Question about Smeg DWI614 Built-in Dishwasher
Stuck on Glass cycle!
I can reset the dishwasher to start a new cycle but everytime after about 5 minutes it gets 'stuck' on the "glass cycle" and when I open the door it has tried to do something, cold water in there, and dirty dishes! Am I doing something wrong or is it broken?
  • 51 Answers
Hi melH Sounds like the water is not heating. Will be either an open circuit thermostat, heater element, or the switch / relay that controls the element. Using an ohm meter, test the element for resistance. Check thermostats for continuity. Regards
Posted on Aug 21, 2007
Opened dishwasher just as it filled up to put in another glass, now the dishwasher won't wash or drain. Power button won't cut off or reset cycles. Turned off breaker, but still stuck on same cycles
You don't mention what make/model of dishwasher. Some diswashers, like my Bosch, require a reset procedure to "kill" a cycle that you've already started. They don't like to have the power button pressed during the cycle. The procedure to reset varies by make and model. If you have the owner's manual, you may check in there for the procedure.
Oct 15, 2016 | Dishwashers
Frigidare dishwasher ..dead!
please follow the next steps and fix it. God bless you
Float Switch
The float switch may be hung up and this can cause the dishwasher to be stuck in a cycle. 68690bea-e43a-408a-beaf-ff3b0809599a.jpg
Timer / Control
If your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace the timer/electronic control
Jul 06, 2013 | Dishwashers
Maytag dishwasher starts too easily and gets stuck in wash cycle
see this causes and fix it. God bless you
Float Switch
The float switch may be hung up and this can cause the dishwasher to be stuck in a cycle. Check the tutorial and the video for checking this part.
Timer / Control
If your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace the timer / electronic control.
Sep 28, 2012 | Maytag MDB7100AWB Dishwasher
Need reset sequence for dishwasher
see this causes, use the common sense.God bless you
Dishwasher Stuck in a Cycle If your Dishwasher is stuck in a cycle check the following
Float Switch
Timer / Control
Sep 19, 2012 | Whirlpool DU1055XTS Built-in Dishwasher
Dishwasher Stuck Mid Cycle
Jiggle the water level float sensor .It is stuck .
May 14, 2012 | Maytag Dishwashers
My maytag dishwasher is not cleaning properly. when the cycle is finished i find that the detergent did not disolve and rinse away. Instead I find it in a hard crusted lump on the bottom of the machine....
This means the bottom cleaning arm is not spinning. Most arms are removable, one large nut or some plastic fingers or a release. Remove the arm and clean it out. There is likely food, glass or objects stuck in the arm. Broken glass can be really stuck! Watch your fingers!
Apr 16, 2010 | Maytag 24 in. MDBF550 Built-in Dishwasher
Power Light on but will not start cycle
Usually Whirlpool dishwashers have a reset code which is pushing the buttons on your dishwasher such as push heat dry, then normal, then heat dry, then normal, within 5 seconds - so push them fast and in that order and wait. It may take a couple of minutes but should reset. If that isn't it, it may be the pump motor not working properly. Also look down into the bottom of the dishwasher and make sure something isn't stuck down into the drain such as a broken piece of glass or a fork. Is there water still in the bottom? It may not be draining so that would suggest it is stopped up. It could be the keyboard but showing power it seems less likely. I don't think it would be the thermal fuse because that usually stops everything including the power light.
Apr 08, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
My Bosh dishwasher seems to be stuck in the drain cycle. What should I DO?
check your flaot valve,, it just may be stuck in the up position, this sometimes will happen from a peice of glass or a fork i even seen it just get stuck
but if its pumping that float valve must be in th up position
Nov 04, 2009 | Dishwashers
Will not start. control stuck on glasses cycle. display states "39" cannot change cycle or cancel
Go to the fuse pannel and trip the fuse breaker off and then put it on again. It will reset the automatic cycle. Vitally
May 13, 2009 | Frigidaire PLD4555RFC Dishwasher
Timer on dishwasher not working
ok start the washer after it fills and starts washing open the door again and turn the dial to drain shut the door see if it drains if it does then open the door and turn it to heated dry shut the door and get you a small glass of warm water let it sit in heated dry for about 3 minutes open the door and pour the water on the heating element and let me know if it sizzles
Mar 27, 2008 | Dishwashers
Smeg DWI614 Built-in Dishwasher Logo
375 people viewed this question
Top Smeg Dishwashers Experts
Marvin
Marvin
Norman Al-Anbar
paul
paul
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
