Manual Clock Set
1 Press MENU to display the MAIN menu.
2 Use up/down arrors to choose the CLOCK menu.
Press ENTER and the CLOCK menu will appear.
3 Use left/right arrors to choose the MONTH option.
4 Use down arrow to choose the DAY option.
Use L/R arrors to choose the date.
The day of the week will display automatically.
5 Use down arrorto choose the YEAR option.
Use L/R arrow to choose the year.
6 Use down arrorto choose the TIME option.
Use L/R arrowto choose the time.
Press and hold L or R arrowto advance the clock
continuously.
7 Use down arrow to choose the DAYLIGHT SAVINGS
option.
Use Lor R arrowto choose AUTO, ON, or OFF.
If you choose AUTO, the VCR sets the clock using the
DST information broadcast in the signal (channel). If you choose ON, the VCR adjusts the clock for Daylight Saving Time automatically.
DVD starts and about a minute or two the picture freezes and you can't even eject the disc. Tried to...
(More)
DVD starts and about a minute or two the picture freezes and you can't even eject the disc. Tried to get dvd out after I unplug the player and it resets itself.
dvd player freezes and stops working I have to unplug and hope it resets. tried to clean player with...
(More)
dvd player freezes and stops working I have to unplug and hope it resets. tried to clean player with dvd Dr laser lens cleaner, but I have same freezing of dvd
How do I do the reverse? I want to copy a VHS tape to DVD. Also, can I do this w/o connecting to a...
(More)
How do I do the reverse? I want to copy a VHS tape to DVD. Also, can I do this w/o connecting to a TV? Thank you for your attention to this!
Recently had Charter Communications install digital cable now DVD or VCR will not work - cable...
(More)
Recently had Charter Communications install digital cable now DVD or VCR will not work - cable company said that my machine may need to be reset??? Machine will come on, I hit play, disc and/or tape is playing but not on the TV.
You can no longer set up a timed recording to the VCR after the digital conversion that took place...
(More)
You can no longer set up a timed recording to the VCR after the digital conversion that took place on June 12, 2009. After I ran the channel reprogram the system does not recognize any of the digital channels. There doesn't seem to be any way to get to the ??.001 identity numbers associated with the digital channels over the air. Curt
