Question about Zanussi FJS1225W Front Load Washer
Long time to dry
My zanussi progress 1200 washer/dryer is taking a long time to dry my clothes all other operation are working fine please help
  • Anonymous Mar 21, 2014
    Turn on but it won,t dry the clothes
  • 183 Answers
Check drain filter on front of machine and check machine is doing full spin. Regards Advisor
Posted on Aug 30, 2007
SOURCE:
It is taking far too long to dry, this has only recently started? what could be the problem?
Does it get hot? If it does, then the problem is reduced air flow, caused by a lint filter that hasn't been cleaned, masses of fluff in the exhaust pipe (usually on bends), or the external vent not opening properly. Birds can also nest in the vent pipe if the vent isn't protected or is broken.
If it doesn't get hot, you need a new element. Some dryers have two elements if the dryer has a high and low setting. just one element can fail.
Jan 20, 2016 | Zanussi TC7102W Electric Dryer
I have a GE washer/dryer Model WSM2700RAWWH stack type and the dryer is taking very long time to dry the clothes. Please advise if it can be fixed. If not what will be best alternate washer/dryer stack...
first things first. if any dryer regardless of brand takes 2-3 hours to dry cloths 90% of the time it is your exhaust duct. take the exhaust duct off the back of the dryer and dry some clothes if the clothes dry fast then you need to have your exhaust duct cleaned. either DIY or call a professional
if it still takes a long time to dry then it could be the thermostats or the thermistor.
but in my experience its normally the exhaust duct.
Feb 10, 2011 | GE Washing Machines
Haier washer/dryer combo not drying clothes
Check things like the Filter / clear fluff...Make sure outlet hose if any is not kinked and passing air..Hope this helps..
Oct 02, 2009 | Haier 14.3 lb. Washer/Dryer Combo
Zanussin tc7103w not drying clothes
The belt can be replaced as follows.
1 remove top and front of dryer shell
2 belt goes around drum around motor pully then under tentioner wheel
3 replace front and top of dryer
(top pops off use a slotted screw driver)
Thanx for using Fixya Please take your time to rate me
Jun 17, 2009 | Zanussi TC7114W Electric Dryer
Hotpoint 1200 aquarius washer dryer
take top and back off. locate the dryer duct which comes from half way down and goes across the top of the machine via the fan. blockages in duct are common especially the plastic part of the duct
Oct 16, 2008 | Hotpoint Ultima WD72 Front Load...
Extremely low drum heat but setting is on HIGH.
Electric (Kenmore - 60931) dryer takes forever (several cycles) lately to dry clothes set on high heat (actual heat in tub feels low though). There are no obstructions in the venting and the 240 volt connection is fine. The timer rotates the dial (timer motor working). Help!!!
Sep 15, 2008 | Zanussi TC7102W Electric Dryer
Washer dryer is no longer drying
two things to check take rear half of cabinet off and check the dryer duct (lhs from front) is not blocked. this is very common check water is being taken in during dry - the water is used to condense steam from the drying clothes. easiest way to check this is to see that some water is being drained during the drying cycle. i assume that drain is operating ok
Jun 03, 2007 | Zanussi ZWD1270 Front Load Washer / Dryer
Manual
have got the washer/dryer, and no instructions on how to use , please help get my cloths clean and dry. thanks
Jan 24, 2007 | Zanussi ZJD1219 Front Load Washer / Dryer
Zanussi jetsystem Turbodry 1200
It appears that you may have a faulty door interlock or a faulty PCB. pcb is not really a DIY job as some boards require proramming on certain versions. Regards Advisor
Oct 30, 2006 | Zanussi FJS1225W Front Load Washer
Zanussi FJS1225W Front Load Washer Logo
284 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Marvin
Marvin
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
