Question about Epson Aculaser C1100 Printer
Epson C9100 I need the code to reset the fuser section! the fuser has been replaced, but the prinetr does not recognise this...do i need a code???
  • DaveyJ Aug 20, 2007
    Thanks for the reply....how ever there is not an 'alt key ' on this model of printer!
    Thanks any way!
  • Epson Master
  • 705 Answers
Press and hold the four directional buttons as you turn on the power. Keep them held until the panel shows MAINTENANCE MODE. From here you will see the menu entry to reset the fuser counter
Posted on Oct 13, 2007
    Brigadier General:
  • 6,966 Answers
Hi, On another model Epson Aculaser C2000, I was able to reset the fuser oil roll by doing a RESET ALL, which of course set the printer back to default values. In my model the reset all command is activated by pressing RESET + ALT together for at least 5 seconds or until the LCD display shows "Reset All". Am not sure if it will work for your model and I leave it to you to give it a try. Good luck and kind regards.
Posted on Aug 20, 2007
Fs1020 has aproblem code e0001
A E0001is a fuser error code. You may have had a power surge and the copier got confussed and coded out. You will need to reset the error code in service mode. If it can not be cleared, you may have a problem with the fuser unit
Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For
Epson Printer Support
Jun 14, 2014 | Epson Expression XP-305 Inkjet...
C 3821
Hi geosegr,
Can you confirm the code is C-3821.
Because it's not one that I recognise.
There are only two C-38xx codes, they are C-3851 and C-3852.
Both of these codes relate to the fusing section.
If it were me, I'd have a look in the fuser area to make sure there is no paper stuck. Then you'll need to reset the code. To do this,
Turn OFF the Main Power Switch.
Turn Main Power Switch ON while pressing the Utility/Counter key.
Touch [Trouble Reset].
Check to make sure that [OK] is displayed and the it has been reset.
After turning off the Main Power Switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
If the fault code reappears, you'll need to get an engineer to look at it.
Hope this helps
Jan 28, 2010 | Konica Minolta bizhub C250 All-In-One...
Is it possible for me to replace the fuser unit in my 2400W laster printer myself?
yes open the prinetr carry fully
find the fuser unit & replace the older once.
reconncet the printer
then start your work
ok bye
Nov 09, 2009 | Konica Minolta magicolor 2400 Laser...
RESET TONER C9100
The waste toner cartridge has a transparent extrusion on the bottom, which fills with toner when the cartridge is full, but also if it is half full and shaken so that toner falls into this extrusion. If this happens, the only way to remove the toner is to open the cartridge by removing the tape, taking the two halves apart and shaking/blowing/hoovering it empty. You can stick them together again with ordinary sellotape.
Jun 17, 2009 | Epson Aculaser C1100 Printer
When turned on, displays a E537 error code. Solution?
error 537 is a failed fuser. You will need to replace it before you can use the unit. cost of a fuser is about $450 retail.
Gremlin11
Nov 12, 2008 | Epson ACULASER CX11NF All-In-One Printer
Epson aculaser c9100 error code Eo86
After a repair person came and worked on the Epson Aculaser CX11NF, I have vertical line, full lenght across every printed page
Oct 08, 2008 | Epson AcuLaser C1900 Printer
Canon super g3 image class d880
E000 means your fuser section is having problems.sometimes you can reset but may need to replace fuser unit.
Sep 04, 2008 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
S9000 or R2400
i would go with the Epson AcuLaser C9100 series very fast
hope this helps
Aug 27, 2008 | Epson Stylus Photo R2400 InkJet Printer
MF8180C error code
DID SIMPLY REPLACING THE FUSER UNIT SOLVE THE PROBLEM?
Sep 29, 2007 | Canon imageCLASS MF8180C All-In-One Laser...
Epson Aculaser C1100 Printer Logo
814 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
