Question about BenQ CRW 4012A (99.B9712.036) CD-RW Burner
Phillips dvd rw 16x double capacity series
Hello, none of my media burners were able to find my philips dvd rw and my computer labelled it as a cd writer. I seached my computer for a solution with no luck so i decided to unistall it. The prblem is i have no idea how to reinstall it, please sa y that you can help
    Sergeant:
  • 457 Answers
What did you uninstall if you meant the drivers then thats all you do. Rollback to the last driver. You say media burners are having a problem reading your Phillips dvd rw. Does Windows read it does windows see the drive? if it does the problem lies with the media burners though I cant quite fathom what you mean "Media Burners" are talking about Media Player 11 Nero 7 and so on ifn so this is a software problem not a hardware. Normally software is remedied like a product with drivers to run it. Hardware ahs firmware to make the hardware go.
Posted on Sep 01, 2007
SOURCE:
I lost power cord. Do you know which one should get? where?
Try in radioshack and take with you the DVD RW also in CompUsa
Jan 12, 2011 | Philips Phillips 16X External DVD 2XRW...
My NEC DVD RW -3500AG will record using 8X DVD- R but not 16X can you advise
Dear friend please see your DVD top side, is there mention that DVD able to record 16X speed ? If not then you can't record that on 16X speed. Thanks.
Jan 29, 2010 | NEC ND3500 16X Double Layer DVD RW ND-3500...
I have a LG GE20 DVD Rewriter Is a DVD+RW disc a format that is editable and suitable for this unit?
The LG G20 DVD Rewriter is an advanced external burner that supports 'editable' Rewritable DVD+RW disk.
As a generic comment, not all writable/rewritable media are made equal and problem with branded & unbranded disks are not uncommon, so stick to brands that work for you for your specific unit!
The following is the advertised support for your unit, hope it helps:
Reading Rate DVD-R/-RW/-ROM 16x/13x/16x/16xSL/12xDL max. DVD-RAM 2x, 3x-5x, 6x-12x DVD-Video (CSS) 4,8x max. (Single/Dual Layer) DVD+R/+RW 16x/13x max./ 12xDL max. CD-R/RW/ROM 48x/40x/48x max. CD-DA (DAE) 40x max. Burning Speed DVD-R 2x, 4x CLV, 8xZCLV, 16x PCAV, 20X CAV DVD-RW 1x, 2x, 4x, 6x CLV DVD-RAM 2x, 3x ZCLV, 3x - 5x PCAV, 12x PCAV DVD+R 2.4x, 4x, 8x, 12x, 16x PCAV, 20X CAV DVD+R Double Layer 2.4x, 4x, 10x, 12x ZCLV DVD-R Dual Layer 2x, 4x, 6x CLV, 10x, 12x ZCLV DVD+RW 2.4x, 4x, 6x, 8x ZCLV CD-R 4x, 8x CLV, 16x, 24x, 32x, 40x, 48x ZCLV CD-RW 4x, 8x, 10x CLV, 16x CLV, 24x, 32x ZCLV
Dec 28, 2009 | Computers & Internet
I installed a philips-lite on blue ray player and need the drivers for it.
Hi friend,
You are not requried any drivers for it. it will work with out drivers...
Dec 20, 2009 | Philips LITE-ON 20x DVD RW Drive -...
COMPUTER NOT READING IT, NOT BEING RECOGNIZED BY COMPUTER
Turn your computer off, and unplug the AC power.
Open up your computer, and unplug the "data" and "power" cables from the DVD-drive, and then reconnect them. Check that the "other" end of the "data" cable is firmly attached to the motherboard.
Reconnect the power, and restart the computer.
Press DEL to enter BIOS-setup mode.
Is the DVD-drive still not detected?
If it is not detected, it probably is electronically "dead", and needs to be replaced.
Nov 05, 2009 | Philips LITE-ON 20x DVD RW Drive -...
My dvd writer became dvd rom only, now I am unable to wirte the cd and dvd by using my dvd wirter which I bough 3 months back
in these case your dvd writer became dvd rom due to optical lens problem. some other case dvd can read only cd or became cd rom also due to optical lens problem. change the optical lens or adjust trimmer for laser.
Jun 10, 2009 | Philips LITE-ON 20x DVD RW Drive -...
Lost code
The radio will have to be removed from the car dashboard .
Then please  ALL the LETTERS and NUMBERS on any LABELS , BARCODES or STAMPED IN THE METAL CASING.
Apr 23, 2009 | Philips Phillips 16X External DVD 2XRW...
Pc died
Hello, I have had similar problems with that same motherboard in the past and have found that resetting the cmos (see users manual) or just taking the battery of the motherboard for a few minutes can solve this. CAUTION please remove the power lead on your tower before touching any components inside, and earth yourself first by touching metal.. as static discharge kills pc components..
Hope this helps.....
Tony.
Sep 09, 2008 | ASUS K8N4-E Deluxe Motherboard
Dvd writer for toshiba satellite pro
HP dvd1040i 20x Super Multiformat DVD Writer
Price: $69.99
  Internal drive (double layer)
 Write speed: 8x double layer, 20x DVD±R, 48x CD-R
Rewrite speed: 8x DVD+RW, 6x DVD+RW, 32x CD-RW
Read speed: 16x DVD-ROM; 48x CD-ROM
Lightscribe disc-labeling technology
one-year limited warranty....
HP dvd1040e 20x Super Multi DVD Writer
External drive (double layer)
  • •   Write speed: 8x double layer, 20x DVD±R, 48x CD-R
  • •   Rewrite speed: 8x DVD+RW, 6x DVD+RW, 32x CD-RW
  • •   Read speed: 16x DVD-ROM; 48x CD-ROM
  • Lightscribe disc-labeling technology
    Price: 109.99
    These are the best DVD writers....
    Lightscribe technology is where you can burn your pictures on the disc as a label..... This is Hp's latest technology
    Oct 22, 2007 | Computers & Internet
    NEC-3520A Suddenly stop to burn correctly, but reads OK
    Have you tried lowering the burn/erase speed? To begin, simply do what you need to do on the lowest speed, and then keep increasing until it gives the error again. This will most likely work. I had this problem and I burn now CDs at 16x.
    Jun 11, 2007 | NEC (ND-3520A-KIT-BLU) Burner
    BenQ CRW 4012A (99.B9712.036) CD-RW Burner Logo
    553 people viewed this question
    Top BenQ Computers & Internet Experts
    Steve Allison
    Steve Allison
    Tommmix
    Level 1 Expert
    Joaquim Martins
    Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
