after a descale if no luck. Hope this helps :)
Posted on Aug 20, 2007
  • Nigel Ridehalgh
    Nigel Ridehalgh Aug 21, 2007
    Enjoy :)
    Depending how hard your water supply is, it is usually worth doing every 3-6 months or so even if you have no problems. It makes the coffe taste better too.
  • Cees Mutsaers Aug 31, 2013
    how do you descale the FNA2 ???
Nespresso machien is leaking water into the drip tray
Posted on Jan 16, 2008
Hello, i have a krups xp7220 and i have two problems with her.
A common place for a leak under the machine is the barista seal that goes in the bottom of the boiler around that eject rod. Barista seal part number is MS5002202, Seals on the tamping piston are MS5002040 (there can be 1 or 2 of these piston seals) If fixing the leaks does not fix error 6 then I expect it will end up being the distributor. Part number MS2A01500
Jun 17, 2017 | Krups Coffee Makers & Espresso Machines
Coffee side beeps 3 times and does not brew. Espresso side and frother are fine
KRUPS XP2280 Espresso Machine and Coffee Maker ...
www.amazon.com/KRUPS-Espresso-Combination.../B...
Amazon.com, Inc.KRUPS XP2280 Espresso Machine and Coffee Maker Combination with ... Theespresso side is literally idxxt proof with the built in tamper system and ... Theespresso does not brew after waiting for the light to turn solid and simply pushing 1 or two cup selection. I often have to push 3 or more times and it still doesn't work.Missing: beeps
KRUPS XP2280 Espresso Machine and Coffee ... - Amazon
uedata.amazon.com > ... > Espresso Machine & Coffeemaker Combos
Krups is pleased to present our new XP2280 Combi Espresso and Coffee ... Theespresso side is literally idxxt proof with the built in tamper system and ... Theespresso does not brew after waiting for the light to turn solid and simply pushing 1 or two cup selection. I often have to push 3 or more times and it still doesn't work.Missing: beeps
Troubleshooting Semi Automatic Espresso Machines
www.espressoplanet.com > Articles > Support > Troubleshooting
Oct 24, 2010 - We do not encourage anyone to open up the machines and try to repair them and if you ... (The water will be moving through the holes between the coffeegrounds ... The portafilter doesn't stay in place in the group head while brewing. ....Jura, Solis, Saeco, Krups, Capresso, Gaggia, Rancillio, Nespresso.Missing: xp2280 ‎side ‎times
Jan 28, 2016 | Krups XP2280 Combi Espresso & Coffee...
Krups FNA2 doesn't draw water!
If it sounds like a pumping noise but louder then it may mean that the pump is bone dry and needs to be primed. You need to find an imaginative way to force water into the socket that the tank engages with. A clear hose of the correct size with water already in it and then press the button and blow into the other end of the pipe. Once the valves are immersed in water it should start to function.
Dec 18, 2013 | Krups Coffee Makers & Espresso Machines
When you press the button for a large cup of espresso (Nespresso Essenza) only small amount comes out
You can adjust the fill of coffee by holding the large coffee cup down for as long as you want to fill it. Try holding the button down for 20secs., next cup of coffee should automatically fill for 20 seconds. The small cup that you are currently getting was probably set at the factory. Good luck
Nov 19, 2009 | Nespresso Essenza C100 Espresso...
It wont brew drip coffee
What are the simptoms? Once you pour the water and add the coffee it should start when you press the coffee button.
Jun 02, 2009 | Krups XP2070 10 cup Coffee Maker/15 bar...
Water leakage inside
Use less water....
Apr 29, 2009 | Krups Nespresso 554
No function when i pushe smalle or big cup
Dear,
My wive bought a new nesspresso machine.
I will keep my old machine for repair parts for my mother, she has simullar machine.
greetings
Dec 26, 2008 | Krups Nespresso 554
Too little coffee
reset to factory default...
1. Power switch off
2. Press & hold coffee cup button while powering back ON
Mar 22, 2008 | Nespresso Essenza C100 Espresso...
Nespresso C190 Espresso Machine Logo
2,887 people viewed this question
Top Nespresso Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Kolbrun...
Jay Finke
Jay Finke
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
