Routers
Problem for Routers
Generic problem for all Routers
Firewall and NAT router con...
By mcross_zero on Mar 23, 2009
i have a bitcomet downloader and its always shown on his status'' Nat Port Mapping: Failed(UPNP device not found)'' and in my status light always showing a yellow light which means blocked and it said ''please check your Firewall and NAT configuration.'' i am using a HUAWEI Mobile Connect the max speed is 7.2mbps, but, unfortunately i have only 236kbps speed because of coverage problem.my download is 10kbps max..more often zero. what's really my problem?is there any configuration that i missed from my network?im so confused i dont know what's really my problem, i never use dial-up speed before so i dont know if this is really the problem..please tell me what to do, step by step if possible because im not that good in configuring i am still a begginer.
Comments:
Mar 23, 2009
- where exactly can i find this port forwarding and how?
Best Solution
posted on Apr 26, 2009
Very Helpful)
krazy_joe85
Rank: Apprentice
Rating: 100%, 1 votes
ok guys i tried this and this have works.
im using vista so for xp user this will be a lil different.
hit Start menu
type ``command`` in search bar (Dont Hit Enter yet)
Right clic on command promp (1rst on top) and run it as admin.
In the black Window type ``ipconfig`` hit enter
This will show your internet gateway service and 3 ip adress
take ur IPV4 adress and right it in new browser in url bar.
that will bring you to your modem config etc.
Try to find Home Network Section (something like that),
hit edit and just add the ``application with the port that need to be open`` in the Hosted application.
I hope this will help ya guys.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Mar 23, 2009
Somewhat Helpful)
vincent721
Rank: Wiz
Rating: 82%, 187 votes
set a port forwarding on your router.
the port you open on port forwarding is the port you are going to use on your bitcommet
Comments:
Mar 23, 2009
- go to your router setting.
your gateway ip address,
type the ip address to your internet explorer and press enter
Log In will pop out...
its better if you could download the user manual of your router.
search the manual on google
type the manufacturer and model numbe + manual then click search
Was this helpful?
Yes
No
Solution #3
posted on Aug 13, 2009
Not Rated)
memli
Rank: Apprentice
Rating: 0%, 0 votes
Dear,
I have an public ip and i want to use this public ip for two services
1. Remote IP Camera
2. Remote VPN
Those devices needs to be accessible from outside the network
I can't find the way to configure my Asus Router for those services.
Was this helpful?
Yes
No
Popular Solutions for Routers
Questions and Unsolved Problems for Routers
Answer
We have a 3000 sq ft split level house, so range is critical (could we extend range with antennas,... (More)
Answer
I Have 4 computers connected to a d1-604 router and can only connect to the service with one they... (More)
Answer
can't connect to the internet with my laptop
Answer
Belkin F5D8230-4 version 1002. I have lost Key number.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Routers:
Top Router Experts
Rank: Guru Guru
Solutions: 3587
Experience: Semi retired, was network administrator, proficient with hardware, software, networks, CAD systems
Ask Me
Find more Router Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
