My sons crib frame that holds the mattress squeaks. Everytime he moves we can hear it squeaking it's really bad. What can we do?
SOURCE: Squeaking noise from Dryer when tumbling
IT IS USUALLY THE "BELT TENSION ADJUSTABLE PULLEY". MOST ARE CHEAPLY MADE ... TRY A BIT OF AXLE GREESE ON IT ... IT IS SEALED FROM THE INNER DRUM AND IS MOUNTED USUALLY ON THE BOTTOM FRAME RAILING.
SOURCE: real bad squeaking noise in dryer
I Have A Neptune Dryer and this solution helped a little bit. I removed the door to my dryer and the front of the dryer opened up. What i saw was 8 years of lint. Next i started the dryer and checked the belt tensioner and found it was squeeking, in another fix suggestion it said to remove and grease the tensioner. this is a bad idea due to all the lint and dirt that is circulated in side the dryer. (No not in the Place where you dry your clean clothes). what happens when you put grease on the tensioner it will collect lint and dirt causing it to clogg up faster and wear out.30 Minutes later dryer dries and no squeeking. Hoooooray.
SOURCE: converting it into a full size bed
Here is the manual: http://www.deltachildrensproducts.com/product_detail.asp?product=100026&dept_id=100027
The product manual will tell you how to convert it to a toddler bed, and here is the contact information to get to customer service to ask where you can get the parts:
http://www.deltachildrensproducts.com/customer_service.asp
SOURCE: convert aspen simplicity 4 in 1 crib to todler bed w/rails
Put the mattress on the lowest level for a toddler bed.
SOURCE: Replacement Parts
I have a similar crib by the same manufacturer. The customer service number is 800-295-1980 or email [email protected].
I've managed to fix the squeaking noise in my bed by putting leather patches between parts that are rubbing. You will also need to check all joint and see if you can tighten the bolts or add glue to the moving parts.
