John Deere GX255, how to remove the safety switch t allow the mower to mow in reverse?
SOURCE: john deere x340 wont move
there is a release usually behind the seat that has to be pulled in order to push it physically. make sure that the release is pushed in for the forward/reverse to work.
SOURCE: I have a Deere LX188 mower, while mowing the
you need to check the seat switch first then have the park brake switch looked at.is there power to the starter relay?
SOURCE: I was mowing in tall
Sounds like you're having a problem with your Power TakeOff system. The first thing to do is check to see if you didn't bump the PTO switch on your dash. Since you were in tall grass, check to see that there is nothing obstructing your machine.
If all appears OK, then the PTO should be tested. This is an electrical problem and requires a multimeter.
Before you test, check your battery to see if it's charged and that the terminals are clean.
For information on testing the PTO system, I'm pasting a web address with detailed instructions: >>>> http://www.ehow.com/how_7725472_troubleshoot-pto-system-john-deere.html
Copy and paste this link into your browser's address bar.
Good luck to you.
I hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
SOURCE: I have a L118 John
Hi, remove the battery and battery support tray and clean all debris from around the hydrostatic drive, fan and cooling fins. Your problem is caused by the hydrostatic drive overheating. Hope this helps, regards Phil
