Question about kawasaki PVS1965 Portable DVD Player
PVS1965 Monitors wont come on
The monitors will not come on. Neither of them. I would think it was the cable but neither of them work and the odds that two cables went bad isn't too good. Didn't know if somebody knew if the monitors go out easy or if it maybe the out on the player. Don't know which end to start on and its hard to test either way. I have an idea on where to start but would be nice to know if somebody else has tackled this problem already
  • 1 more comment
  • vander1 Nov 19, 2007
    I only use my dvd player on two trips. Then it stop working. The player turn, but the power won't connect to the screens. Target doesn't carry that brand anymore. I need HELP.
  • Anonymous Mar 25, 2008
    dvd player comes on, disc spins but nothing on monitor. no light, no color, no nothing.
  • ayreshead Aug 28, 2008
    Neither of my monitors will come on. It was working fine before I shut it off two minutes ago. Is it fused?
I had the same problem with my player, I took it apart and began troubleshooting. What I discovered was a blown 3.5 amp 125V fuse.
The fuse cost about $3.00 and if you can solder this is a very easy fix. Just pay special attention to the ribbon cables when you are reassemling the unit, their is a white ribbon cable that is not attached well and will just slip right out, when I was putting it back together I secured the cable to the cable end with a small drop of super glue. Be sure that the cable is attached correctly before glueing it, (exposed metal strips on the end of the cable are facing the right way). towards the pins on the board it attaches to.
I was also able to fix my neighbors venturer DVD player with the same exact problem. Internally it is almost the same player, it just costs about a hundred dollars less.
Posted on Jul 27, 2008
These are made by a company called Alco Elecronics Inc. You can find their web site and submit your problem and they will direct you on how to send them in for repair/replacement or call them at 1-800-252-6123. I sent mine in three times. The first time they rejected disks. I sent them in with 25.00 and they replaced the player with a repaired one. Then it started skipping bad and they athorized me to send it free of charge.And again replaced it with a repaired one. Now a year latter the screens won't power up. And I'm getting ready to contact them again.The trash can is where their going next time!!!!!
Posted on Apr 01, 2008
I had the same problem. I am an electronics technician. I have had my unit for 2 years and I fixed it by throwing it in the trash. Fixed it real good!
Posted on Sep 16, 2007
I can't get either of my 2 computer monitors to work through my DVI D cable, both monitors work through a VGA cable, just the DVI wont work, what is wrong?
dvi cable most likely will only work as a second monitor rather than as a primary monitor. Suggest checking you computer video card specifications to see if this is the case.
Apr 23, 2018 | Vga Computers & Internet
My dvd player works but i am not getting anything on the monitors
Well the actually the player isnt working.
If you get no video output, and the wires are hooked up correctly, then the video output circuits are bad and the unit will need replaced.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Aug 08, 2010 | kawasaki PVS1965 Portable DVD Player
How do I put it together?
Plug the fat cables into the monitors on the bottom, and then to the player in the D shaped holes. Plug the 12V (car) adapter into your car's power outlet and then to the player in the small hole that may be marked AC/DC in. There's only one hole that will work - can't mess it up.
Aug 06, 2010 | kawasaki PVS1965 Portable DVD Player
Monitor cable
Here is the website for Kawasaki electronic replacement parts, including this exact cable for $6.50:
http://www.18002526123.com/products.aspx?type=pa&view=104&p=34&sc=6
Feb 13, 2008 | kawasaki PVS1965 Portable DVD Player
Kawasaki pvs1965
u wann put pc on tv use vga cables have tv that ready for it s video out on video cards wont do it
Feb 02, 2008 | kawasaki PVS1965 Portable DVD Player
Kawasaki pvs1965
You can order replacement parts from the following web site. We had accidentally cut one of our player to screen cables and I ordered two through this site. Had them within 2 weeks, no problems. http://www.18002526123.com/products.aspx?type=pa&view=104&p=34&sc=6
Aug 17, 2007 | kawasaki PVS1965 Portable DVD Player
Kawasaki dvd screen damaged
Visit the official customer service website for this product, http://1800customersupport.com/kawasaki, or call them at 1-877-252-6873. They should be able to sell you one. Target also sells an item that should work. It's called the Kawasaki AVM678 or Audiovox AVM6781, and designed to work specifically with the PVS1965 or PVS1965S. I believe it's $79.99, but only available in their stores, in the portable DVD section of the electronics department.
Aug 16, 2007 | kawasaki PVS1965 Portable DVD Player
Kawasaki PVS1965 Portable DVD Player cables
I finally found the customer support website for Kawasaki electronic products, including the PBS1965:
Jul 11, 2007 | kawasaki PVS1965 Portable DVD Player
kawasaki PVS1965 Portable DVD Player Logo
658 people viewed this question
Top kawasaki Televison & Video Experts
Damen Wong
Damen Wong
Jaime Hernandez
Are you a kawasaki Televison and Video Expert? Answer questions, earn points and help others
