Question about Frigidaire GLRT83TES Top Freezer Refrigerator
Water in fridge
Water keeps dripping in fridge but the fridge and freezeer are still working and keeping things cold where is the water coming from.
  • 183 Answers
Blocked drain channel at back of fridge, get a flexible cable tie of piece of flexible wire push down as far as will go this will resolve fault. Regards Advisor
Posted on Aug 21, 2007
SOURCE:
The freezeer compartment keeps frosting up
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Mar 18, 2011 | KitchenAid Refrigerators
Temprature control
I suggest turn it to lower temperature, so that water won't drip down. You can get rid of the hardness by keeping those things out of the unit for about half an hour before using, so that it may lose some coldness and become soft.
Jul 05, 2010 | Fisher and Paykel Active Smart® E522BR...
Have a Dawoo no frost fridge. It is getting ice in the bottom of the freezer compartment, and it is dripping water, not into the drip pan in the back, but rather out of the front on to the floor. Otherwise...
You might have to pick a time to switch off your fridge all together for a half day and defrost it and the turn it back on it will probably be ok after that make sure the fans are working properly etc a no frost fridge usually has a heater that comes into play thats why no frost so to speak . but turn it off (plan the best time ) and make sure its fully defrosted . switch it back on and you should be go to go .
Oct 26, 2017 | Daewoo FR143 Compact Refrigerator
Fridge not getting cold
if the fridge is running, but not cooling, only two things- the coolant has leaked out some where, or compressor is worn out. it could be repaired, but if its an old fridge it may not be worth it .
Oct 17, 2009 | Refrigerators
Water leaking into fridge
check to see if the gasket is ripped somewhere on the fridge door this will allow hot air to seep in and cause moisture to form
Apr 17, 2009 | Refrigerators
Bottom of freezeer and fridge are cold, but top areas aren't?
you have defrost problem or check see if condenser fan working
Apr 07, 2009 | GE Refrigerators
Having a water dripping from top of fridge!! p
The problem could be a number of things but you have to know the top of the fridge is the bottom of the freezer (usually) and this surface must be colder than the air that's being circulated in the refg compartment. Obviously Side by Side or bottom freezer would be differant.
4 items to check :
1your air damper switch is set to give you a colder freezer and not allowing enough cooling and dehumidification in the fridge compartment (explanation below of the reason you have to have air flow unobstructed)
2 the defrost on the freezer is not taking place (Explained below)
3 the door seals are not sealing. Use a piece of paper like a $1.00 and slide between the door gasket and the frame if you can pull and push it and it not fold up the seal is open and not working.
4 some fridges have a energy saver switch which is a heater. This switch turns the heater off. It is not needed in everyone's home or locality so the switch may be set to "save energy" and thus not keeping the "dew" off the fridge (usually these heaters are only on the doors and possible on the outer sides of the fridge and not the ceiling, so I doubt this is it, but I do like to eliminate this).
One of the more common things is the defrost not taking place and this can be a verity of thing Ive seen drain lines stop up and refreeze eventually to the point where the upper part of the fridge is too cold not to drip when the humidity come up like in the spring time. A faulty defrost timer / initiator or a bad element or safety switch, bad wire can also cause non defrost.
Defrost is required because the freezer is where the coldest part of the refrigeration circuit is and it requires air from the fridge to move over the coil. When this movement stops a cold ceiling can result. It will eventually follow with warmer fridge temps as humidity and time progresses.
Hope this helps with the mystery of most common problems associated with:
having a water dripping from top of fridge!!
Please grade ma accordingly and GOOD luck!.
Mar 08, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Food is only frozen on bottom shelf
dkburing,
You said, the freezer is only keeping the food frozen on the botton of the freezee. It is cold, but only like a refrigerator.
We need more info,
What is tour brand,model number and the year or age of the fridge.
Waiting for your reply
Huuum
Oct 09, 2008 | Freezers
Frigidaire GLRT83TES Top Freezer Refrigerator Logo
103 people viewed this question
Top Frigidaire Refrigerators Experts
Steve Allison
Steve Allison
Sal De
Thomas F. Schneider
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
