Grinding noise right after starting when car is either in Park or in Neutral. NO noise while on Drive or Reverse; car moves forward or backward ok. Noise some time is on, most time is off.
There are many things to cause this problem. torque converter is most likely expected if its 3.0 v6. notorious for these problems. If you don't know where it is located, it is behind the transmission. you will have to drop it and it is a cylinder. another issue that could cause rough vibration is bad motor mounts.
SOURCE: 1997 ford explorer rolls/creeps forward while in park
linkage is off, not starting in park, neutral safety switch maybe bad
SOURCE: awd 97 ford explorer grinding noise going forward
I ran into this problem, and discovered that i had a faulty front shaft speed sensor. The grinding I had was that the transfer case clutch packs were trying to lock up and engage the front wheel drive. Replacesment of the sensor has not fully rectified the situation though, as it still does it intermittently. It seems to do it at low speed turns and on acceleration. Not sure if this is your problem or not, but it could be. A scan of the computer can tell you if it is the issue though.
SOURCE: my 1998 ford explorer makes a loud noise (like an
i would say your transfer case is on its way out. but it is hard to say that is a lot of info to take in but ya i say tranfer case is toste
SOURCE: I have a 1966 Falcon that has a C4 transmission issue no reverse
Readjust the band, I have ran into this same problem with another C-4.Found the reverse spool valve was sticking in the valve body. Hopes this helps.
SOURCE: My 1999 ford explorer will not go into park;all other gears work
DIsconnext and reconnect the linkage at the transmission. You may want top replace the linkage cable all together. Make sure you set the parking break and block the tires
