Question about Motorola Mobility H500 Wireless Headset
Motorola H500 Wireless Headset Pairing Problem
Motorola H500 Wireless Headset and paired with N70. I didn't charged it fully. I did half an hour. But while i turned on the bluetooth it was a steady blue. I did as per the instruction. I [paired it and my phone says pairing was successful. Even the Steady blue changed to blink flash in my headset as per the instruction manual. but while testing i couldnot hear any voice or attend call. Could any one provide solution!!!
If you turned it on and it was steady blue most likely you held the call button too long. The steady blue means it's ready to pair with a phone. Try repairing again and if you still don't hear anything, play with the volume buttons to the top and buttom of the headset the volume may be down. If that doesn't help I don't know what will.
Posted on Sep 21, 2007
SOURCE:
Pairing motorola h500
Pairing mode is what is shown in the picture. The headset has a steady blue light and is ready to be paired with another device.
Mark
Motorola Support
Jun 08, 2014 | Motorola Mobility H500 Wireless Headset
I have charged the blue tooth but I do not know how to turn it on to pair it with my phone
Well, try to press the Call button: it is the button that has got telephone drawed. Hold it until you see the blue light steadily lit. That means that you just turned on and putted the headset into pairing mode. Now find Motorola H500 over your mobile phone. You will need to put a pass, and it is by default (i think, on ALL Motorola Headsets): 0000. You're ready for using!
Dec 18, 2010 | Motorola Mobility Universal Bluetooth...
The default code is not working for my motorola blue toot h500
here is the manual for the headset
http://www.starbatteries.com/moh5blheowma.html
half way down the page click on "View the product manual..." and open it.
Motorola states that the pairing code is "0000" and can not be changed.
make sure it is fully charged before pairing.
hope it works.
Jun 17, 2010 | Motorola Mobility H500 Wireless Headset
How to conect Motorola H500 Bluetooth Headset to Iphone
Be sure the the headset in in 'Pairing' mode.
When in pairing mode, the light should be flashing red and blue or have a steady blue.
The put most headsets in pairing mode, turn headset OFF, then hold the power button until it goes into pairing mode as discribed above.
Then you can discover it with your phone or PC. Pin (pass key) should be 0000 (4 Zeros) or try 1111, 1234, 9999
Nov 09, 2009 | Motorola Mobility Bluetooth Hands Free...
Pairing with iPhone
Real easy go to the iphone and settings go to bluetooth and it will said in discovery mode.
then go through the pairing of your headset sontrols and the iPhone will say enter password then enter 0000 or whatever your H500 manual says.
If you have already paired the H500 with another phone you need to reset that. this is also covered in the manual which can be found online at motorola.com
Jul 10, 2009 | Motorola Mobility H500 Wireless Headset
I want to pair the motorola H500 to my blackberry pearl. i cannot get the bluetooth in pairing mode?
-Be sure the headset is fully charged.(plug it in till the light turns off.)
-Hold the talk button down for 4 seconds or until the blue light goes solid (not blinking.)
Now the device should be ready to pair with your Blackberry. It usually only stays in pairing mode for a short while (approximately 90seconds)
Jun 30, 2009 | Motorola Mobility H500 Wireless Headset
HOW TO PAIR MY MOTOROLA H500 TO SAMSUNG CELL PHONE?
If you have lost the pairing on your phone with the headset follow these simple steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the phone
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The phone should search for any available Bluetooth devices and display what was found
5) Select the Motorola device and click add
6) You will be required to enter in a pass code which is standard ‘0000’.
7) If successful then the headset will start flashing BLUE every few seconds.
8) If it’s a Samsung or Nokia phone you will need to “AUTHORIZE” headset on the device.
• The headset is now paired with the phone
Hope this helps
Chris (ziraffa)
Dec 26, 2008 | Motorola Mobility Bluetooth Hands Free...
How to pair my Motorola H500 headset with my HTC Touch
i have a pre paid phone from net 10..the phone is a motorola..how do i get my head set pairing mode and get my phone to detect it..i have no pin for the ear peice ..
Aug 02, 2008 | Motorola Mobility H500 Wireless Headset
H500 won't pair with Blackberry Curve
It might already have been figured out but if you hold the answer button on the headset down until the light stays on steady, it is in pairing mode. You can then go to bluetooth setup on the Curve and it will find the headset.
Nov 08, 2007 | Motorola Mobility H500 Wireless Headset
Motorola Mobility H500 Wireless Headset Logo
290 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis Webber
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
