FixYa.com
Tags:
Sapphire Technology PURE Innovation PI-A9RX480 Motherboard
Booting a new motherboard I installed recently...
posted by dredo123 on Aug 20, 2007
I have an AMD 690 chipset PI-AM2 RS690 MHD, I have self installed , but will not boot first time , report scannig disk...., your hardware faulty. Plz , can you give me help or advise?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Aug 20, 2007
FixYa! (100)
sandrew
Rank:Wiz Wiz
Rating: 83%, 4487 votes
if you have changed the motherboard without either re installing windows or repairing windows you will need to because of hardware serial numbers that windows checks against installed hardware.
Change the first boot device in the bios F2 or Del on boot up to your cdrom save and exit and then insert the cd before you re boot.
Allow the cd to install the installation files, but when prompted instead of pressing enter to install windows, press 'R' to repair instead, at which point your C: drive will be shown, press 'Y' to answer yes to the c drive that needs to be repaired and press enter and allow a system repair, no docs or files will be lost as you are only repairing not formatting and installing.
If you have already done the above or done a clean install, check in the bios (F2 or Del on boot up) again and see if all your hard drives and cdrom drives are listed correctly, if not select F10 or F12 depending on bios type, which is normally auto detect drives, as you may have faulty or damaged system files or damaged sectors on you hard drive.
If you get running you right click on your hardrive and select explore,right click 'C' drive, then properties, then tools tab and select error checking.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Motherboards problems?
Motherboards
PC Chips M955G Motherboard...
I am looking for a diagram to... Answer This...
Motherboards
Drivers Network Card
Super p4 sce Answer This...
Motherboards
laptop system board
the system board, lcd, and key... Answer This...
Motherboards
fredy
nesecito el driver del sonido... Answer This...
Motherboards
link is broken
hi srinubabu epox ep-4pdaei... Answer This...
Repair Service
Find Motherboard Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
