Question about Garmin zumo 550 GPS Receiver
Unit won't draw power from the bike battery
I have fitted the unit, wired it up to the battery on the bike and it worked perfectly. Now it will only work on the internal battery. when I mount it on the bike it won't switch to external power, it just runs on the internal battery. I have to charge it up on the mains and if it's over four hours ..........it goes off because the battery has expired. I have cleaned the contacts and checked the fuse and all is ok. Help!??
  • Anonymous Dec 18, 2007
    Yes I have the same problem. I'm going to try the fix noted here and I'll see if that works. The unit has been working fine on the bike for over a month. Then I washed the bike this past weekend. The unit wasn't on the bike when it was washed but the holder was in it's normal spot but I had the rubber cover over the contacts. Maybe they are corroded. I'll take a look.
Ay I just fixed my Zumo 550, that would constantly go into battery power when hook up to my Motorcycle, found the enemy I was fighting was lack of proper ground (-).
Posted on Jun 01, 2008
On the lower side of the zumo there are copperm coloured contact points which have to fit to uprising points of the holder on the motorcycle/car. These contact points are very vulnrable to pollution. Clean them dry and use a tiny bit of contact spray.
My first zumo was replaced under warranty because of damage to the contact points due to a leaking battery
Posted on Nov 21, 2007
Lifefitness recumbent bike battery not charging
Possible causes for a dead battery or it not holding charge
1. Battery has lost its ability to hold a charge (dead battery)
2. Charging system on unit has failed (battery cables, alternator, or alternator control board)
3. Stuck key on the display is causing a constant draw from the battery.
For any further troubleshooting you can contact our Technical Support Team and we would be happy to help you,
online or by phone 888-713-2880 or
http://www.sportsmith.net/supportsearch.aspx
Aug 16, 2014 | Life Fitness 9500 HR Recumbent Bike Next...
Power lead with plug model
tes the charger in another receptacle wall, if is ok , test the receptacle wall if is open, reset the circuit breaker .
if his system use batteries replace, or see if they are o.k use alkaline only.
Other is everything is o.k see if the board is fault or look for some wires loose, or disconnect.
Let me know
Blessing
cuadra2016@yandex.com
cell+whatsApp: +50588611441
Jan 26, 2018 | Life Fitness 9500RHRT Recumbent Bike
2008 electra glide battery draw, test light pulses, now bike wont crank over
The pulsing could be the alarm module. When bike is turned of, you will get small draw for a minute or so and then it should go very low, below a miliamp or so. This is the alarm module setting itself. Check for this. Is battery gone flat while checks were being made? Make sure ignition switch is on when disconnecting battery if alarm (Stock HD) is fitted. If not, alarm module gets confused and can cause problems. The corrct procedure for disconnecting a battery from an alarm fitted HS is - alarm off, ignition switch on, pull main fuse (Maxi Fuse), disconnect battery. To fit, ignition stitch off, connect battery then install main fuse.
Nov 01, 2013 | Harley Davidson FLHTCUI Electra Glide...
Battery won't hold it's charge when fitted to the bike even though it charges when bike is running?
You have a drain of power somewhere. Check all the earths that you can reach. Do you have a dodgy alarm that may have water in the connections, or a damp ignition switch. Use some WD40 to obtain better contacts.
Nov 13, 2012 | 2002 Honda XL 1000 V Varadero
Our life fitness 9500hr recumbent bike stopped working
If this unit has not been used for that period of time then the 6v batt has died ans needs replacing call National Gym Parts @ 1-800-496-7278 to order part# LC001.5
HERE IS THE PROCEDURE TO REPLACE THE BATT:
Tilt the bike on its side, remove mounting screws securing the battery to the bracket. Remove the battery just enough to access and disconnect the black (neg) wire from the (-) terminal and the red (pos) wire form the (+) terminal. Replace battery and reverse procedure when installing battery
Apr 17, 2010 | Life Fitness 9500RHRT Recumbent Bike
It starts and runs perfect but no headlight horn
first... check to make sure you don't have blown fuse.. using an electrical tester also, pierce the wire going into the units(if testing blinkers.. horn.. etc.. make sure you actually turn the blinker or horn on etc) this will tell you if you're getting power to them.. if no power trace wire back to connectors with the tester, checking connections etc... (you can get the electrical tester for about $5, clips onto battery and has small light that turns on when it's getting current to where you pierce the wires)
Sep 02, 2009 | kawasaki Full Suspension Mountain Bike Men
Burnt out
internal failure possibly on power side, lower than 300A fault current so unit could not trip i/p protection and as fault was post ac section, continued to burn internally.
it just broke
no breakers tripped out so it kept drawing current until the fault burnt away.
maybe this is what happened, need to know a lot more info to change hypothisis
Jun 01, 2009 | Vector VEC056D 2500 Watt Power Inverter...
Connecting GPS device to bike's electrical system
I misunderstood, I thought your battery was discharging DURING the ride. Put your meter in current mode. connect one lead to the battery and one lead to your TomTom wiring while the unit is in the cradle. How much current is is drawing? Now remove the TomTom from the cradle. Is it still drawing the same amount? If not, the TomTom is drawing power even while off and that is draining your battery.
Apr 20, 2009 | 2006 Yamaha Stratoliner
Want hold a charge
get a test light and a schematic. unplug stator plug.start bike ,make sure battery has full charge. test each pin on connector that is attatched to the 3 yellow wires.should light on each pin. if all good check for burn marks around connectors, front & back sides, and on wires. if no power on yellow wires, stator problem. if power, plug connector together, now test for voltage in wires on the voltage regulator side of the connector, to see if the voltage is making it through the connector.if there is power to volt. regulator,test w/ multi meter across battery leads to see if there is charging voltage to battery,approximately 13-15 volts. if only battery voltage(12.2 or less) while bike is running,voltage regulator is no good.if charging good, but bike wont start after prolonged sitting(say overnight) a system amp draw test is needed to see if something is staying powered up while bike is not running, drawing down battery.
Feb 18, 2009 | 1994 Suzuki RF 900 R
Garmin zumo 550 GPS Receiver Logo
374 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
