Question about Zanussi FS1455W Front Load Washer
Need factory codes for zanussi fs1555w
My zanussi fs1555w wont start.after pressing start,door locks then end light flashes...ive been told i need to reset power board with factory codes but i dont know them...can u help please?
  • smokiejoe03 Jan 19, 2008
    machine clicks and after a few minutes starts flashing end ,,,,,
  • bbonn May 17, 2009
    Fuse blew on Zanussi FS1555w . Replaced fuse bur now 'end' light continually flashes and machine will not start
5 Suggested Answers
SOURCE: Zanussi FX1465W aquacycle, beeps 5 times and end light flashes
I have the same trouble with my washing machine did you find a solution i have been told the PCB or motor drive system
Posted on Jun 16, 2007
  • 96 Answers
SOURCE: Zanussi ZWF1437W washing machine - wont start
The error message "Err" usually indicates that the wash program and option are not compatible. 40 degrees and 900 rpm Spin should be o.k.. I would try another wash program with no special options and see if the problem goes away.
Posted on Mar 07, 2008
  • 236 Answers
SOURCE: Door not locking and program reverting straight to end
initially i would replaced the door interlock then if no result the control boart could be faulty.
Posted on Mar 13, 2009
SOURCE: can anyone help ive got a zanussi FJDR 1466 W. e91
I had the E90 problem about a year or so ago. Havng had a problem with my Zanussi dishwasher a common fault with zanussi white goods is that they don't solder major joints on the control boards very well. (Probably tryng to economise of the amount of solder they use)
Check all the connections on the control board are tight and haven't burnt off the solder. This worked for me and we haven't had this code since.
Posted on Dec 11, 2009
Zanussi washing machine fs1255w green end light flashes 5 times what is this error code
Press START/PAUSE and any one of the option buttons
simultaneously for at least two seconds: the LEDs first switch off,
and then display the flashing sequence corresponding to the
alarm condition.
Examples:
Alarm E43 (problems with the door safety interlock triac) will be displayed as follows:
• four flashes of the END OF CYCLE LED indicate the first digit E43;
• three flashes of the START/PAUSE LED indicate the second digit E43;
So, error code E55 as you specified does not exist. Any how, family error code 5 (first digit) means problem with motor. Error code could be E51,E52,E53 and E54.
Possible causes:
- faulty motor
- motor brushes (very often)
- faulty tachometer (integrated in the motor but is replaceable)
- faulty electronic (Motor power triac short-circuited or motor relay contacts sticking).
Dado
Jan 18, 2015 | Zanussi Washing Machines
Why will my zanussi FS1555 not start it only beeps at me???
Might be a problem with the door latch which is either not shutting properly or the door switch which could be open.
Look at item 7 in this diagram.
Zanussi FS1555W 91479119100 Washing Machine Spare Parts Diagram
Sep 02, 2014 | Washing Machines
Hi I have a zanussi fs1055 door won't lock . I have replace the door lock but still won't lock . The end light just flashes and noting more !! I held the start button and the delay start button to try
I had a similar problem and found this thread helpful:
http://www.fixya.com/support/t652698-machine_start_clicks_turned_door_open
It turned out that the machine needed to "finish" the cycle it thought it was in
Dec 06, 2012 | Washing Machines
Zanussi washing machine is making five beeps and not workign - what does this mean? It is not in the manual
My Zanussi Fs1555w is not finishing it's cycle and beeping 7 times. If I put on spin the cycle lasts less than a minute before the end button beeps, then it will beep repetitively 7 times until turned off. Please help
Feb 05, 2010 | Zanussi FS1455W Front Load Washer
E 20 ERROR ZANUSSI JET SYSTEM
E20 is a general error code to get to the real problem try this..
Reading Error Codes 1. Wake the washer by pressing any button. 2. Wait 5 seconds. 3. Press and hold the START/PAUSE and CANCEL buttons simultaneously. As long as the buttons are held, the failure code will appear in the display as an “E” followed by two numbers, a number and a letter or two letters. The control will beep and the Door Lock, Wash, Rinse, and Final Spin indicator lights will flash. let me know what code come up... hope it helps
Sep 07, 2009 | Zanussi FJS1225W Front Load Washer
Zanussi zwf1430s error codes - E40 / E41 & ELE
hi
ele means the pcb is in factory settings . all you need to do is turn back off the on again then will be back to normal use. but e41 usally means the door lock has failed. does it click alot when you start it up and not do anything? if so this will be the lock
regards
Mar 19, 2009 | Zanussi ZWF1430W Front Load Washer
Mar 13, 2009 | Zanussi ZWF1430W Front Load Washer
Fjs1225w machine wont start
If its not the door interlock then the only other possible thing is the control module has failed ....
it does happen on zanussi machine.. is it making a cliicking noise the door interlock.... when you press start .... like click click....
if so then most likely its the control board inside the machine
Jan 20, 2008 | Zanussi FJS1225W Front Load Washer
Starts and then ends after about 1 min without doing anything
wire off the circulating pump or faulty door switch if you gis a bell on 01132570737 we can go through it with u we do a lot of work with zanussi washers and are willing to help
Jul 17, 2007 | Zanussi FS1255S Front Load Washer
Zanussi FS1455W Front Load Washer Logo
281 people viewed this question
Top Zanussi Washing Machines Experts
jimorris77
shaun taylor
Marvin
Marvin
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
