Question about Canon PowerShot SD550 / IXUS 750 Digital Camera
Error 18 in right bottom corner
I have e18 and i want to now the solution
  • 31 Answers
"e18" is a lens error, the lens is stuck and would not come out, camera displays error and shuts off. replace the lens assembly and it will fix the problem
Posted on Aug 21, 2007
6ya staff
SOURCE:
What does E18 mean on the screen of my camera?
E18 is a lens error. You might try this repair technique:
Canon E18 Error
Jun 04, 2015 | Canon PowerShot A20 Digital Camera
Error code 18
checked the fusing unit then perform menu,*,45
Nov 19, 2013 | Muratec MFX-2830 Black and White Copier
The camera was dropped by my son, which happened before, when turned on the canon logo shows then the screen is black. An error message in the bottome left says E1b or E18. Help!! thanks
Here is some information on the E18 error: http://www.e18error.com
A repair guide (suggestions) http://www.e18error.com/repair.html
Forum for users with the same problem http://www.e18error.com/posts/index.php
May 21, 2009 | Canon Cameras
E 18 message
Lens errors (E18 errors on Canons) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 04, 2009 | Canon PowerShot A75 Digital Camera
I have a powershot A85. Lens wont retract. Camera cuts off after about 10 seconds. Bottom left corner reads e18 just before it turns off.
this is a popular error due to dust or sand in lens assembly
search google for e18 solutions will flood
Oct 21, 2008 | Cameras
E 18 problem
broken lens on Powershot SD600
Feb 17, 2008 | Cameras
E 18 problem
the E18 means the lens system has a problem. I had it with my S2 and sometimes it worked, sometimes not. Eventually it stopped working. The only solution was sending it to repair, they changed the lens system.
Best Regards
Nov 19, 2007 | Canon PowerShot S2 IS Digital Camera
IXUS II
error code e18 means that the focus motor gears a jammed, dirt or grain of sand in them. you can try to fix it by gently banging the camera on somthing soft, their are also instructions on web on how to disasemble and fix this fault. BUT unless you have some skills, the right tools and conditions i would not attempt it. leave it to the experts
Sep 23, 2007 | Canon PowerShot SD100 / IXUS II Digital...
Screen is showing E18
The E18 error message relates to a problem with the zooming mechanism (lens would not retract or extended) Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix you problem. In any case it could not make it worse Good luck!
Aug 10, 2007 | Canon PowerShot A520 Digital Camera
SD200 E18 Error
E18 is the error that comes when when the lens is stuck, so if the lens is stuck out, turn off the camera, carefully turn the lens until you hear a small clicking noise, then turn it on. I had the exact same problem, and that fixed it for me
Jun 23, 2007 | Canon PowerShot S400 / IXUS 400 Digital...
Canon PowerShot SD550 / IXUS 750 Digital Camera Logo
141 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
