Question about Pyle PLA2180 Car Audio Amplifier
Protect mode I had just installed the amp and it was doing well for two days, but after that the amp's power indicator will just light for a second but it will switch to protect mode after that. I followed all installation specs.
    Scholar:
  • 98 Answers
The only thing to try would be to remove the sub wires form the amp and see if it still goes into protect. If it still goes into protect with the subs unhooked then the amp will require repair.. If it doesent go into protect then check to see if you have a shorted subwoofer. also make very sure that you have a good clean bare metal tight ground connection to the body of your car. People forget that step all the time.. Did you do your setup with the correct ohm load? Most of these amps will fail if the subs are hooked up incorrectly(too low of a ohm load). If the amp has a lowest possible ohm load rating of 4 ohms... but you have a pair of 4 ohm subs.. you hook them up togther at the amp.. both positives togther- two negatives togther.. because it "bumps harder" that way.. Then you now have a 2 ohm load on the amp... The lower the ohm load you put on a amplifier the more it will output. The problem when people do this is that the amp outputs more current then its internal parts are rated for and the output transistors (usually) fail.. most amps will not fail if installed correctly.
Posted on Aug 21, 2007
SOURCE:
My thermal light on my 1000/1 amp comes on too often
This means your amp is in "protect mode" this light indicates that your amp is having a short circuit or loose of power.
Check your cables, if they are secured & no exposed wire And most important of all, check your voltage reading, it must be above 12v.
Loosing voltage in car audio is the number1 factor of heat/thermal problem & fire.
When an amp looses voltage, heat builds up inside it. Too much heat will make the amp be on "protect mode", excessive voltage drop will cause the amp's circuit board & other parts to be burned.
So, always watch your Voltage, either with a plug-in volt-meter or with a fuse holder & voltmeter.
Hope this helps.
Apr 08, 2011 | Jl Audio 500/1 Car Audio Amplifier
I hooked up 2 capacitors into my amp and every time I put power to it the amp shuts off and 10 seconds later a red light comes on for 5 seconds and the amp don't turn on, basically it goes into protect...
Well, I have no idea why you would have two capacitors on a 500 watt amp but, did you charge the capacitors? Have you tried the amp without the capacitors? What size power wire are you using?
Sep 20, 2010 | Kenwood KAC-9102D Car Audio Amplifier
JBL amp, worked fine untill 2 days ago. protection light on..
might have roasted your speakers voice coils a little which may be sending the amp into protect mode throw a speaker on it that you know works and if it doesnt trigger the protect circuit then you probably have a blown or almost sub.
Jan 02, 2010 | JBL BP1200.1 Car Audio Amplifier
AMp does not display any LED read out
Amps have a part inside that is made to keep the channels equal. The problem is that when there is nothing hooked up to the second channel, then this goes bad and goes into protect. It is really hard on an amp to use just one channel.
Sep 26, 2009 | Bob Mackie Mackie M-1400i Power Amplifier...
Light
The red light indicates that your amplifier is in protect mode. Amps go into this mode if there is something wrong with the setup of the system to prevent fatal damage to the amplifier circuitry. This is bad thing since the amplifier will not function until the problem is solve and it can remove itself from protection mode.
Amplifiers can go into protect mode for many reasons but one of the most common is incorrect mounting. Is your amp sitting on the metal of your vehicle? Is it bolted down and screwed into the metal of the vehicle or your seat? The amp should never be touching any sort of metal. Only the ground should touching the metal of your vehicle.
Speaking of grounds, many people often neglect proper grounding which can cause an amp to go into protect mode. Do you have a solid ground? Is the wire less than 3 feet long and directly connected to a non-painted metal part of your vehicle? Is the ground wire the same gauge as your power wire?
These are just a few reasons why an amp can go into protect mode. You can find more information here. Or simply google for why your amp is in protect mode.
Aug 06, 2009 | MTX Thunder 81000D Car Audio Amplifier
Thumping speakers - no power light is on - wired correctly
the amp is going into protect mode due to something wrong in the amp or some thing in the wiring to it ooh yea if you are getting 18v power to the amp that is way to high it should not be higher then 15v if the amp is in protect mode it will not play at all.
Nov 02, 2008 | Visonik Dual Bass Box with Amplifier Car...
Protect led light
It appears that the amp is going into protect mode. To eliminate external causes, read through the following page. Let me know if you have any other questions.
Amp in Protect Mode - Troubleshooting
Oct 10, 2008 | Car Audio & Video
My "Power Acoustik OV2-420" has a problem. Some advice please!!!
It appears that the output transistors have failed. To eliminate other possible causes, read through the following page. Let me know if you have any other questions.
Oct 04, 2008 | Power Acoustik GOTHIC OV2-1200 Car Audio...
Subwoofer amplifier
This could cause from different issues.
1. Check if there's any voltage leading from your ignition to the remote cable on the AMP. If you have voltage on the ignition check the fuse that connect inseries on the remote cable.
If the fuse ok you might have other problem in the Audio Output stage.
Good luck.
Dec 13, 2007 | Jensen A600HLX Car Audio Amplifier
Protect Mode
Is it doing this while you have it turned right up? Most systems have protect mode because you are trying to draw to much power or amps through them. Are you trying to run to many or to large of a speaker through them all systems have rate output if you try to exceed this they go into protect mode so you don't blow the amp.
Dec 10, 2007 | Onkyo TX-DS676 Receiver
Pyle PLA2180 Car Audio Amplifier Logo
187 people viewed this question
Top Pyle Car Audio & Video Experts
Mike Duncan
Mike Duncan
xxxxxx xxx
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
