Sanyo PLV-55WM1 55 in. HDTV-Ready LCD TV
Problem for Sanyo PLV-55WM1 55 in. HDTV-Ready LCD TV
Sanyo Television PLV-55WHD1
By lolon45ncc on Mar 23, 2009
Green power comes on for a few seconds then turns red. Is this a bulb problem.
Solution #1
posted on Mar 23, 2009
Not Rated)
mohammed387
Rank: Wiz
Rating: 77%, 889 votes
if bulb is ok and this is a DLP the ballast that fires the bulb could be bad
Comments:
Mar 23, 2009
- The power control board that would control the lamp would be the lamp ballast board and yes these board are replaced for your problem
This board usually is not a consumer replaceable part ple contect tecnician
Mar 23, 2009
Mar 23, 2009
- you will need to replace the lamp ballast.
Mar 23, 2009
- have a SANYO PLV-55WHD1. Sound and mouth do not match. Do not have original remote. Using a universal remote.
Solution #2
Not Rated)
regacii
Rank: Guru
Rating: 86%, 78 votes
Sounds like a relay circuit is not latching on when the television is turned on. This problem might be in the power supply subassembly or it might be elsewhere, depending on the circuit design, the slim ps2s will always have a red light on when switched off unless you unplug it. if the light keeps going to standby everytime you want to play and you turn it ,When the TV is powering on it is detecting an issue, possible short, overload, etc etc
Popular Solutions for Sanyo PLV-55WM1 55 in.
Questions and Unsolved Problems for Sanyo PLV-55WM1 55 in.
Do you recommend Sanyo PLV-55WM1 55 in. HDTV-Ready LCD TV?
Answer
Answer
I heard a pop and that when it started doing the same thing, Now mine will act like it's turning on... (More)
Answer
my sanyo tv is flashing red and green and cant get volume keys or channel keys to work
Answer
we had a power failure and now this select a language 1 english 2 espanol 3 francais is all that... (More)
Answer
andy did you get anywhere with this problem? could you find anyone to help? sanyo has been no help... (More)
Answer
no picture,no sound red lite blincks for a 2 min.green for 1 min
Describe your Projection Televisions problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repairmen
in Newport, KY
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
