Question about Gateway 830GM (RB830GM) PC Desktop
High speed fan
I know the computer fan constantly runs, i have a gateway and it all of a sudden started running at its highest speed constantly. Before it would change speeds as it needed but now it just constantly runs fast. Is this cause for concern?
    Scholar:
  • 76 Answers
There is a CMOS setting that you can set on some motherboards which monitor CPU temperature while adjusting fan speed to match. You might have a look into your CMOS settings for such an animal. To enter the CMOS, tap the F1, or F2 or Delete key (depending on your motherboard) about 3-5 seconds after repowering your machine. ZT3000 "Beta tester of "0"s and "1's"
Posted on Aug 21, 2007
  • Gateway Master
  • 12,061 Answers
Well it may just be a program has set it and hasn't set it back... You can use a program called SpeedFan to "Control" ya Fans here ----> www.almico.com/sfdownload.php
Posted on Aug 20, 2007
SOURCE:
Ryobi 725r trimmer carburetor adjustment
Turn both low and high adjustment screws carefully clockwise all the way in - do not overtighten.. Then back out each two full turns. Set the idle speed control for highest setting. Prime and start and let it run and warm up for about 15 seconds - then lower the rpms a tad and then adjust the low end screw for highest rpm. Then reset the idle to lower reasonable level. You may have to go back and forth with those two adjustments till it runs fine at low idle speed..
Then accelerate to highest speed and set the high adjustment for highest rpm. Then go from idle to high speed. If not smooth a small adjustment on the high speed screw is in order. Keep doing that until you get a nice smooth transition form low speed to high speed.
Mar 11, 2017 | Ryobi Garden
Should my fan constantly run when my gateway ms2274 powers on
The fan normally runs in sync with high CPU usage. So, I would say normal. Go ahead and blow out the system with canned air it has become noisier than usual.
Oct 25, 2012 | Gateway NV5214u Notebook
Our fan is constantly running now for the last last 3 days when our computer is on. We have the computer on all day and shut it down at night. It is louder than normal. Why is this and can it be fixed. ...
Its not a problem if you have the computer running all day long. Get an additional fan for your computer. An additional fan will reduce the noise as more fans running at low speed produce low sound that a single fan at high speeds. Make sure that the CPU is free from dust. More the DUST, higher the heat and higher the noise.
Dec 28, 2010 | HP Hewlett Packard Pavilion Slimline...
The fan on the motherboard runs at full force constantly. Any ideas?
This is a common problem for Gateway. The first thing to do is shut the computer down and blow out the dust from the processor heatsink and other areas that it is heavily collected. Then go to the Gateway website and download the latest firmware for your computer. They constantly have fan issues. These are almost always addressed in firmware updates from the manufacturer website.
Oct 19, 2009 | Gateway 3200SB (521563) PC Desktop
Casablanca fan only runs at highest speed
When I turn on any of the fan speeds fan does not come on. When I remove the blades and turn on the ceiling fan on and give it a push the fan stays running. What could it be?
Aug 30, 2009 | Casablanca Fan Panama II 50" Ceiling
Heater fan only works on high after replacement of heater core
It's very possible the fan motor has quit. The squealing noise is caused from motor bearing failure. As the bearings wear out or dry up the motor is harder to turn and require more current to run the motor. On lower speeds, the motor runs off a series of resistors that reduce the amount of voltage and current so the fan runs a lower speeds. If the bearings are worn, there is not enough voltage or current to turn the motor and that's probably the humming noise your hearing.
Good observation by the way.
Let me know.
regards,
Feb 13, 2009 | 2001 Chevrolet Prizm
My gateway Mx6920 is overheated
First off you should know that laptop fans have three speeds high, low, and off. When you first turn a laptop on it will start on high/low (depending on brand) and after a short time will turn off, it may not turn on again for a while. i have had some that will not make it to the desktop without the fan and i had on that was running for several month straight without the fan plugged in (i don't recommend doing this, it was a mistake burned it, reached 70 degrees C).
I would like you to first download Speedfan http://www.almico.com/speedfan437.exe and install it. once installed leave your computer completely off for at least 1 hour. then turn on your computer and once you get to the desktop run speed fan make note of the temps. leave this opened and now use you computer normally for a little bit then come back to speed fan after a while and make note of those temps. once you have done this if you post them in a reply so i can verify if the fan is bad or if it is something else.
Feb 05, 2009 | Gateway MT3705 Notebook
High speed fan
the thermo switch determine how high and how long the fan need to run to obtain the proper temperature, it will be a consern if the fan doesn't run.
as far as the upgrade of your machine. do you have enough RAM (2GB minimum) and how is the CPU?(1.6GHz or better) can the CPU handle the operating system. Since you didn't mention that, and by reading what you say, I believe the machine is not able to handle the Vista, that is why the fan is running at high speed and non-stop. The CPU is getting hot, and the power supply is pulling lots power.
Vista loading takes approximately 1-2 minutes, dependent on how many applications you have installed and what you have on the desktop.
roll back to XP from Vista is no possible, the only way is to reformat and reinstall XP.
Dec 01, 2008 | Computers & Internet
Ceiling Fan only spins 1 speed
assuming you havent messed about with the wireing it can only be the pull cord switch fault or the motor is on its way out
Jul 25, 2008 | Dryers
Open Questions:
See all Gateway 830GM (RB830GM) PC Desktop Questions
Gateway 830GM (RB830GM) PC Desktop Logo
502 people viewed this question
Top Gateway Computers & Internet Experts
Ekse
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
