Question about Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
HOW TO TEST A DYSON MOTOR.
Hi all, hoping someone can help, im wanting to know how to bench test a dyson motor or check the motor for early signs of wear so it doesn't fail in the future, i sell reconditioned dyson and on one of the the motor seemed ok but then started cutting out after 15 mins, i ALWAYS put brand new filters in the machines and replace anything else that needs replacing. thanks in advance craig
    Sergeant:
    Champion:
  • Dyson Expert
  • 357 Answers
A DC-7 has a Panasonic motor which is the best part of it. I have never seen one of those fail within the life expectancy. You do have to consider that a Dyson was never designed to last more than 5 years. The newer Dysons are only designed to last 2 years. If the motor runs for 15 minutes and overheats, my first guess would be a faulty heat sensor on the motor. If it ran only 30 seconds or so, probably a bad motor.
Posted on Aug 08, 2017
SOURCE: DC07 cutting out
check all the filters first
WASH the side filters only
check for blockage in the inspection pipes
visit dyson.co.uk
and click on support you will see help videos there
Posted on Feb 29, 2008
Agent Don
  • 310 Answers
SOURCE: dyson animal will not stand up and question concerning lifetime hepa filter
http://geeksquad.fixya.com/ThreadView.aspx?prdid=34163&thid=630085
Dyson animal will not stand up and question...
Posted by madmimi on May 28, 2008
my dyson will not stand up by itself=catch seems to have failed and online instructions from dyson have not solved the problem- can anyone help
my second question is will dyson replace my lifetime hepa filter that is located beneath the debris collector, it is very black and is not washable
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
In answer to your 1st question, you may want to check with a factory authorized vac dealer who does repair on the Dyson vacuums to see if they can correct the problem, or call the Dyson factory phone # listed below for the nearest vac dealer in your area. 2nd question. The Hepa filter is mostly a wear item and I was not aware of the lifetime Hepa filter and that also would be a good question for the factory to answer, I could not find an answer to the questions and they might be able to clarify the answer to both your questions. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.dyson.com/
Dyson Inc. 600 W. Chicago Suite 275 Chicago, Illinois 60610
Customer Service 1-866-693-9766 questions@dyson.com
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on May 28, 2008
  • 5 Answers
SOURCE: Dyson DC07
Try this page: -
http://www.fixya.com/support/t192124-overheating_dyson_dc07
Regards Gualo
Posted on Mar 21, 2009
rustysheriff
  • 344 Answers
SOURCE: Dyson cleaner keeps cutting out, no blockage found, filter clean.
1. Check the on/off button these can also be troublesome and if you've stood on the cable once or twice you could have a break in the wire and it's shorting, check by turning on and wiggle cable around where it enters machine.
2. Faulty thermocouple, it is held in a white plastic housing screwed with one T15 torx screw to the motor housing. You could replace it but I just shorted mine with some wire and it hasn't failed since and more importantly not caught fire yet!
Posted on May 28, 2009
SOURCE: DC15 Animal brush motor not working?
Same problem but all fuses etc ok I found that there are two wires that move with the head,orange & white located in the left hand bottom panel(side of vacume). they had broken bought some conectors from maplin & all fine now.
Posted on Jun 13, 2009
I have a Dyson dc08 it won't turn on. No smell just won't turn on. Can someone help me? I need to know how to test for... If it's the switch ? If it is the motor ? Motor brush? Cord to machine? Please...
Start by testing the cord and switch to be sure you are getting proper electrical voltage. If so check at the motor. If you are getting proper voltage to the motor and it won't run you may need a new motor.
If you are not experienced in doing the testing required to determine the source and cause of problem or problems it may be less expensive and a lot safer to hire a professional. Not all vacuum repair shops can repair Dyson vacuums. I highly recommend a repair shop that is a Riccar Warranty center as they have the proper training to do the repair correctly.
Jan 28, 2018 | Dyson Vacuums
My dyson just quit working when I plug into electricity it will not come on
This could many things.
In order of ease of checking/testing:
1. Have you checked the fuse in the plug ?
2. It could be a cable fault - do you have a multi-meter and know how to test for continuity ? If not, you'll need help from someone how has/can, if not take your Dyson to a repair shop.
3. It could be a faulty on/off switch - same test criteria as for item 2.
4. It could be a faulty over current/temperature cut-out that safe guards the motor - this is in reality part of the motor so very difficult to replace seperately.
5. It could be a faulty motor - there is no easy way to test a motor but if all the other items above are okay, then it's pretty much a given the motor is finished. Motors can be obtained fairly cheaply but require very good DIY skills and tools to fit.
May 05, 2015 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Ball makes a clicking noise every 0.25 metres. Please help
Please read this answer all the way through there is something that may be relevant (strike out 'important') at the end !
Maybe it's this
"clip that holds the filter in place and the locating lug of the access flap to gently rub together as the ball rotates and create a slight clicking noise as the appliance is moved around (though is not routinely noticed due to the motor noise)"
(from Fully Cleaned Serviced Refurbished Dyson DC25 Animal Ball Vacuum Cleaner )
stop press - I just saw this - if you do not have proper Dyson brand HEPA filters - see end of answer - you may get a loud clicking sound....
The manual tells you about removal and cleaning HEPA filter - the All floors version has one as well)
Otherwise I can only refer to Dyson support, there are various ways of contacting them given at the top right of this webpage Support forDC25 Multi Floor
(the user guide manual is downloadable from this webpage)
Sounds to me as if maybe there is an irregularity on the ball that is contacting the body/ball housing every time the ball does round....unfortunately this makes the ball diameter ~8cm which too small.
18.April.2015
Beware Some After Market DC25 Filters Do Not Fit Correctly March 2014
Apr 18, 2015 | Dyson DC25 All Floors Bagless Upright...
Periodically my Dyson DC07 stops operating, and then will resume operating after about a 10 minute wait period. Is there a thermal switch or "cutout" if the motor is overheating?
Hi there, it's Jack at Dyson.
Like most Dyson vacuums, DC07 is equipped with a thermostat which shuts the machine down for protection if it starts to overheat. This will often be due to a blockage, and the pre-filter may also be overdue for a wash.
The machine will reset automatically after it's been allowed to cool down, but to prevent this from happening again there are a few simple check you can try: http://www.dyson.co.uk/support/dc07/dc07-standard/my-machine-is-not-working/machine-won-t-switch-on-or-cuts-out/my-machine-cut-out-whilst-i-was-using-it/how-to-wash-filters/wand-suction
We recommend washing the filter at least once every 3-6 months, using cold water without detergent. Allow the filter to dry completely before replacing it - this may take at least 12 hours.
Removing any blockages and washing the filter thoroughly should resolve the issue. However, if your machine continues to shut off after you've tried both of these steps please get in touch with us directly so we can talk you through some additional troubleshooting checks. You can reach us by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Feb 10, 2015 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Motorhead problem for dyson 21
Hi Laura, it's Jack at Dyson.
I'm sorry to hear you've had difficulty with your DC21 Motorhead. I'm not sure if you've already been in touch with us directly? If not, it would be worth giving us a call so we can confirm if we're able to help under the terms of your machine's warranty.
Our freephone Helpline number is 1-866-693-9766 (US), or 1-877-397-6622 (CA). If you'd prefer, you can email your details to us at askdysonUS@dyson.com, and someone will be in touch as soon as possible.
Best wishes,
Jack
Dyson Online Customer Support
Feb 01, 2013 | Dyson DC21 All Floors Stowaway HEPA...
I have a Dyson DC28 Animal Bagless Upright Vacuum. The vacuum has no suction. the beater roller turns but there is no suction. The red button and the on off switch only works when the handle is moved...
Sorry to hear you're having difficulties with your DC28. I wouldn't suggest attempting to dismantle the cleaner yourself, as this will void the warranty.
Due to the nature of your issue, it's probably best if you get in touch with us directly - one of our experts will be happy to run through some troubleshooting checks over the phone with you, and provide further assistance. You can call us free on 1866MYDYSON - or if you email your details to askdysonUS@dyson.com, someone will get back to you as soon as possible.
Kind regards,
Jack
Dyson Customer Service
Aug 08, 2011 | Dyson DC28 Animal Bagless Upright Vacuum
Can I vacuum a house full of soot without damaging my dyson?
hi.
i would not like to try it with my dyson.
soot particles are often "oily" or "sticky", and would probably clog any standard hoover.
it would probably work out cheaper to hire someone with an industrial cleaner. that way, not only do they do the job for you, but it is their responsibility if the soot clogs their cleaner.
hope this helps
Apr 24, 2011 | Dyson DC08 Cylinder Bagless Canister...
My dyson hoover keeps cutting out and smells of burning i cant see any obvious blockages does this mean the motor has gone
Hi, It definitely sounds like the motor is toasted.
If you visit http://www.sparesaver.com/help-and-support/dyson-section/dyson-technical-advice-450/ they have alot of info on repairing dyson cleaners AND they sell the parts, cheapest ive seen online.
Hope that helps
Jun 10, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
I have a DC08 Animal. which I love, but the switch is stuck, know I can buy a new one, but HOW do I take it apart, thanks. Maggie
HI there,
I have made a video showing how to access the motor and switch of a dyson dc08.
Have a look at the video I am sure you will find it easy to follow. Please if it is helpful take a moment to give it a thumbs up or maybe leave a comment.
If you need parts for your dyson dc08 check out Nelson Vacuums or VacuumSpot.
Hope this helps!
Dec 22, 2009 | Dyson DC08 Hepa Allergy Bagless Canister...
Dyson dc05 motor cuts out
Check for either voltage to switch or if your not happy or compettant working on live mains.
Switch meter to ohms ensure vacuum is unpluged from mains follow live wire (brown) from plug to exit point on the back of cable rewinder check for continuity shold be dead short if it is check switch if this is ok move to neutral (blue) wire again check from plug to rear of cable winder.
The neutral then goes off to moter again check for dead short,
I think from experience that you will have A break in either live or neutral in the mains lead going to cable winder.
If it is its realy easy to replace winder they come with lead all ready fitted.
If you need one contact me.
http://dysonmanuals.llc.nu/index.htm
Chris...
Nov 16, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
249 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
