Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
System Restore gets disabled
Hi, I have Win XP wiht SP2. When I turn off the laptop and turn it on again, the System Restore gets disabled (as ssen in My Computers ->Properties->System Restore->Turn off system restore) This happens every time I turn off my laptop. Is there any solution? Please let me know. Thanks, Shobhit
  • diyowel Feb 10, 2008
    i get this message whenever i click the system restore from the start menu: "sytem restore has been turned off by group policy. To turn on system restore, contact your domain admin."
    When i type gpedit.msc in run, it says "windows cannot find gpedit.msc"
    pls. help. i want my laptop back to normal!
  • diyowel May 11, 2010
    i lost my system restore when i got hit by a virus. the virus is now gone but my sys restore won't work. from the star menu, everytime i click on system restore, i get a message saying: "sytem restore has been turned off by group policy. to turn on system restore, contact your domain admin." pls. help!
  • Microsoft Master
  • 12,061 Answers
You must set the "Service" to "Automatic" here are some instructions. And a link to a M$ KB article about it. support.microsoft.com/kb/302796 Start the Group Policy Editor (gpedit.msc) Navigate to Computer Configuration/Administrative Templates/System/System Restore Set Turn off System Restore and Turn off Configuration to "Disable" Right click on My Computer and Select "Manage". Navigate to Services and Applications/Services Navigate to System Restore Service and double click On the General tab set [Startup Type] to "Automatic" using the drop down list Click the Start button to start the service. Close the Computer Management console Return to System Restore in Group Policy Editor and configure both to "Not Configured" Close Group Policy Editor and reboot the system. After the reboot is complete, right click My Computer, select Properties and the tab for System Restore will have been restored. Configure it to your individual needs.
Posted on Aug 20, 2007
SOURCE:
Disable touchpad
Hi
look for a FN + some key (F3-F12) combination to turn the touch pad off, there can also be a button next to the power button to switch touchpad on and off.
You can also try to disable it using windows itself by right clicking the touchpad software (by the system clock )and in it's settings look for an option to deactivate the internal touchpad.
Hope this helps.
Sep 03, 2014 | Packard Bell Computers & Internet
This is what happens when you turn the computer on . Nothing else can someone help to get it back to how it should be...
2 Solutions
Boot to Safe Mode, by pressing F8 during boot. Then try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig. In Startup tab, uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running. This just disables them in startup. Programs will still load, but when only you initiate.
Remove all USB attached devices like drives.
You may need to roll back system with System Restore. Under Safe Mode (press F8 during boot and choose Safe Mode).
Win 7 - Start > Search type System Restore.
XP - Is Start > All Programs > Accessories > System Restore. Now choose a date prior to problem. You may have to try a few dates.
Uninstall last program(s) that was installed, again in safe mode.
Nov 12, 2012 | Computers & Internet
Good night, i formated the hdd of my compaq armada 1500c, next i install win xp sp2, every time that the computer boot, i see a mesage that says system date and time not set. how can i restore the bios...
There is not a bios partition, as the bios is a firmware on the mother board. You need to press the key specified early during boot up, before the system seeks the hd for load.
Oct 02, 2010 | Compaq Armada 1500C Notebook
I have a dell inpsiron 2200 notebook which i just installed a new windows xp sp2. Before the installation the local area network connectioon was showing but after installation it does not appear again. i...
problem is the win xp operating system
There are no drivers for what you want and the win xp has not been supported for a long time
In fact for so long that win 7 is now in the same boat
Mar 04, 2018 | Dell Inspiron 2200 PC Notebook
Want to unable Autoplay option
go to start menu then u see run.
type in run "gpedit.msc"
then enter and u can see group policy editor.
then go to user configuration -administrative templates - system then u can find in right window
"turn off autoplay" doubler cl kit and disable it.
Jun 02, 2009 | Microsoft Windows XP Professional SP2
After win xp sp2 installation my c700 notebook pc keyboard malfunctioning
Your keyboard uses a driver(small pieces of sftware). Windows might have corrupted the driver with no intentions. You can get into safe mode by pressing F8 on some models and you can either restore just before the update or uninstall the knowledge base update that caused it.
May 17, 2009 | Compaq Presario 700 470024-192 Notebook
Dell Dimension 2400 OEM Win XP OS installed. Problems started after installing SP3. Then it needed 28 critical updates. After reboot I had errors with "shell32.dll and had lost part of my right click...
After remoting into system, noticed that updates.exe was still running in the task manager. Ended updates.exe and downloaded and installed Service Pack 3 for Windows XP. It installed, customer rebooted. Advised on a few maintenance tips for restore points, etc. Skip was a pleasure to work with.
Apr 28, 2009 | Dell Dimension 2400 PC Desktop
I cant get sound drivers for compaq laptop presario V3000 win xp sp2
Hi utkarsh1313,
please try thie following link which will lead you to the download site of HP. Please choose the apprpriate operating system link there (Win XP, Win XP 64 etc.). Then you can download the drivers needed...
Greetings from Germany,
noris017
PS: Please don't forget to rate this advice after you've tested it out! Thanks in advance and have a nice day!
Feb 25, 2009 | Compaq Computers & Internet
I m not able to install win xp sp2 on my compaq notebook
windows xp cant detect ur hdd bcoz its SATA hdd.
Solutions:
1. Install vista instead of XP
2. You need to disable this SATA feature in BIOS to install OS.
SATA disable steps.
1. Restart the computer and start tapping F10 key.
2. Choose System Configuration tab.
3. Disable SATA native support.
4. Save and Exit the BIOS by pressing F10 key
Aug 21, 2008 | HP Compaq Presario V5000Z Notebook
Problem downloading the files from net
dear sachin
please do a system scan for viruses (update your anti-virus first)in safe mode by disabling system restore.if the problem still persists clean your ram and install it again.report back your findings
Apr 03, 2008 | Microsoft Windows XP Professional for PC
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
1,955 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
