Question about Sony DHR-1000 DVHS VCR
DHR- 1000 I HAVE USING DHR 1000 FOR OVER A YEAR NOW, BUT YESTERDAY I PLAYED DVCAM CASSETE WHICH WORKED FINE BUT AFTER I CHANGED ANOTHER CASSETE IT WOULDN'T REWIND,PLAY OR FORWARD AT ALL. WHEN YOU PRESS ANY BUTTON IT WILL JUST MAKE THE BLEEP NOISE. ALSO ON THE TELE SCREEN IT WILL SHOW PLEASE INSERT CASSETE. AFTER PRESSING EJECT CASSETE TAKES TIME TO COME OUT, TRIED FEW TIMES ON DIFFERENT CASSETES BUT ONE CASSETE THE ACTUAL CASSETE REEL CAME OUT.. WHEN CASSETE INSTERTED IT MAKES A CRINKLE SOUND FOR COUPLE OF SECONDS AS THE TAPE IS SLIPING SOME WHERE. PLEASE HELP AHSAN
  • videoman49 Mar 15, 2008
    Yes, same kinds of problems. But my unit can be controlled just fine when using the capture controls on my editing program on my attached computer.
    Anyone have advice, please ?
    Thank you.
    Mike Comeau
    m.comeau@comcast.net
    Champion:
  • 221 Answers
Recently repaired one of these with what appeared to be a power supply problem; found several defective capacitors on the drive board. The symptoms were similar to what you are seeing.
Posted on Aug 22, 2007
SONY DHR-1000NP : Problem : No power Already replaced some components in shielded part of power supply : Replaced big capacitors (1500 and 2200 and 680 mico farad) R115 and FET Q101 will always...
I have just fixed one of these. The problem was C104 inside the metal shielded section of the PSU. It's a 2.2uF 50V capacitor. Sony used an 85degC version rather than a 105degC (which I've used). Fortunately, no other components were damaged.
Feb 17, 2011 | Sony DHR-1000 DVHS VCR
Mini DV cassettes only fast forward. play or record for about 40 minutes and then displays a message "remove and reload cassette"
can u fine out what format did u use while recording.I mean
DV or DVCAM.if u record in DVCAM then it will happen like this.So change in DV
Jan 26, 2011 | Sony HVR-Z1 Mini DV Digital Camcorder
The machine is connected to the power, but it will not work
Most likely problem is deteriorated electrolytic capacitors. It's been a while since I saw the inside of a DHR-1000, but I do remember replacing several bad caps to bring it back to life.
Dec 11, 2009 | Sony DHR-1000 DVHS VCR
Daewoo DHR-9414/8414 dvd recorder/player won't play zone 4 dvds
Instructions for changing the region:
  • Press the SETUP button
  • Select INIT SETUP
  • Select SYSTEM INFO
  • Using the remote, press 1 1 0 1
  • When the region shows, press 0
  • Press the SETUP button to exit
Aug 29, 2009 | Televison & Video
The DHR-1000ux keeps blowing fuses
Blowing fuses are always an indication of a short circuit somewhere in the circuitry of you unit. Unfortunately, this will require a trip to the shop. Get an estimate before approving repair. In the new world of disposable electronics the cost of repair may exceed the value of the unit.
Aug 28, 2009 | Sony DHR-1000 DVHS VCR
Sony DHR-1000
The timer/display control IC501, located on the FM 26 board (right behind the display tube) is likely bad.
the part number is 8-759-368-84.It will NOT be an easy part for an average consumer to replace. You would be better off looking for a complete FM 26 board A7066705A.
Nov 05, 2008 | Sony DHR-1000 DVHS VCR
DHR 1000 problems
sounds like a keyboard problem, but check all the electrolytic caps -- bad caps sometimes produce strange symptoms.
Mar 15, 2008 | Sony DHR-1000 DVHS VCR
DCR-TRV130 - not playing back
The head may be dirty, clean it with a cleaning cassete, playing using the cleaning cassete will clean the dirty head.
May 18, 2007 | Sony Handycam DCR-TRV130 Digital Camcorder
VCR not working for some cassettes
What do you mean by "not able to play my VCR with some cassettes. " Is it that some tapes do not display images? No Video? From your name it seems that you are from India, Assuming that to be so, I also presume that you must be possesing a Multi-System VCR, to play back PAL Tapes from India, and NTSC tapes from the US. And if that is the case, I guess it is a simple problem of resetting the System standards. Please go to the Main menu of your VCR using the Remote, and select AUTO in System (You will be given choices of AUTO, PAL, NTSC 3.58, NTSC 4.43 and NTSC PB PAL. Likewise, it is entirely possible that your Television SYSTEm Standard has been accidentally changed. If it is Multi System TV, Then, again, using the Remote of the TV, select Menu, and then select AUTO in System. In all likelihood your problem should get solved.
May 13, 2007 | RCA VR605HF VHS VCR
Sony DHR-1000 DVHS VCR Logo
389 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
