Technical Support, Instructions, & Repair Service
Ask our Experts
Ask
Find a Solution
Most Common Problems for:
Canon 400D CF pin broken, power down
poltaq on Aug 20, 2007
I got 2 pins of CF slot has been broken.
Tried change battery to 2 fully charged with now the whole camera not functioning.
I try to bring it to Canon Authorized Service, they need to replace the whole camera motherboard with the new one.
almost US$250
Decided to take repair by myself, hope internet community can help..
Then I opened the camera to find if any fuse has been burned, located fuses with E, P, K mark, test it but look okay (still connected).
They i suspect an IC with burnt looking
(not sure), lately clean the surface, read the mark "G2" probably Toshiba TC7SET08FU.
but cant find the replacement in the market.
Anybody have idea for my situation?
Comments:
Aug 20, 2007
- power supply board. burnt-looking IC marked
Sponsored Links
I have a similar problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Mar 23, 2008
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
where is this board?
thks
Solution #2
posted on Feb 18, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
3 pins broken, in the slot where we insrt the memory card. Am willing to risk opening it. Any one with a step-by-step help. Someone who has done this earlier.
Solution #3
posted on Dec 23, 2007
Not Rated)
markevans
Rank: Wiz  Canon ExpertCanon Expert
Rating: 80%, 131 votes
250 is a bargain if you value your time at anything over $10.00 per.
and canon will guarantee the results.
but...good luck
mark
Was this helpful?
Yes
No
Related Problems
I have an older model Canon EOS Digital Rebel. The LCD...
My Microsoft vista doesn't seem to pick up my Canon EOS...
I have taken some pictures without my memory card in the...
My Canon XTI does not let me change aperture any more. No...
Can you Help with these Digital Camera problems?
no power, tried 3 different...
Solve
no power, tried 3 different batteries, canon rebel xti? help.
dark viewfinder
Solve
when i look through my viewfinder, everything is dark. and yes, the lens cap is off.
Err99 and busy flash
Solve
Camera works fine if flash is not needed. Try to use the flash right away get few strobe flashes and... (More)
my canon rebel xti will not turn on.
Solve
my canon rebel xti will not turn on. I have replaced all the batteries, and still nothing starts up.... (More)
Sponsored Links
Describe your Cameras problem:
Top Digital Camera Experts
Rank: Guru Guru
Solutions: 2826
Experience: I have yrs of experience dealing with many situations.
Ask Me
Find more Digital Camera Experts
Top Cameras & Camcorder Repair
(952) 236-7243
Worldwide AFFORDABLE digital camera repair &...
Darntoothysam.com
(717) 397-3019
We clean and repair all makes and model of film...
Perfect Image
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
