Question about Acer AC713 17" CRT Monitor
Monitor problem Hi... I have problems on my monior... I will try to express this to my best Whenver I switch on my monitor the monior menu items such as brighness, conrast etc.. reduce automatically and the menu window exists and things are changing automatically. It can't be controlled by te monitor buttons. Day by day the frequency increased and now it's on peak. Why it is like this and How can I solve this problems? Expecting the exact solution. Thank you
  • rsriram78 Nov 12, 2007
    Even my monitors brighness and contrast automoatically adjusts and goes to zero and finally blank. Iam not able to set it right. Let me know the solution.
It was corrected long before by a repairman nearby... problems is there was a crack in the board inside... it was corrected. It's OK now.
Posted on Mar 16, 2008
  • 151 Answers
It is the problem of command section.Check menu button for shorting.if it is ok then check command ic or component related ith it.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Posted on Mar 13, 2008
SOURCE:
Monior comes on and says "No Signal". Can't
MAKE SURE THE POWER IS OFF AND CHECK ALL YOUR CONNECTIONS IF YOU CAN LOOK INSIDE THE UNIT TO SEE IF THE VIDEO CARD IS ALL THE WAY IN.I WOULD TRY ANOTHER MONITOR FIRST.THAT'S WHY I'M GLAD TO HAVE MORE THAN ONE PC IN THE HOUSE LOL
Oct 10, 2011 | E-Machines eMachines Desktop PC
What is the best tracking software
Hi Daone770,
If you are referring to a monitoring software, i suggest Blackbox Monitoring software by ASM. I have been using this software for more than 2 years and I have been very satisfied with the ease of use and its excellent monioring capabilities. Another awesome thing about it is that they offer a free download for the Home version (Blackbox Security Express ) Here is the link: http://www.asmsoftware.com/Products.aspx
All the best to you.
Jul 22, 2011 | HP Computers & Internet
Lg crt monior display cable wire circuit diagram
Pin Signal 1 Red Video 2 Green Video 3 Blue Video 4 Monitor ID - Bit 2 5 Ground 6 Red Ground 7 Green Ground 8 Blue Ground 9 [KEY] 10 Sync Ground 11 Monitor ID - Bit 1 12 Monitor ID - Bit 0 13 Horizontal Sync 14 Vertical Sync 15 N/C (Reserved)
Feb 11, 2010 | Computers & Internet
My monotor its all black but u can
This should be an (LCD) screen. They are the ones that usually have this kind of problem. You will need to take it to have it checked if the problem is the VGA signal cable leading to the monitor. They will check if it is properly connected or has gone bad. It is very unlikely that the screen is bad. When this VGA signal cable goes bad it could result in a totally blank screen.
Sep 13, 2009 | Dell Computers & Internet
I have a yellow vertical central line just appeared on my Dell monitor. Does anyone have a solution?
In diagnosing most computer Problems, especially if its with Monitors or other plug ins its best done by process of elimination.
First try replacing Monitor with one you know works OR plugging monior into another Computer that works.
If you still get the line in the first case with a known good monitor then its most likely the Video Card in the Computer. First Try Going to "SYSTEM" /Device Manager and see if the "Video Driver" is Still there, Try downloading it again in either case from the Dell Website.
IF that does not work then
If Monitor has same problem in "Good" computer check Cable and Change if you have a spare. If still has problem it is a defective Monitor and at that point it does not pay to repair.
In the first case if Both Monitors do not work properly then Replace the Video Card; that is most likely the problem.
Hail Mary: If Monitor does not work in the "good computer" there is an off chance that the cable is defective or they adjustments are off. Try resetting the Monitor Controls to DAFAULT ..
If you cant use another computer or Monitor your best bet is to replace the Video Card; its most likely the problem; suggest you do so with a superior card so if you still have the problem and decide to replace the Monitor you'll at least have a better Video Card *shrug* :)
Aug 20, 2009 | Dell OptiPlex 740 PC Desktop
Studioworks 880lc
Dear Friend
Your LCD Monior haveing Panel Problum if you want to change you panel it will cost aprox 5,500/-
Ashok
9322133048
Jan 20, 2008 | LG 880LC Monitor
Acer AC713 17" CRT Monitor Logo
161 people viewed this question
Ekse
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
