Question about Candy CDC266 Dryer
Spare parts I have tried on several sites for a part which i believe to be a THERMAL CUTOUT but all i seem to be able to get is the THERMOSTAT. The problem the part is giving me is that it prevents the heater from working and also brings on the filter light. Could you please help me as to which part it actually is and to where i might purchase one?
  • 1 more comment
  • albert15 Aug 21, 2007
    Thanks for the help (no reset button by the way. I am from the UK.
  • albert15 Aug 22, 2007
    Thanks a lot for your help offer.I am hoping i may have located one through Gias but if this goes belly up i will contact you again.
    Once again thanks.
  • Anonymous Mar 04, 2008
    no water in tank ,not getting hot filter light on
    Novelist:
    Champion:
  • 244 Answers
The thermal cutout is the thermostats u have two in a dryer one for the low heat and one for the high heat there just called a thermal cutout switch because it prevents the dryer from over-heating and setting a fire m8 but before you buy one just check if your thermostat for the lower heat might have a small reset button attached to it if it does then press this and if it not faulty will reset itself to start heating up again its that one with the reset buton that are called a thermal cut-out switch let me know which country you live in and i should be able to find you the cheapest web site to order from m8
Posted on Aug 21, 2007
  • peter gittos
    peter gittos Aug 22, 2007
    hiya mate best site ive seen is 4domex.co.uk but you do know that candy parts are exact as hoover candy is just the american version but the exact try this web site or just type in hoover/candy support youll get alot of sites up you can call it a toc for short instead of thermal cutout and they shouldnt be no more than £15 let me know if you get anywhere if not send it to me and ill get you 1 eithin a week might even have them instock m8 just need to see to match
E60 code on Aeg lavertherm dryer understand it us
Yes the NTC or thermal cutoff failure can cause E60 error.
It may look something like this.
AEG Thermostat Thermal Limiter
For diagrams of your dryer refer this site.
AEG LAVATHERM 60750225500 Tumble Dryer Thermostat Spares Parts
Sep 20, 2014 | Dryers
Whirlpool Dryer model LER4624BW2 doesn't get hot enough
What was your solution? I was thinking one or more of the multiple coils in the element could be burned out but not the entire thing I've see that happen before. Glad you got it fixed!
Mar 31, 2012 | Whirlpool Dryers
Jenn Air Microwave builtin oven has no display and will not turn on. Had the power to the oven checked and it's ok. The oven stop working when it was on. The oven is 17 years old.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You should check the internal fuse as well as the oven cavity thermostat / thermal cutout and the magnetron's thermostat / thermal cutout.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Aug 23, 2010 | Jenn-Air JMC7000 Microwave Oven
I have a samsung smh7187 microwave over the range and in the middle of cooking it just shut off. The vent at the top of the unit is still open. The outlet is fine, other things work fine in it-I unpugged...
I would suspect the oven cavity's thermal cutout / thermostat, the magnetron's thermal cutout / thermostat, and/or the fuse.
We have the service manual and have uploaded it to our site here to help you.
Note that your model number's suffix may be different than this manual covers exactly.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Oct 04, 2009 | Samsung SMH7178STD Microwave Oven
Goldstar mv1502w has no power.Not even on display.
You can find the service manual here.
(Also, the owner's manual is here in case you want it)
I would suspect the magnetron thermal fuse / thermal cutout / thermostat (depending on which it has) or the oven cavity thermal fuse / thermal cutout / thermostat (depending on which it has).
To access some components, namely the oven cavity thermal device, you will need to remove the oven form the wall, in which case the installation instructions are very handy.
You can order L.G. parts from Encompass. Or you can call them toll-free at 866-779-5835.
Mar 14, 2009 | Goldstar MV-1515 Microwave Oven
How do i remove a built-in jenn-air microwave?
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
If not, try here.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
If the fuse is good, it may be the magnetron thermal cutout (TCO or thermostat) or the oven cavity thermal cutout (TCO or thermostat).
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Jan 05, 2009 | Jenn-Air Microwave Ovens
Runs but no heat
most common cause of no heat is a blown thermal cutout, over temperature cuthout, thermal fuse (any of a dozen or more names for the same article
examine the exhaust vent ducting inside the dryer for screw on device that looks like this d7573a1.jpg or this 0874a9a.jpg, with wires on the terminals. they are not resettable but they are cheap. despite the large number of dryer models there are only a few cutouts, used in multiple dryers, the local parts guy will be able to match it easily.
test with battery annd bulb, or ohmmeter
conducts-good, no conduct- replace
if you havent disposed of them already, retain the heater and thermostat, they are probably good, and will make spares if the parts guy wont buy back the replacements
Aug 29, 2008 | Kenmore 63942 Dryer
Quit working -Haier Freezer
You have one of three issues here.
Either the thermostat has gone bad,
The thermal cutout has gone bad ontop of the compressor,
or the capacitor is out for the compressor.
Take an hom meter and check the thermal cutout, it should read 0 ohms or "continuity" if it doesnt the cutout is bad.
The only real way to check the cap is with a cap meter.
as for the thermostat check it with a n hom meter to make sure you have good connections internal the thermostat.
If you have any other questions just let me know!
Mar 12, 2008 | Haier 5 cu. ft. / 142 liter Chest Freezer...
Is microwave dead?
It's probably an open thermostat or thermal cutout on or near the magnetron, or possibly the one on top of the cavity / body of the oven.
Once the thermal cutout is replaced and it's alive again, you may then find the magnetron is bad, too, and it runs but won't heat.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Nov 10, 2007 | GE JE1460 Microwave Oven
GE Spacemaker 2.0 Microwave just died!
If you're getting power at the outlet, the most common problems causing a "dead" condition are a bad thermostat (or thermal cutout / thermal fuse) on or near the magnetron, a blown internal fuse, or a problem on the control circuit board. I would suspect the thermal cutout / thermal fuse in this case. You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383 If it seems to be a problem on your control board, we repair these for $39.95 nationwide in most cases. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk If you need more help, feel free to follow up here, but please include your model number (e.g. JVM1190, etc.) I appreciate your thoughtful rating of my answer.
Oct 02, 2007 | GE JVM1190 Microwave Oven
Candy CDC266 Dryer Logo
155 people viewed this question
Top Candy Dryers Experts
Gerry Harvey
Gerry Harvey
Billy Detlefsen
Eddie Dalton
Eddie Dalton
Are you a Candy Dryer Expert? Answer questions, earn points and help others
