Question about Samsung SyncMaster 753S 17" CRT Monitor
Colors my monitor colors appear in yellow/green ,some times the original colors return for a minute
  • 31 Answers
I too have same problem.
can somebody teach how to open this monitor.
i unscrewed the screws attached to back of the front panel
but still i was not able to open the monitor for repair
pls guide me if u have knowledge in opening a monitor for service
Posted on May 14, 2008
    Brigadier General:
  • 6,966 Answers
Hi, This sounds like a color driver problem with the RED. I will assume that the blue is good since yellow will only be present if the green and blue are both ok. Below is a copy of my response to a similar post at http://www.fixya.com/support/t181021-zenith_a25a11d_no_red_color "...If you are comfortable working with a soldering iron, a continuity (VOM) multi tester and a fair knowledge of electronic components, then perhaps you can repair the missing color red. You have to open the unit, expose the small printed circuit board that is attached to the small end of the picture tube. There will be many components present but you will need to focus yourself on three (3) transistors that are bigger than the others sometimes with an aluminum heatsink. It is also possible that instead of 3 transistors you will have one power IC. In any case these control and provide the drive for the 3 colors of your picture tube: red, green and blue. One of them is either dead or suffers from cold solder to any or all of its pins/legs. You have to visually inspect the solder joints of these big transistors/IC and determine if any is dull in color, loose of simply not connected. You may even try the shotgun approach and solder each of the pins/terminals/legs just as long as you don't cross solder creating a short between pins/legs. If this works, you're set, if not: You have to check with the use of the VOM and determine which of the 3 transistor is defective. If you are familiar checking continuity of base to collector to emitter and reverse, again you're set, if not perhaps you check all three and compare which have the same reading from the same position and which is different. Pls keep in mind the transistors have forward and reverse bias readings. If able to determine defective component, desolder, replace and solder. If it were an IC, replace the entire pack. If the above would make you uncomfortable, pls ask for the services of a qualified TV repair man and explain your problem..." Hope this give too an idea. Good luck and pls post again how things are or if you need further information. Kind regards.
Posted on Aug 20, 2007
SOURCE:
Monitor color settings not being maintained
Sorry to hear you're having this issue, Josh. To clarify, you can get the proper colors if you set them manually, correct? If so, that rules out the possibility of a screen issue or a problem with the video card. I hope for your sake this is a new monitor for you (or at least one that would still be covered under warranty), for it sounds like it's a logic issue in the monitor itself that prevents saving of the proper settings as well as the distortion of the presets. I would return it if possible for a replacement/refund, as they seem to be a quality product...it just looks like you got a defective one. Sorry I couldn't be of more help to you, but good luck! :)
Nov 07, 2013 | Sony SDM-HS73 17" Flat Panel LCD Monitor
Why do i have a green screen after i turn the screen adjustment screw?
since every display color monitors are only work with 3 primary color which are red, blue and yellow. You could also search it that by mixing these colors, you could get any color your want. Thats how color monitors work. Now in case of green color, it creates by mixing blue and yellow. When you are turning the screen adjustment screw, the red color plug will become lose, makes it appear green.
I hope your got the reason.
Jul 10, 2012 | Sony FD Trinitron WEGA KV-34HS420 34" TV
How do I slide the green toner tabs?
1. power down the printer.
2. remove all color cartridges from their slots.
3. inside the color slot, you will see a green slide that will not move until you pick up the plastic cover (it is the full length of the cartridge holder).
4. rotate the plastic cover forward.
5. slide the green slide 3 or 4 times. (DO NOT TOUCH SMALL WIRES!)
6. return slide to original position.
7. snap the plastic cover back in place
8. return each color cartridge to it's slot.
9. replace color cartridge holder back to printer.
10. close all covers
11. turn printer back on.
If you still get the "move green slide" error, just repeat these steps
This took me about 10 minutes for the process, after understanding what the "green slide" meant.
Apr 20, 2011 | Brother HL-4040CN Laser Printer
Drum error. slide green tab in each color
3. inside the color slot, you will see a green slide that will not move until you pick up the plastic cover.
Oct 04, 2010 | Brother HL4040CN Laser Printer
Monitor colors not displaying any red only blue/yellow
update the latest driver for your video card might help.
Mar 19, 2009 | Gateway FPD1760 Monitor
Color problem MAG Innovision 14" monitor
1. try to connect to another computer . if it is fairly good then it must be your computer is having a problem.may be your video card problem.
Mar 21, 2008 | Mag Innovision lt456s 14" Flat Panel LCD...
Dell AS501 flat screen monitor
The front panel switches seem to be the culprit.
If you are technically sound you maybe able to solve problem by opening monitor and clean front panel switches or replace them.
Samir.
Feb 28, 2008 | Dell E173FP 17" LCD Flat Panel Monitor
Green backgroud instead of black
sounds like your monitor cable is either bad or has a bent or missing pin on the connector.
Oct 25, 2007 | Acer AL1916W 19" LCD Monitor
Samsung SyncMaster 753S 17" CRT Monitor Logo
195 people viewed this question
Top Samsung Computers & Internet Experts
Ekse
asber
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
