Question about Microtek scanmaker 3840
Troubleshooting I have a mikcrotek scanmaker 3840 which is not working now. I tried to scan any document or picture but their is no images appeared on my screen. This scanner is under warranty but the problem is I lost my receipt. I heard a loud sound from the scanmaker when i tried to scan. Hope you can help me as soon as possible coz I have a many paper works to scan. Thank you and good day. INday
    Brigadier General:
  • 6,966 Answers
Hi Inday, Based on your post/description, there appears to be a mechanical problem with your scanner. It would seem that something is blocking the moving part of the scanner internally. Should you wish to give it a try, you have to open the scanner. Chances are you have to invert with the bottom up to access the screws. There might be 6-8 screws with plastic locking at the sides. Upon removal of the bottom plate, the interior of the scanner would be exposed. There should be practically nothing inside except for a movable bar that is held in place on one side by a guide rail and a plastic toothed belt on the other end. Near the topend would be an electronic board. Check that there is no blockage on the guide rail nor on the path of the roller or the toothed belt. Since this sound more of a mechanical problem (due to the "loud sound" that you heard), it should be visually detectable. Good luck and pls post back how things are or should you need further information. Kind regards from Batangas.
Posted on Aug 20, 2007
SOURCE:
How to download driver for microtek scanner 3840 for windows 7
Microtek scan maker 3840 is not available in the model list Try downloading Microtek scanmaker 3860 for win 7
http://ww3.microtek.com.tw/eu/modules/tinyd0/index.php?id=2
this might help.. Thanks, Markus
Jan 25, 2011 | Microtek scanmaker 3840
I need driver for microtek scanmaker 3840
you can download it from
http://www.driverskit.com/freedownload/Scanner/Microtek/ScanMaker_3840_3830_3800_ScanWizard_5_5_93/14515.html
Feb 26, 2010 | Microtek scanmaker 3840
I'm Using Windows vista 32 I cant Find compatible driver software for my Microtek Scanmaker 3840 ! Help me Pls.
Your Model 3840 Scan only works with Win 98SE/ME/2000/XP
At this point you can do:
1) Replace your Scanner for one Vista Compatible
or
2) Downgrade your system to Window XP
Nov 07, 2008 | Microtek scanmaker 3840
Poor scanned image quality
yes u can repair this try to remove the cover clean up the white tiles which reflect the image, also unscrew it and clean up the mirror and lens
Sep 08, 2008 | Microtek scanmaker 3840
Configuration
well go to your setting i mean file menu on you source scanner and locate destination to photo imaging
Sep 05, 2008 | Microtek scanmaker 3840
Installer or microteck scanmaker 3840
  • I need
    Driver
Microtek ScanMaker 3840 Scanner ScanWizard 5 v6.310 Windows 98/ME/2000/XP Multilanguage
May 20, 2008 | Microtek scanmaker 3840
Help !! ,Microtek scanmaaker 3840 problem
maybe you have to clean up your scanner.. and ur settings of scanner might have the wrong configuration....
Feb 24, 2008 | Microtek scanmaker 3840
Scanning problem scanmaker 3840
I have scanmaker 3880 scaner but my C D is missing please sent the softwear for it
Jan 04, 2008 | Microtek scanmaker 3840
Troubleshooting
the scanner has a lock and unlock slides at right corner front, I have the same problem before and it takes long time to figure this out, you will also find how dumb you are with that scanner...
Nov 05, 2007 | Microtek scanmaker 3840
Microtek scanmaker 3840 Logo
67 people viewed this question
Top Microtek Office Equipment & Supplies Experts
Alun Cox
Thomas F. Schneider
Are you a Microtek Office Equipment and Supply Expert? Answer questions, earn points and help others
