Question about Sony SDM M51D 15.1" LCD Monitor
SDM M51 major problem
Tft monitor is about 6 years old has been perfect until now. When switched on, status box is showing missing lines and distortion. Then the screen the goes black, turning to grey in places and somtimes flares out to white. When connected to computer, image, if aquired, distorts and fades to white or gray with residual background image and becomes unusable. Prior to this problem there was a fizzling noise and a smell of ozone. Thanks in advance for any suggestion/help As yet I have not looked inside the case. Tony
  • ARtone Aug 20, 2007
    Thanks for that benimur
    I have now undone the case and had a brief look prior to your email for such a damaged component. There does not appear to be any indication of damage. I have pressed in all the small connectors in case of a HR joint and with the guts still out of the case I have powered it up and it is working perfectly. I am currently concerned that this is an ittermittant fault which will probably return once the case is replaced. after the first burn out it did work again some time later and then failed again yesterday.
    Thanks for the info which is most helpfull for the future
    Tony
    Problem Solver:
For sony SDM-M51 monitors try pinching the the screen on the plastic bezel, about one inch above the speaker holes on the audio output side of the screen. Move up and down a little. If the picture comes back on the problem is the lcd connector to the monitor electronics.
Posted on Dec 06, 2007
    Brigadier General:
  • 6,966 Answers
Based on your post/description, the "fizzling noise and a smell of ozone" are indicators of electronic component(s) that burned. Should you be comfortable and have a fair knowledge of component level repair, soldering and the use of a VOM then it is possible to repair it yourself. The inside would basically be divided into 3 electronic group; 1. power supply; 2. video; and 3. illumination. This should be fairly straight forward since the "fizzling noise and a smell of ozone" indicators would also be visually apparent. Fizzling would normally be capacitors leaking their oil at high temp/high pressure. this would probably be in the power supply section (but the other 2 groups have their own capacitors also). Smell of ozone would usually come from high voltage arcing which is only present in the inverter circuitry of the illumination. It is the group responsible for supplying the high voltage high frequency supply of the small fluorescent tube (CCF) that provides the backlight of the display panel. As earlier mentioned, it has also its own capacitors. If for some reason you do not feel comfortable opening and working the electronics inside, you might be better off seeking the services of a qualified professional. Good luck and kind regards. Hope this gives you and idea and how to go about it.
Posted on Aug 20, 2007
I have a 2003 Yukon SLT 4WD with 5.1 engine throwing codes C0283, B0103, C0660. What do they mean?
DTC C0283 (W/O JL4)
The traction control switch is a momentary-contact, normally-open switch that can be used to disable the traction control system (TCS). Each time the traction control switch is pressed, the TCS enabled/disabled status changes. When TCS is disabled, the electronic brake control module (EBCM) illuminates the traction off indicator by opening the service traction control signal circuit.
DTC C0283 (W/JL4)
The traction control switch is a momentary-contact, normally-open switch that can be used to disable the engine torque management function of the TCS. On two wheel drive or all wheel drive vehicles, the traction control switch is directly monitored by the EBCM. On four wheel drive vehicles equipped with selectable 4 LO, the traction contol switch is monitored by the transfer case shift control module (TCSCM), which sends the traction control switch status information to the EBCM on the serial data link. Each time the traction control switch is pressed, the VSES and TCS enabled/disabled status changes. When TCS is disabled, the EBCM sends serial data messages to the IPC to turn ON the traction off indicator and display the stability system disabled message.
DTC C0660
The exhaust solenoid valve is switched on and off via the suspension control module. The suspension control module provides a switched path to ground whenever exhaust activity is required and during a compressor "head-relief" sequence which occurs at compressor start-up if system pressure is lower than 68.95 kPa (10 psi). The suspension control module continually monitors the exhaust solenoid valve circuitry to determine if the voltage level agrees with the commanded state.
DTC B0100, B0101, B0102, B0103, B0104, or B0105
The inflatable restraint front end sensor utilizes a unidirectional 2-wire circuit. The front end sensor modulates current on the interface to send ID, State of Health, and deployment commands to the inflatable restraint sensing and diagnostic module (SDM). The SDM serves as a power source and a ground for the front end sensor. When the ignition is turned on and input power from the SDM is first detected, the front end sensor responds by performing internal diagnostics and sending an ID to the SDM. The SDM considers the ID to be valid if the response time is less than 5 seconds. The front end sensor continually communicates status messages to the SDM, which determines if a fault is present in the front end sensor circuit. When a fault is detected, the SDM resets the front end sensor twice by removing and reapplying power. If the fault is still present, the SDM will set a diagnostic trouble code (DTC).
Oct 16, 2018 | Cars & Trucks
Power supply sony monitor SDM-S204
TRY WITH A OTHER MONITOR ARE THAT OKEY YOUR MONITOR ARE PROBERLY BROOKEN.
ARE THE OTHER MONITOR ALSO BLACK YOUR VIDEOCARD ARE PROBERLY BROOKEN.
ALL CABELS SHOULD ALLWAYS BE SEATED TIGHT.
Jun 07, 2013 | Sony Sdm-s204 20.1" Tft Lcd Color Desktop...
No picture Display when turned on lots of Colour lines, could this be the inverter board problem. the model is Sony TFT LCD Color Computer Display SDM-X72 Serial Number 4530624 Manufactured April...
This is not an inverter problem. The inverter only powers the fluorescent lamps in the back of the LCD panel.
It is probably a fault in the LCD data decoder circuit or a failing connector between the decoder circuit board and the glass LCD panel. If you took it in to a shop, they would probably charge you a full hour's labor minimum - compare that with the price of a new LCD monitor.
Dec 14, 2010 | Sony SDM-HS73P 17" LCD Monitor
Power cord
mcdevito75 here, You should be able to get a replacement power cord at a Radio Shack, Staples, Best buy stores.
Aug 15, 2010 | Sony SDM M51 15.1" LCD Monitor
Srtyws
The cheapest method of all.
Make sure your PC is plugged into a power strip and after windows shuts down just hit the off switch on the power strip.
Unless you want to shell out some cash for a new power board for your monitor.
Mar 11, 2010 | Sony SDM M51 15.1" LCD Monitor
Sony SDM-HS75 tft lcd monitor
I HAVE ONE SONY MONITOR MODEL SDM HS75.
IT IS SHOWING LED BLINKING FAST NO DISPLAY IF CAN ANY BODY HELP ME TO SOLVED MY PROBLUME.
ASHOK MY CELL NO.09322133048
email.ashoksharma4@gmail.com
Mar 02, 2008 | Sony SDM-HS75 17" LCD Monitor
Sdm-n50 fault
I WANT THE SYSTEM CABLE OR IT NUMBER EXIST PLEASE
Nov 10, 2007 | Sony SDM N50R 15" LCD Monitor
Brightness
looks like your contrast is set to very low...just adjust it..
Oct 21, 2007 | Sony SDM M51 15.1" LCD Monitor
Monitor goes blank
Well, I do not think that there is an actual solution for that problem. I had that exact problem and I had to throw mine away. Turn it in to where you bought it and see if they can repair it. Otherwise they will have to replace it.
Apr 09, 2007 | Sony STYLEPRO SDM-S71 (Gray) 17" LCD...
Sony SDM M51D 15.1" LCD Monitor Logo
301 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Computer Links
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
