Question about Olympus FE-170 Digital Camera
Camera will take picture, but when viewed they are a strange colour.
If I take a picture, when I view it it has strange 'highlights' of pink and violet at the edges of objects. This has just started as previous photos have been perfect. It takes perfect videos, it is just the still photos that are corrupt. I have tried resetting to the factory settings in case I had inadvertantly changed a setting, but no joy so far. ANY suggestions appreciated.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 206 Answers
This sounds like the first signs of CCD sensor malfunction. If this is correct it will get worse and pretty shortly you will have no image at all in capture mode. Have a new sensor installed and camera will work fine.( btw this is a common fault effecting all makes of digital cameras and v-cams ).
Posted on Sep 04, 2007
There is a purple colour to the screen and the pictures I take are blank. The rest of the camera works fine eg. viewing photos taken, lens opens etc.
better option is to reset the camera to factory reset mode simple way to do it is just press menu & find reset option in the menu ,by choosing it you will bring camera to its those modes when you purchased it without disturbing the stored data in card.try out you will be sucessful "merry chrismas "& god bless you.
Dec 24, 2013 | Samsung Cameras
When i look through the view to take a photo it looks like it is running down the scene as it is melting, the colour is weird also. When I view the photo it is all different colours eg. pink, blue, purple,...
Hi you have either ccd unit (image sensor) or main circuit defective. Also circuitry connector loosen is possible. your local repair shop would charge $35 to 85 depend on what they really want to charge. Thanks and best regard!
May 25, 2011 | FUJIFILM FinePix AV100 Digital Camera
Hello i take a pic but the white section flashes black nikon d60
I'm going to assume you're talking about the picture review on the back display. If I'm wrong, please please let me know.
You're seeing the highlights. Those are the areas of the picture that are overexposed and thus have lost all detail. That's not necessarily an error, though often it is. The proper solution is to reduce the exposure and shoot again.
The quick solution is to press Up or Down on the multiselector while viewing the picture to change your view of the picture. The camera provides several different views, including Highlights, Histogram, and several screens of Image Data.
Feb 14, 2010 | Nikon D60 Digital Camera
Overall pink cast and pink stipe at top of all images taken.
Never had that camera, however, had the same problem -- the pink stripe and pink cast. Turns out the lens cover was slightly cracked and not opening and closing properly. Thus -- the pink cast.
Mar 26, 2009 | Canon PowerShot S400 / IXUS 400 Digital...
Image on LCD jumps
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Apr 09, 2008 | Canon PowerShot A95 Digital Camera
Fuji Finex 800 camera
If it's pink/purple and "streaky", you have a bad CCD sensor. The only fix is replacement of the sensor. This is the main image capturing sensor in the camera. The situation is well documented on the web. It's usually the end of the camera, unless it's under warranty (or just a little past). Approaching Fuji's repair department can sometimes yield a sympathetic rep who'll have it fixed at no charge to you. If you are on the hook for the repair, expect to drop about $100 US.
Mar 23, 2008 | Fuji FinePix S5000 Digital Camera
Display screen image does not show a stable, true image.
Go ahead and try resetting your camera.
Press menu
Go to Setup tab
press up once and highlight reset
press right arrow and highlight reset again
press set button in between arrows.
If that doesn't work then you will have to send it in to be repaired.
Nov 25, 2007 | Casio Exilim EX-Z750 Digital Camera
Coloured lines on picture screen
I have the same issue, Although My camera is a samsung N46, It was working perfectly the night before, then my friend switched it on and it came up with a black backround and pink + purple vertical lines going through it.
Nov 12, 2007 | Olympus FE-120 Digital Camera
Olympus FE-170 Digital Camera Logo
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
