Question about Smeg FAB32 Bottom Freezer Refrigerator
Freezer not working
The fridge is working ok. when the freezer is switched on, the compressor (the one without the water tray above it - assume is freezer compressor ?) is very hot to touch (it's still warm now having turned the freezer off over 2 hours ago). there is no clicking noise coming from the compressor. is this a compressor or a thermostat problem ? appx how much should it cost to get a new compressor fitted ? thanks !
  • kimhound Aug 21, 2007
    hi - the problem is that the freezer is not working at all. i don't think there is a fan.
  • avnjdw Oct 31, 2008
    i have exactly the same problem, freezer packed up - everything has defrosted, the condenser at the back is too hot to touch when freezer is switched on however no chill in the compartment.
    Fridge is still running fine.
    Product is only 2 years old!!
    Any further info on what is the problem/cost??
    Thanks
    Jack
  • 183 Answers
The compressor does run warm but not hot, if the freezer is not cooling then the comp is faulty, approach local repair agent for cost. Regards The Advisor Smeg Agent
Posted on Aug 21, 2007
  • 291 Answers
I not sure there is a problem... the compressor does get quite hot... Is there is a cooling fan and is it running.. some will have cooling tubes on back of the firdge without a cooling fan.. but. what is the problem.. you think compressor is getting too Hot?
Igloo mini fridges
The question is: Are you seeing water inside the fridge where it shouldn't be? Are there water stains in the try? Some of these have no tube, the water just drips from a small hole above the tray.
Jan 05, 2018 | Igloo FR834A Stainless Steel 3.2 Cu Ft...
Maytag fridge works but freezer doesn't
Try the control relay/ condenser thats attached to the compressor and provides a momentary spike to start the compressor start windings prior to the unit going into run mode. reasonable and easy to fix
Apr 04, 2014 | Maytag Refrigerators
Freezer compressor is short cycling
Red light on for High Freezer Temperature Warning
or freezer not cooling, but fridge is and a lot of noise from compressor.
Also, fridge drain hole blocked, water in bottom of fridge.
This is a common fault in Hotpoint Fridge Freezers and can also happen if the door has been left open or has been a power cut.
1. Turn off fridge freezer, or at least turn down the freezer temp to minimum, though not ideal.
2. Open freezer door and remove all drawers.
3. Remove the back panel on the inside of the freezer. This is held in place with 4 screws, which might be 6mm hex head or star allen head. Pull the panel out.
4. Behind where the panel was, there is a cooling element for cooling, pipes, and below this a temperature sensor. If the fridge freezer is not switched off, then fold together a few layers of tinfoil and wrap around the sensor.
5. Use a hairdryer to slowly melt the ice. Melt it around areas where it appears to be hanging on, such as the corners of the cooling element or bolts, as well as any thin sections below the main block of ice around the cooling element, which will be supporting the main block. Use a plastic ice scraper to remove ice but not near pipes or sensor.
Warning: Be careful using electrics around water & melting ice & drips.
6. Below the cooling element, there is a drip channel & drain hole. If this hole is full of ice, pour a small amound of warm water down, leave for 10 seconds and pour a bit more until clear.
In the fridge, clear the drain hole in the same way.
Warning: Do not pour a lot of water down, as this water drains onto a tray above the hot compressor at the rear of the fridge freezer to be evaporated by the heat of the compressor and the tray will only hold a small amount.
7. When all ice is removed, dry all moisture. Put the shelves back. Close door. Turn on fridge freezer. Turn up the freezer temperature to your normal setting. Turn on fast freeze if available. After 1 hour, check with a thermometer. It should be cold enough after 1 or 2 hours.
Sep 06, 2013 | Electrolux Refrigerators
Our Zanussi Fridge freezer ZK87/46ef temp alarm sounding with red light on, the fridge temp is ok however the freezer is not cooling and the food is defrosting slightly,any suggestions please ?
hi.defrost unit completely first 24/48 hours. or until there is water on drip tray above compressor.then turn it on .if it works it means your evaporator is freeing up.if it is the same it could be lack off refrigerant.good luck.ali
Jun 14, 2012 | Refrigerators
Beko CDA751FW/1 mostly on all the time - fridge 4 degC, freezer -30degC
there is no thermostat in cda751fw/1. apparently the pcb controls fridge temperature. which pcb, the main one or the one behind the temp dial I dont know which.
Apr 11, 2012 | Refrigerators
I have a sharp fridge SJ-P49N-SL. A recent power outtage in the area lasted 8 hours. When the power came back on, the fridge seemed to be ok. But, after 5-6 hours of operation, the freezer is not cold...
Checked Freezer Fan is working. Also checked defrost Fuse in freezer.
To checked freezer fan is working or not open freezer door press Door Switch and checked Cold air is coming from duct or not.
Aug 10, 2011 | Sharp Refrigerators
FRIDGE OK FREEZER NOTWORKING RED WARNING LIGHT ON
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 03, 2010 | Hotpoint RFA60 Bottom Freezer Refrigerator
Black tray above compressor is filling up with water on a RLA50
hi there.the tube your speaking about comes from the rear of the fridge down to the plactic tray on top of the compressor...and is used for conveying condensed water from the fridge to the dri tray where it is evaporated by the running heat of the comressor....excessive water can be caused by a faulty fridge door seal....door not closing correctly...and the possibility that your fridge setting is to low....or sited close to a working radiator
regards Sir Galahad
Aug 12, 2009 | Hotpoint RLA50 Refrigerator
Water is dripping from the freezer into the fridge from above. Ice has formed under sliding freezer tray.( Whirlpool 21- Model# ET21DKXDN04 )
Sounds like the water produced from defrost cycle is the problem. There is a tube designed to carry the water to the compressor compartment where it evaporates. you will need to onclog the tube by taking the back off freezer compartment to access .Under the condensor is a tray that collects the water. There you should see the hole that needs to be blown out. Compressed air works great. Hope this helps.
Jul 28, 2009 | Refrigerators
ARISTON FRIDGE FREEZER MBA 3842C PROBLEM
It should work the same as before. Does the compressor get really hot after running a while? If so it could be low on charge, or there could be a restriction inside the refrigeration system. Either way a professional would have to look at it.
Jan 07, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
Smeg FAB32 Bottom Freezer Refrigerator Logo
1,324 people viewed this question
Top Smeg Refrigerators Experts
Mike
Jay Finke
Jay Finke
 Mikey
Mikey
Are you a Smeg Refrigerator Expert? Answer questions, earn points and help others
