Question about Whirlpool SF315 Dual Fuel (Electric and Gas) Kitchen Range
No power is getting to the oven
We have had the power "brown" out due to storms now the oven wont turn on I assume it is a fuse but I cannot find the fuses to check them, "are they in line at the connectors or am I just missing them?
  • 625 Answers
The brown out may have fried the step down transformer.
Posted on Aug 21, 2007
My frigidare gas oven wont turn on...
try changing the igniter it may have burned out or is weak
Aug 26, 2012 | Frigidare FGB24S5DC Gas Single Oven
Lost power due the storm' when power was restored micro. never came back on
Possible that during the power outage there was fault in the mains supply and with the oven being plugged on it is possible that the power supply or the main board is damaged.
Unless you are able the top cover it is difficult to confirm if this can be silly fault like a fuse blown which is on the mains circuit or a Step down transformer or the processor board.
Nov 06, 2011 | Maytag MMV1153A Microwave Oven
I have no power (120VAC) coming from F2 terminal of Fenwall 1466H Ignotor Control. Draft inducer will turn on and oven is inop due to this. I would like internal connections of controller to verify loss of...
I'm assuming you meant to say your draft inducer will NOT turn on. I unfortunately do not have a wiring diagram in front of me (they are usually stickers inside the burner compartment) but you should check to make sure your hood fan is running and that the air switch for the hood fan is closed, your ignition module wont receive power until the hood airflow is verified.
Sep 06, 2010 | Baxter BXA2G Stainless Steel Gas Single...
Wont turn on.no light on when ist plugged
A blown fuse is a very common type of fault due to poor design very often triggered by power surges due to outages or lightning storms. However, the most likely parts to short are easily tested, usually in-circuit, with an ohmmeter and then easily removed to confirm.
Note that it *may be* useful to replace a fuse the *first* time it blows (though it would be better to do some basic checks for shorted components first as there is a small chance that having a fuse blow the second time could result in additional damage which would further complicate the troubleshooting process). However, if the new one blows, there is a real problem meaning that your power Power supply board just die.It can be dead at anytimes.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Hope this work...
Jun 07, 2010 | LG 42LB1DRA 42 in. LCD Television
Put in new wall oven , turned on power and set
my kenmore double oven model 41165 has no power....its hardwired 40 amp....it stopped working when it was cooling down after the slf cleaning cycle..we had a storm and had a minute power outage. Finakky got the door open but it wont turn on at all. Tried the breakers but i stll get no power....no even the bulb.......thanks....
Jun 07, 2009 | Ovens
Unusable new oven after ice storm
HI. the storm has caused an electrical surge that traveled through the home wiring system and, the Oven control received the hit in this case. it is damaged at this point, and it should be replaced asap, if possible. this code represents a major control breakdown. the board is ruined.
replace it asap.
Dec 17, 2008 | Whirlpool RF380LXPS Electric Kitchen Range
Oven will not heat at all after an interrumpted cleaning cycle (power went off)
There is a thermo fuse located behind the back panel of the oven. If the oven appears to be working but is not actually heating then this is the cause. The oven will have to be removed from the wall, power to the oven shut off at the main breaker and the back panel removed. the thermo fuse is just to the left and up from the center of the convection fan. It has 2 wires connected to it.
Jan 02, 2007 | KitchenAid KEBC107 Electric Single Oven
Open Questions:
Whirlpool SF315 Dual Fuel (Electric and Gas) Kitchen Range Logo
180 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Ismael Rodriguez...
Sal De
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
