I had the same problem with my A560.If you are handy you can repair it yourself.Remove the seven screws from the camera.Note the hidden longer screw behind the battery door.gently remove the front cover first then the rear.note the place where the screw was behind the door has a slight overlap and will need to be pulled away to clear the corner (watch for the lens o-ring seal).The selector wheel has become misaligned between the contacts.unplug the ribbon for the wheel on camera end.(use a pin in the hole of the ribbon to push it back in later).Unclip it from the housing nearest the top.note alignment of contacts on the pad.I had to bend my contacts very slightly towards the outside on one and in on the other and its works a1 again.The rubber cover for usb plug is easiest to install on the camera body first then put that end back in the housing first.make sure it is properly seated before putting the screws back in.Best of Luck and Happy New Years!
Was this helpful?
Yes
No
Popular Solutions for Canon PowerShot A560 Digital
immediately after charging batteries after taking two photos low indicator warning appears? camera...
(More)
immediately after charging batteries after taking two photos low indicator warning appears? camera is only one year old from date of purchase and only ever used the best batteries
Canon A560 camera problem - the images are overexposed. I checked the exposure setting, AWB, and all...
(More)
Canon A560 camera problem - the images are overexposed. I checked the exposure setting, AWB, and all other settings and they are all normal. There is an exposure setting where I can set to + or - 2, but setting it to -2 does not help much. Outdoor photos are almost completely white. There is some detail in black objects. Indoor photos are overexposed. Flash pictures seem OK. The picture on the display is OK. I compared some macro photos taken a few weeks ago with macro photos now. The good photos have an exposure of 1/5-1/8 second with an ISO of 200. The bad (way overexposed) photos show an exposure of 1/60 second and ISO of 125. Is there an iris in this camera that is stuck open or something? If so, why does the display on the camera look normal but the pictures taken look bad?
the lense is stuck and will not extend. When powered up it makes a clicking noise. We replaced the...
(More)
the lense is stuck and will not extend. When powered up it makes a clicking noise. We replaced the batteries hoping to reboot the camera but still the problem
i tried the suggestions for the card lock problem, sliding the little white button, did not help...
(More)
i tried the suggestions for the card lock problem, sliding the little white button, did not help mine still says its locked, help please...
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
