Question about Radio Shack Pro-82 Scanner
Pro-82 buttons dead and won't reset!! Yikes!
Only shows-- 1ch 000 000o -- l/o and scan, no buttons work and will not reset. Has static but that's it. Any way to internally reset this scanner?
  • Himarx Aug 22, 2007
    I kept it plugged in for 1/2 an hour, then it cleared itself! Works normally again. Thanks for the response..
    Brigadier General:
  • 6,966 Answers
Hi, If a simple reset will not correct the error, you may need to re-initialize the scanner (but of course this will delete all your stored memories and presets). To Reset - push a pin through a hole at the side of the scanner and press on the recessed button inside; To Initialize - power off, press TUNE button (leftmost third from the bottom), without releasing TUNE button power on and do a RESET again a bit longer. Wait a couple of seconds (till after the LCD display blinked). Release RESET button then release TUNE button. Try the scanner. If buttons don't work, you may need to verify that KEYLOCK is off. A more comprehensive instruction is detailed at http://support.radioshack.com/support_electronics/doc69/69887.pdf If this does not work, you may need to seek the services of a qualified professional as it needs circuit analysis in the logic section. Good luck and kind regards.
Posted on Aug 20, 2007
SOURCE:
Scanner pro 93
reset it one more time and let the scanner boot before you do any thing else chill out for while dont be so egor
Sep 26, 2013 | Radio Communications
Dimage scan dual iv
It's possible you have physically damaged it but not certain. One old engineers trick to reset anything microchip based is to unplug the device, both power and connection cable, and hold down the power/on button for 30 seconds (time it as it seems to take forever when you are waiting) this will discharge any static and reset the chip-set to defaults. With that done completely reinsert reinsert the negative tray/holder *before* reconnecting power and test it. No guaranties at this point but defiantly the place to start. Message back if this is no help.
Aug 24, 2007 | Konica Minolta Konica/Minolta Dimage Dual...
Whenever i turn on my pro-82 scanner all i get is static and have tried squelch and reset
Check your antenna connections, if the connections are good then try a different antenna. Most likely that is the problem if it's the scanner. If your trying to scan Public Safety Frequencies you may be running into a situation where they have gone Digital and your scanner is Analog or they may have encrypted their frequency or control channels so the scanners won't work.
Sep 21, 2011 | Radio Shack Pro-82 Scanner
My radio shack pro 82 keypad not respond when I press it.Lamp button etc not work, only channel scan running up and down when i pree the arrow :( what should i do to repair it. Initializing procedure is...
Most likely have locked it. Press and hold the lock key lower left button. it will beep several time when unlocked the lock symbol if in the upper left side of the LCD screen next to BANK
Apr 19, 2011 | Radio Shack Pro-82 Scanner
I am trying to scan a document and it is breaking the document up into 4 picture size documents
Hi, It sounds as though you have managed to set the scanner to automatically break up originals. In your scanner driver (I'm not with one at the moment so I'm working from memory) locate the button that says 'Advanced'. When the new window appears look for a button that says 'Reset' or 'Default' It may be a menu item, I'm not sure.
Many scanners can be set to do multiple scans. this is usually indicated by a number of faint rectangles showing in different places in the preview scan. You just have to find the button that turns that feature off.
Feb 02, 2011 | Canon PIXMA MP760 All-In-One InkJet...
Is weather chanel all i can get with pro-82?
Try the SCAN button......hope this was helpful......
May 15, 2010 | Radio Shack Pro-82 Scanner
Epson Stylus Photo RX510 - Scanner Error, Grating Noise
Hi there
You can download this from my website.
Main features.
SSC Service Utility allow you to do many amazing things with Your Epson printer :
1) Work directly with CSIC in Epson Stylus printers cartridges.
2) Reset or rewrite any chip using special addon device.
3) Freeze internal ink counters.
4) Reset internal ink counters even with empty cartridges.
5) Separate cleaning of color and black heads for all Epson inkjet printers, powerful cleaning mode.
6) Hot swapping of cartridges supported.
7) Resetting of protection counter (even then it is already full).
8) More then 100 different Epson printers supported
This allow many people with high printing demands to save some money (program works with both black and color cartridges).
Up to day this software works under Windows 95/98/ME/2K2/XP with both the LPT and USB printers.
Download Free
Click Link = http://www.4all2sell.com/reset-tools/sscserve.exe
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
All files on my website are only there for a limited time
Mar 12, 2010 | Office Equipment & Supplies
My scanner will not scan
You need at least 2 or more frequencies programmed, and
adjust the squelch knob until there is no more static, then press the scan button.
Here's a manual
Feb 09, 2010 | Radio Shack Pro-82 Scanner
I'm getting a color line going down the page on my pictures and the quality of the picture is no good
IssueWhen you copy, fax, or scan an original, the resulting output contains vertical bands, lines, or streaks in one or more colors.When you print the original, the output is normal. Figure 1: Sample output with vertical white or black linesc01892760.gif Figure 2: Sample output with vertical colored bands or linesc01892761.gif
NOTE: This article does not apply to most PSC products, to the Photosmart C6100 or C7200 series, or to the Photosmart Premium C309a and C309c All-in-Ones.If you are using a PSC product other than the PSC 2400 or 2500 series All-in-Ones, go to Vertical Bands, Lines, or Streaks in Copies, Faxes, or Scans (c01887564) (in English).If you are using a Photosmart Premium C6100 or C7200 series All-in-One, go to Vertical Bands, Lines, or Streaks in Copies, Faxes, or Scans (c00899181) (in English). If you are using a Photosmart Premium C309a or C309c All-in-One, go to Vertical Bands, Lines, or Streaks in Copies, Faxes, or Scans (c01622189) (in English). Solution one: Reset the All-in-One If there is static interference, or loose connections with the product, this can result in bands or lines in the copy, fax, or scan output. To resolve this issue, check the product connections and reset the product.
  1. Make sure the product is powered on, and then disconnect the power cord from the product.
  2. Disconnect the USB cable from the product, and then disconnect it from the computer.
  3. Reconnect the USB cable to the computer, and then reconnect it securely to the product.
  4. Disconnect the power cord from the wall outlet, and then reconnect it to the wall outlet.
  5. Reconnect the power cord to the product.
  6. Press the Power button (c01892763.gif ) to turn on the product.
  • If these steps resolved the issue , you do not need to continue troubleshooting.
  • If the issue persists , see the next solution.
Solution two: Clean the All-in-One and print a blank copy If the scanner glass or the white underside of the lid has fingerprints, smudges, lint, dust, or other debris, this can slow performance and affect copy and scan quality. To resolve this issue, clean the All-in-One. Before you begin, gather the following materials:
  • Several clean, soft, lint-free cloths
  • Mild glass cleaner
Step one: Clean the scanner glass and lid
  1. Press the Power button (c01892763.gif ) to turn off the product, and then disconnect the power cord from the product.
  2. Open the scanner lid. Figure 3: Open the scanner lidc01893292.gif
  3. Spray a clean, soft, lint-free cloth with mild glass cleaner.
  4. Wipe the scanner glass and the white underside of the scanner lid with the dampened cloth. Figure 4: Scanner glassc01893293.gif Figure 5: Scanner lidc01893294.gif
  5. Dry the scanner glass thoroughly with a clean, dry cloth, or chamois to prevent spotting, and then dry the white underside of the scanner lid.
  6. Close the scanner lid.
  7. Reconnect the power cord to the back of the product, and then press the Power or Start button (c01892763.gif ) to turn on the product.
Step two: Make a blank copy
  1. Remove any originals from the scanner glass.
  2. Load plain white paper in the input tray.
  3. Press Start Copy Black to make a blank copy.
If the copy is clean, there is no need to continue troubleshooting.If the copy has vertical bands, lines, or streaks, there might be dust inside the product, poor internal connections, or the product might be damaged. See the next solution. Solution three: Service the All-in-One If you have completed all the steps listed above and are still experiencing a problem, service the product. Causes
  • Static interference
  • Loose USB cable or power cord connection
  • Fingerprints, smudges, lint, or dust on the scanner glass
  • Dirt or debris on the scanner lid
  • Scratched or damaged scanner glass
  • Poor internal connections
  • Dirt or debris inside the product
  • Damaged or faulty scanner bulb or parts
Jan 27, 2010 | HP Photosmart 2610 All-In-One InkJet...
Radio Shack Pro-82 Scanner Logo
713 people viewed this question
Top Radio Shack Radio Communications Experts
Robert McClure
Jason
Perry Mellott
Perry Mellott
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
