if you found this functional problem SC542 then first of all you clear the all mode to press the clear mode button after this with in 30 second dail 107 from keypad after this press and hold the clear/stop button then it will show other thing you just press exit 2 time now shutdown the main power and again on it will ok now...
Was this helpful?
Yes
No
Popular Solutions for Ricoh Aficio 2022 All-In-One
Everything I print from my Brother HL-5240 printer comes out with both sides of the paper/check...
(More)
Everything I print from my Brother HL-5240 printer comes out with both sides of the paper/check curled up.
Copier will normal copy fine but jams when duplexing. Paper does not re-enter machine from duplexer,...
(More)
Copier will normal copy fine but jams when duplexing. Paper does not re-enter machine from duplexer, it goes under the paper slot. Seems to be warped from heat. I need a part number of that unit above the fuser that handles the paper.
