Question about HP LaserJet 1300 Printer
Hp 1300 printing blank margine lines
Hp 1300 printer not printing complete page.on left corner of the page blank printing.
  • 4 Answers
Hello it was your printer fuser asembly problem and in fuser u have teflion flim which was demange so u need to replace teflion flim
Posted on Sep 09, 2007
SOURCE:
It will not print Word documents. it pulls a blank piece of paper through. It will print in notepad
there is something wrong with your Word printer setup. Go to Word, then from the File menu select the Print option and when the print window opens see if the HP deskjet is selected as default printer. Then, in the upper right quadrant theres a button called Advanced Settings, or Prefferences (depending on your Word version). Click that button and check to see if the HP printer is set as On Line, and is set to print odd and even pages. Also, check the margins of the paper. Ink Jet printers cant print over the full page, there's always a need of some margin on each side of the paper, so you'll need to set the margins from all sides on at least 0.5 inches
Jan 18, 2011 | HP Deskjet F2210 InkJet Printer
My printer -X1185 prints the page with a 3 inch blank area on the left side and some of the right side printing is off the page. This is typical in my e mail page, and even if I center the letter on...
Web site designers create Web pages for display on a monitor, not for users to print on 8.5- x 11-inch pieces of paper. This becomes obvious the first time you try to print a Web page. Content you need may get chopped off by the right printer margin, whereas content you don’t need, such as the site’s copyright information, will print on its own sheet of paper. Fortunately, you can avoid such problems with a little foresight.
Before printing any Web page, open Internet Explorer’s File menu and select Print Preview. The current Web page will appear on-screen exactly as it will print on paper. Scan the preview carefully. If it appears that some content is chopped off by the right margin, click the Page Setup button located directly to the right of the Print button in the upper-left corner of the Print Preview window. In the resulting Page Setup dialog box, adjust the left and right margins so that each is set to 0.25 inches. The extra inch of space you gain by resetting the margins should provide just enough room to accommodate all of the content on most sites. Click OK to save the changes and return to the Print Preview window.
Next, scan the preview to determine which pages contain the content you want to print. Take note of those pages and click the Print button in the upper-left corner of the Print Preview window. Locate the Print Range heading and select the Pages option. Type the number of the first page you want to print in the From field and type the number of the last page you want to print in the To field. For instance, if you want to print just the first three pages of a Web page’s content, type 1 in the From field and type 3 in the To field. If your browser doesn’t have To and From fields, type the range of pages (such as 1-3) in the corresponding field. Make sure your printer has paper and click Print.
May 04, 2008 | Office Equipment & Supplies
I guyz. my hp officejet printer works very fine as in you send document to the printer but the most amazing thing is that afetr printing and you discover there is no ink on the printer page. Please...
Hello
Before actually printing your report, use the Print Preview function to see how it will look. If there are blank pages, you will see them in Print Preview.
To use the Print Preview function, simply open the report, click on the "File" menu and choose "Print Preview" from the file menu. You will then see your report just as it will look on the printed page.
Scroll through the report for blank pages. If you see blank pages, it is an indication that the data on the report is wider than the paper you are using. You can use your printer properties to change the size of the paper if you wish. If you have access to legal-size paper, you may be able to print the report on the larger paper. If legal-size paper is not an option, you will need to adjust the margins so that the blank pages are eliminated.
To adjust the margins of your report, click on the "File" menu and choose "Page Setup" from the drop-down box. Go to the Margins tab and adjust the margins as needed. It may take a bit of experimentation to get the margins just right; toggling back and forth between Print Preview and Page Setup will make the process faster and easier.
Click on the "Page" tab and choose either portrait or landscape orientation. Changing the orientation to landscape may allow all the fields to print on the same page, thus eliminating the blank pages and saving your paper.
Nov 05, 2010 | HP OfficeJet d145 InkJet Printer
Hp 1300 Prints fine but creates a slight wrinkle afterwards on the top left corner of each page. I have blasted the insides of the printer with compressed air whihc made a slight difference.
This could be due to either dust inside the roller shutter or due to paper block which is torn and stuck. I suggest you to get the printer serviced by a near bye service centre.
Good luck.
Oct 19, 2010 | HP LaserJet 1300 Printer
HP 2840 will not print on 3 inches of left side of page
Take the toner cartridge out, shake it back and forth, and turn it around in a circle a few time. Put it back in the priter, and print. Order a new toner cartridge.
If this is an inkjet printer, ignore this response.
Apr 21, 2010 | HP LaserJet 2840 All-In-One Printer
Printer name :hp Laser jet 1300 the print
this printer prints a multipage document on 1 page everytime
Oct 21, 2009 | HP LaserJet 1300 Printer
Samsung ML4551n printing blank pages
This is according to the support section of the Samsung website for this printer
Dark or Blank Image P, td, li {font-family: arial, u; font-size:9pt; margin-top:0px;margin-bottom:0px; word-spacing:1px;} If your printer prints a dark or blank page, your printer requires service. Click on the create service request below to fill out an online service request form so that we can further diagnose and correct the problem.
You can request servicer for this printer here.
http://www.samsung.com/us/support/repaironline/supportOnlineServiceRequest.do
May 27, 2009 | HP Office Equipment & Supplies
HP LaserJet 2430 prints vertical grey bands
It is a bad Toner Cartridge or Fuser. Most likey a bad toner cart.
Mar 07, 2009 | HP LaserJet 2430n Printer
Hp laserjet 1300 prints extra blank page
did you try the hp laserjetIII driver
Apr 22, 2008 | HP LaserJet 1300 Printer
HP LaserJet 1300 Printer Logo
147 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
